Re: $2.00 part failure - OUCH
[Re: tex013]
#1079542
09/20/11 11:44 PM
09/20/11 11:44 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Check the fit of the balancer on the crank snout... It's common for aftermarket balancers to fit to tight and not go on all the way... Once the balancer is on all the way the crank sprocket should be clamped between the step on the crank & the hub of the balancer, there should be virtually no torsional load on the key...
[Re: 1_WILD_RT]
#1079545
09/21/11 01:36 AM
09/21/11 01:36 AM
Posts: 2,475 Sydney,Australia
tex013
Sydney,Australia
balancer is checked good and tight no sign of slop valve first ? who knows - maybe an over rev.Greg did say with the new tune it came up on the tire way easier. Ron,it sure does suck
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: 1_WILD_RT]
#1079550
09/21/11 02:22 AM
09/21/11 02:22 AM
tex013
Sydney,Australia
there is no oil slinger plate fitted - i did wonder about that
Tex
[Re: maximum entropy]
#1079556
09/21/11 06:56 PM
09/21/11 06:56 PM
tex013
Sydney,Australia
[Re: Moparnut426]
#1079557
09/21/11 07:01 PM
09/21/11 07:01 PM
tex013
Sydney,Australia
thanks Kasey, yes too far
Tex
