Holly carbs won't stay running #1081752
09/24/11 09:29 PM
09/24/11 09:29 PM
Tennessee
Hemi ragtop Offline OP
Tennessee
Late in 09' We ran my HEMI on the dyno. It did great. At the end of the tuning and power pulls, we idled it to check manifold vacume.
Now, two years later, I am starting the engine in the car. (More on that in a different post). The engine fires instantly, runs fine until the pump shot is used up and dies. No fuel appears in the booster venturies. Fuel level is "spot on" and accelerator pumps work great but the idle circuit doest seem to feed any fuel to the engine at just above idle/no load.
Carbs are 750 square bowl vacume secondaries. Is it possible that they gummed up from sitting for two years?
Re: Holly carbs won't stay running [Re: Hemi ragtop] #1081753
09/24/11 09:38 PM
09/24/11 09:38 PM
Eng off. I'd take out the (4) mixture screws and shoot a 2 second blast of starting fluid into each hole with the red straw. As you know count the # of turns to lightly seated to return em to their orig position & I like the same one returned to it's orig hole
Re: Holly carbs won't stay running [Re: Hemi ragtop] #1081754
09/24/11 11:13 PM
09/24/11 11:13 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I sure hope you drained the gas and flushed the entire fuel system after two years. It would be like starting over again. Those carbs probaly need to come off and be gone thru. Especailly if fuel has been sitting in them.
Coming soon!!!!
Re: Holly carbs won't stay running [Re: Mr.Yuck] #1081755
09/24/11 11:23 PM
09/24/11 11:23 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
yep! i've had the needles stick closed, like in no fuel, .
Re: Holly carbs won't stay running [Re: Mr.Yuck] #1081756
09/25/11 08:37 AM
09/25/11 08:37 AM
Tennessee
Tennessee
ALL new fuel system. Fuel did stay in carbs while engine was in storage waiting for the body work to be completed.
You are probably right, I need to pull the carbs apart and clean/rebuild them. It is just strange to me that the idle circuit is the only thing that seems to have failed.
Re: Holly carbs won't stay running [Re: Hemi ragtop] #1081757
09/25/11 11:23 AM
09/25/11 11:23 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
before storage.. a.k.a. winter I run the carbs empty for just that reason.
Re: Holly carbs won't stay running [Re: Mr.Yuck] #1081758
09/26/11 09:05 PM
09/26/11 09:05 PM
Tennessee
Tennessee
Well, storing gas in a carb for two years, (even VP racing) is not a good idea. When the carbs came apart, you could see the residue. A good cleaning and new kits and I hope that is that.
