Re: OK 3th try with the E-85
[Re: ajcasini]
#1082214
09/25/11 10:27 PM
09/25/11 10:27 PM
Posts: 7,348 Mt.Vernon ,Ohio
VernMotor
Mt.Vernon ,Ohio
Well I will run it Fri night with the set up in it and see where we get. and I will report back LOL Have not run it yet AJ now I got everything fix.
[Re: VernMotor]
#1082216
09/26/11 08:36 PM
09/26/11 08:36 PM
Posts: 16,925 NC
440Jim
NC
[Re: VernMotor]
#1082220
09/28/11 04:51 PM
09/28/11 04:51 PM
Posts: 2,128 sweden
sshemi
sweden
dont listen to what jets someone elses different carb has. If it runs good leave it. If you start to change air bleeds you will offset the whole fuel curve.
[Re: sshemi]
#1082221
09/28/11 10:06 PM
09/28/11 10:06 PM
Posts: 2,442 LOWELL IN
QWK_ENUF
LOWELL IN
i have been running E85 now for three years now with no problems. i have a 3 circuit 1050 set up with the qwk fuel kit. i have went to 99 MJ and bumped up the timing 2 deg over my starting point in 2009. others i have converted also run with no problems. at MMW i ran a best of 9.89 with the trottle loose to run the 10.0 and john cope (CRT) ran a best of 9.94 and jerry hayes (MOPARPITTBULL) ran solid 9.80's with a smaller carb to slow it to the 10.0s. E85 ROCKS.....
WAXER
[Re: VernMotor]
#1082224
09/29/11 09:32 PM
09/29/11 09:32 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Ok I started the car up today for the first time in two days..Man this thing is cold blooded . How is the rest of your cars.. is it a little lean ??
Jamie, what was the ambient temp when you fired it up... E-85 is REAL cold blooded... I wont even attempt it if its 45* or lower(maybe closer to 50*) you have to pump the hell out of it to get it to fire and keep it lit till it gets some temp into the engine
Re: OK 3th try with the E-85 update ( 10-7-11 )
[Re: VernMotor]
#1082228
10/08/11 12:03 AM
10/08/11 12:03 AM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
Making the most out of the little time Jennie let's you drive?
Nice job bud
[Re: MR_P_BODY]
#1082230
10/08/11 12:42 AM
10/08/11 12:42 AM
Posts: 4,069 Mo.
racerx
Mo.
I've started my last Sunday temp. was between 40-45 in the morning u have to pump the h*ll out of it to get it to start and keep it running with the rpm up to get the heat in the motor.
[Re: WILD BILL]
#1082231
10/08/11 10:01 AM
10/08/11 10:01 AM
VernMotor
Mt.Vernon ,Ohio
Nice job bud
I got to keep my 1 win a year streak going !..Jenni can't pick on me to much that way LOL
[Re: VernMotor]
#1082232
10/08/11 10:04 AM
10/08/11 10:04 AM
WILD BILL
BROOK PARK, OH
Nice job bud
What ever you need to tell yourself
