Electric Choke on a T-quad
#1083677
09/27/11 04:12 PM
09/27/11 04:12 PM
Posts: 3,719 Space Station #5
471Magnum
Space Station #5
I’ve been contemplating the possibility of upgrading the intake on my 72 Roadrunner. Currently has the stock case iron 340 intake feeding the 410 stroker through a 400 spec thermoquad. If nothing else, it could use a diet… sumbitch is heavy!
I want to maintain a quasi stock appearance, and like the performance with the thermoquad, so I’m not looking the change carbs.
One of the restrictions in upgrading the intake though is the factory choke thermostat that won’t work on any aftermarket intake. Furthermore, I’d like to block off the exhaust crossover as well. So regardless of what intake I use, converting to an electric choke is a must.
Will the Thermoquad accept the electric choke mechanism off any other carb, like an Edelbrock or late T-quad? Really haven't looked at it closely myself. Anybody done it?
-Jim
I can fix it... my old man is a television repairman. He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: Electric Choke on a T-quad
[Re: DEMONSIZZLER]
#1083679
09/27/11 07:57 PM
09/27/11 07:57 PM
471Magnum
Space Station #5
I'd seen the electrically assisted divorced chokes. That limits my intake selection somewhat.
Thanks for the definitive response.
-Jim
[Re: 471Magnum]
#1083680
09/28/11 12:12 AM
09/28/11 12:12 AM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
My Offy intake has a place to drop in the stock bimetal choke with the wire on it. Just have to make a different length choke rod. Weld a stocker.
Properly tuned you can run them fairly quick in about any weather. No choke! I did that on a daily driver with the crossover blocked, and single digit weather.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
[Re: DaytonaTurbo]
#1083684
09/28/11 08:34 AM
09/28/11 08:34 AM
Rug_Trucker
I did a manual choke on my van when it had a TQ. The cable has to run around from the front side. Drilled a hole in the floor board for the knob.
[Re: Rug_Trucker]
#1083687
09/28/11 04:34 PM
09/28/11 04:34 PM
DaytonaTurbo
Manitoba, Canada
I would NOT run a TQ on a street-car with a totally-blocked crossover. uNless you are in a very-warm climate - 365
Why Doc? My intake is a Offy Dual Port on the carpet hauler. I have a Quadrajet on it right now. I ran a TQ for many years.
The choke is slower to open when the heated crossover is blocked, especially if you're using a cast iron intake.
[Re: DaytonaTurbo]
#1083688
09/28/11 06:48 PM
09/28/11 06:48 PM
Rug_Trucker
I never mentioned I-Ron Myron! OP is looking at aluminum intakes.
BTW a Dual Port Offy is for a low-mid range stump puller. They make others. Usually cheap at swap meets. Very expensive new.
[Re: Rug_Trucker]
#1083691
09/29/11 10:57 AM
09/29/11 10:57 AM
Posts: 30,456 Florida STAYcation
dOoC
The village idiot's idiot
Florida STAYcation
Yours is totally blocked RT ? .. at what temp is the intake when fully warmed up ? ... actual temp? ...or just too hot to touch? ... My MH project will be put-together with either a Eddy alum Streetmaster or SP2P that will be insulated AGAINST heat-loss.
WHY ? ...for the best air-fuel atomization.
[Re: 73rrak]
#1083693
09/30/11 11:49 PM
09/30/11 11:49 PM
Rug_Trucker
I have an electric choke TQ on a cast manifold on a non stock 318 in my 77 Power wagon. It starts fine, runs fine in hot or cold weather and it does get cold here. Mine could be a Ford one I didn't know Ford used the TQ until I read this post but I doubt that it's Ford carb because it still works and it hasn't left dead on the side of the road.
It maybe a 9800 series. After market, 800 cfm.
