Re: Anyone using a hydraulic roller camshaft? [Re: 451Mopar] #1080928
09/29/11 08:26 PM
09/29/11 08:26 PM
Mississippi
lahatte Offline
lahatte  Offline
Mississippi
So why do I need a bronze distributor drive gear if running hydraulic rollers?
Re: Anyone using a hydraulic roller camshaft? [Re: lahatte] #1080929
09/29/11 09:22 PM
09/29/11 09:22 PM
scratchnfotraction Offline
because the cam core is billet steel and needs the bronze gear and a bronze fuel pump push rod as mentioned.
on my SB the cam core has a cast iron gear pressed and pined on so the stock gear works.
my lunati roller cam runs stock roller lifters,push rods,rockers,retainers,seals with comp 901-16 spring = single with damper and no machine work,stock retainers/seals
done jerked it and stabed it in the 2nd SB engine with no worrys on another set of roller lifters..something you cant do with a flat tappet hydro or solid.why I consider the roller cam upgrade as an investment
i have 3 roller cams now and a couple stock ones for regrinds
lots more to the BB than a SB so the homework is key to longevity
Re: Anyone using a hydraulic roller camshaft? [Re: scratchnfotraction] #1080930
09/29/11 09:28 PM
09/29/11 09:28 PM
Mississippi
lahatte Offline
lahatte  Offline
Mississippi
I wonder if the cam manufacturer can tell me what I'll need to have and to address in order to put their roller cam in my 440?
Re: Anyone using a hydraulic roller camshaft? [Re: lahatte] #1080931
09/29/11 09:36 PM
09/29/11 09:36 PM
yep,they like to sell more stuff
I want to upgrade my 440 but am a little over all the options and needs to get it done.
plenty here or the race board to ask about it
make a few post on retro fitting a BB & opinions
good luck
Re: Anyone using a hydraulic roller camshaft? [Re: scratchnfotraction] #1080932
09/29/11 11:06 PM
09/29/11 11:06 PM
IN
ahy Offline
ahy  Offline
IN
The alternative to the roller is a fast rate mechanical. Matched up with a good valvetrain it can make a reliable hi-po "fast street" setup. Comp extreme energy high lift, Hughes or a MM lobe cam from Muscle Motors would be a place to start. Matched up with good 3/8" pushrods, 10 degree locks/retainers and good rockers it makes a solid combo. I like the Comp pro-Magnum alloy steel rockers. Good up to about .6" lift, good geometry and no aluminum fatigue issues. At higer lifts and corresponding spring pressures, they need bushed or you need another lifter choice.
Depending on how far you go with lift you would likley need a double valve spring or one of beehive offerings (Comp). Head machining may be required for the doubles. This setup requires high zinc oil to be reliable. I would also use one of the EDM oil hole drilled lifters for added insurance.
On a BB where the roller conversion is tougher and bronze gear durability can be an issue, the mechanical flat tappet is an attractive alternative. You could do something similar with a fast rate hydraulic flat tappet. The fast rate hydraulics are touchy about setup and loose performance to a solid. I don't mind checking lash once in a while so the mechanical cam made a lot of sense to me.
That's what I did on my BB (MM lobe cam). I've got about 8,000 trouble free miles on it.
Re: Anyone using a hydraulic roller camshaft? [Re: ahy] #1080933
09/29/11 11:26 PM
09/29/11 11:26 PM
Mississippi
lahatte Offline
lahatte  Offline
Mississippi
Thanks. I'm not looking to build a race engine, just a stronger street performer. This car doesn't have A/C or power brakes, so not having a lot of vacuum for external devices isn't a concern.
A flat tappet would be fine, but if I could eek out a little more power while maintaining drivability, that's always nice.
Re: Anyone using a hydraulic roller camshaft? [Re: lahatte] #1080934
09/30/11 10:01 AM
09/30/11 10:01 AM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
A good read....my 505 has a few parts to finish collecting and its ready to go. I have a .541 lift roller cam from Comp plus roller lifters, a HV Melling Oil pump, the Bronze dist. gear. (But I have to change out that bushing), I have to get that fuel pump rod as well as all the pushrods, I have the cam button. I just spent the little money I saved and bought the Harland Sharpe rocker assembly. Matched with the Eddy RPM heads and swapping out the valve springs for the COMP recommended ones...I am hoping to own the beast she was destined to be. Hopefully getting to the goal of 550 realistic HP.
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Anyone using a hydraulic roller camshaft? [Re: Pyper70] #1080935
09/30/11 11:40 AM
09/30/11 11:40 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Sounds nice. What compression ratio and intake?
Just asking, I just started building my 505" stroker. Should be about 10:1 with stealth heads, and I am planning on using the comp XR286HR cam with Isky 8005A valve springs, because I plan to use higher ratio rocker arms, maybe 1.7:1?
Re: Anyone using a hydraulic roller camshaft? [Re: 451Mopar] #1080936
09/30/11 02:52 PM
09/30/11 02:52 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
11:1 with a CH28 Dual Quad and dual 500 Eddy's. I have the dual quad setup on my 440 now and LOVE it
Re: Anyone using a hydraulic roller camshaft? [Re: 451Mopar] #1080937
10/02/11 09:40 AM
10/02/11 09:40 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
The only downside to running a roller cam is cost.
