Cooling ? #1081043
09/23/11 04:55 PM
09/23/11 04:55 PM
gtx69 Offline OP
super gas
gtx69  Offline OP
super gas
Driving car temp was at 190 running electric fan.Outside temps was 67 degrees.Got on freeway for about 3 miles temp went up to 200 any ideas why.
Re: Cooling ? [Re: gtx69] #1081044
09/23/11 04:56 PM
09/23/11 04:56 PM
gtx69 Offline OP
super gas
gtx69  Offline OP
super gas
Engine
Re: Cooling ? [Re: gtx69] #1081045
09/23/11 05:17 PM
09/23/11 05:17 PM
TP Exit 7, NJ, USA
DANA60 Offline
DANA60  Offline
TP Exit 7, NJ, USA
Guage could be a bit off, or you could be lean. Either way, it stops there, does it ever drop back down at any time?
Re: Cooling ? [Re: DANA60] #1081046
09/23/11 07:10 PM
09/23/11 07:10 PM
gtx69 Offline OP
super gas
gtx69  Offline OP
super gas
When i got off the freeway it dropped down.I'm thinking i'm lean my center carb jets are 62.I'm thinking maybe try 64's?Guage is on the money checked with a temp gun.
Re: Cooling ? [Re: gtx69] #1081047
09/23/11 08:20 PM
09/23/11 08:20 PM
IN
ahy Offline
ahy  Offline
IN
It looks like the fan shroud setup is blocking about 25% of the radiator. Try removing the fan + shroud completly and run down the highway. I bet it runs cool - right at stat temp.
If that test works, you need a shroud setup that lets the air flow through the whole radiator... like the OE.
Any reason you couldn't put a mechanical fan and standard style shroud on? They work great.
Re: Cooling ? [Re: ahy] #1081048
09/23/11 10:28 PM
09/23/11 10:28 PM
Eden, Texas
Strawdawg Offline
Strawdawg  Offline
Eden, Texas
X2
Steve
Re: Cooling ? [Re: Strawdawg] #1081049
09/24/11 08:19 AM
09/24/11 08:19 AM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
Uh oh. Factory shroud. Copper. 180 Superstat. Green coolant. Mancini Billet housing. 2 eared factory cap. Thermal fan. Ma knew how to keep them cool.
Re: Cooling ? [Re: gtx69] #1081050
09/24/11 11:05 AM
09/24/11 11:05 AM
overheating "at speed" is usually a partly restricted rad imo. Way less likely is a stat not opening all the way. Something restricting the water flow
