8 3/4 sure grip, tq,specks, #1083709
09/27/11 05:25 PM
09/27/11 05:25 PM
nesbit,ms.
70sate Offline OP
70sate  Offline OP
nesbit,ms.
489,sure grip,what do i tighten the back plates,and center sec.nuts,i have new gaskets,do i silicone or not?,the backplate n retainer gasrets are metal,the chunk gasket is paper
Re: 8 3/4 sure grip, tq,specks, [Re: 70sate] #1083710
09/27/11 06:17 PM
09/27/11 06:17 PM
45 ft lbs on the center section nuts crisscrossing, not sure on the axle retainer nuts though I usually go pretty snug making sure the plate is being drawn down evenly & not hanging up on the stud threads. No sealer on the white foam gasket. Light coating of silicone on either side of the metal gasket though I prefer to spray it with Permatex "high tack" the red stuff in the spray can as it goes on light and is extremely tacky and seals well. I personally avoid silicone most of the time tho it does have it's place. EDIT copious amts of sealer can make the foam gasket (especially the thick white ones) squish out of the retainer when tightening but several tiny dabs of super glue or actually any gasket sealer will hold it in place if needed. The axle studs are the same diameter/fine threads as the 3rd member studs so the torque may be the same (45) but I would check