Part of the additional cost besides the cam and lifters are valve springs, pushrods, cam button, and bronze distrubitor/oil pump gear.
With a big block maybe, smallblock not so much since the factory churned them out in huge numbers from 88-03.
All you need is the cam and new springs.
I picked up a used ($175) .505 lift Comp Cams roller for my 5.9 Duster and it dropped right in. Stock pushrods, lifters, cam gear and rockers.
Big block is a different story as there isn't any factory pieces to fall back on.
Re: Anyone using a hydraulic roller camshaft? [Re: dogdays] #1080938
10/02/11 12:31 PM
10/02/11 12:31 PM
Heart of Ohio
4boxers4 Offline OP
4boxers4  Offline OP
Heart of Ohio
If you use a hydraulic roller camshaft you can use stock stamped steel rockers, just get the pushrod length right. Millions of Detroit hydraulic roller engines have been built with non-adjustable valvetrain.
R.
Really? No change of the big block rockers from stock non adjustable to adjustable? How did you get the dimension for the proper pushrod size, please? How is the streetability? Thanks!
Persistance is omnipotent Durability Engineer, Chair and Couch division...
Re: Anyone using a hydraulic roller camshaft? [Re: 4boxers4] #1080939
10/02/11 06:13 PM
10/02/11 06:13 PM
IN
ahy Offline
ahy  Offline
IN
R.
I"m sure it could be done with a checking pushrod and made to order pushrods. The stamped rockers have limits on how much spring pressure they can take. They max out at about .5" lift. I wouldn't see the point in running a roller with such small lift. Might as well run a mild hydraulic flat tappet.
Re: Anyone using a hydraulic roller camshaft? [Re: ahy] #1080940
10/03/11 12:18 PM
10/03/11 12:18 PM
dogdays Offline
dogdays  Offline
There are people on this board running the stamped steel rockers to 0.650" lift. I don't like them because they look bad and can flex, but on the other hand they have less rotating inertia than most other rockers and they're inexpensive.
The drill on the pushrods is, you get a pair of checking or adjustable pushrods from a cam or pushrod company and use them to set your lifter preload how you want. Then you mail in the pushrods and they make (or pull off the shelf) a set. There are at least three ways to measure a pushrod and by doing what I have just described you can be assured of getting the right length.
It is also possible to run 16 adjustable pushrods, it was done all the time back in the day.
R.
Re: Anyone using a hydraulic roller camshaft? [Re: dogdays] #1080941
10/03/11 07:44 PM
10/03/11 07:44 PM
IN
ahy Offline
ahy  Offline
IN
I believe you... some have run the stamped rockers at high lifts. I also know quite a few folks have punched holes in them with the pushrod at much lower lifts. It seems like they fall into the "gamble" category beyond about .5" lift. With one consequence of failure trashing most of a $10k+ engine it just doesn't seem like a good gamble.
Re: Anyone using a hydraulic roller camshaft? [Re: ahy] #1080942
10/03/11 08:02 PM
10/03/11 08:02 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
I speared new MP "6-pack" rockers twice on my 440 back in the day running a .509 cam and the recommended springs. You could not get me to run a .500+ cam again with stamped rockers for love or money with a big block.
The new Magnum small blocks seem to have no issues however, I know lots of folks running over 500 lift with them.
Re: Anyone using a hydraulic roller camshaft? [Re: gdonovan] #1080943
10/03/11 08:39 PM
10/03/11 08:39 PM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
funny you mention that because if i DID still run the stamped rockers, my engine wouldnt have eaten a bunch of needle pieces and destroyed itself. They did work fine.
Re: Anyone using a hydraulic roller camshaft? [Re: POS Dakota] #1080944
10/03/11 08:52 PM
10/03/11 08:52 PM
IN
ahy Offline
ahy  Offline
IN
I sure agree with you on the needles. With a stout well oiled shaft MOPAR's don't need them. My favorite types are the ductile iron, Comp Pro Magnum and RAS. All simple, stout and robust plain bearing types when applied correctly. I'm running the Comps.
Re: Anyone using a hydraulic roller camshaft? [Re: ahy] #1080945
10/03/11 09:18 PM
10/03/11 09:18 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
When it comes to roller rockers, in my opinion go with a part with excellent reputation like Harland Sharp or don't bother. Run them on the Magnum engines for thousands of miles without fail.
T&D also has an excellent reputation.
On the GTX I went with a set of Max Wedge rockers I stumbled upon and they are still on the car to this day.
Re: Anyone using a hydraulic roller camshaft? [Re: gdonovan] #1080946
10/04/11 11:56 AM
10/04/11 11:56 AM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
My thoughts exactly. My only weak point in the valve train was the 440 Source Rockers, I have since sold them. I didn't want to trash a 10k motor for a few hundred bucks. I ordered the Harlands and I am awaiting their arrival. The only thing left to really order of mechanical stress are the pushrods.
