Re: 8-3/4 rear end selection question [Re: DoctorDiff] #1078646
09/21/11 02:01 PM
09/21/11 02:01 PM
State of Fascism
52savoy Offline
52savoy  Offline
State of Fascism
You talk'n to me???
I got my specs directly from Chrysler...
The only B-body housing that was shorter was the Max wedge..1/2"
Re: 8-3/4 rear end selection question [Re: DoctorDiff] #1078647
09/21/11 02:02 PM
09/21/11 02:02 PM
California
moparbroz Offline OP
California
I will have to adjust to install. I have all the measurements thanks to you guys.
Hebrews 11:1
Re: 8-3/4 rear end selection question [Re: DoctorDiff] #1078648
09/21/11 02:05 PM
09/21/11 02:05 PM
California
California
Thanks for the measurements. I found them also in the tech archive. 3.3" adjustment based on center of the perchs. Thanks!
Hebrews 11:1
Re: 8-3/4 rear end selection question [Re: DoctorDiff] #1078649
09/21/11 02:08 PM
09/21/11 02:08 PM
California
California
"Dr. Diff." I want that offset! Send me the info including shipping to 92867 and payment preferene to moparbros@yahoo.com. Thanks!
Hebrews 11:1
Re: 8-3/4 rear end selection question [Re: 52savoy] #1078650
09/21/11 02:09 PM
09/21/11 02:09 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
The information you got from Chrysler is incorrect.
In addition...
'63 B-body housing: 53 1/4" with 44" perch on center
'64 B-body housing: 55 5/8"" with 44" perch on center (except max wedge)
'71-'73 B-body wagon housing: 59 7/16" with 47.3" perch on center
Re: 8-3/4 rear end selection question [Re: DoctorDiff] #1078651
09/21/11 02:15 PM
09/21/11 02:15 PM
State of Fascism
52savoy Offline
52savoy  Offline
State of Fascism
The information from Chrysler is the "track" measurement. Yours is axle housing length.
correct?
Re: 8-3/4 rear end selection question *DELETED* [Re: 52savoy] #1078652
09/21/11 02:23 PM
09/21/11 02:23 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Post deleted by MoparforLife
Re: 8-3/4 rear end selection question [Re: moparbroz] #1078653
09/21/11 02:45 PM
09/21/11 02:45 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
E-mail sent.
Thanks,
Cass
Re: 8-3/4 rear end selection question [Re: DoctorDiff] #1078654
09/21/11 02:46 PM
09/21/11 02:46 PM
dogdays Offline
dogdays  Offline
I just talked to Bil Abel at Western Drivetrain and he said the Yukon Powr-Loks were still on backorder, this makes nearly two years. But, he did get a TrueTrac in the other day.
He also warned me that Randy's had a batch made this year and rejected them all because of material problems. So if you see a new Powr-Lok on the 'bay or other places, it is probably the Randy's reject and you don't want it. Machining problems may be repairable but material problems aren't usually.
R.
Re: 8-3/4 rear end selection question [Re: 52savoy] #1078655
09/21/11 02:51 PM
09/21/11 02:51 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
"Track measurement" varies with housing width.
Re: 8-3/4 rear end selection question [Re: MoparforLife] #1078656
09/21/11 03:02 PM
09/21/11 03:02 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
My offset hanger/shackle kit bolts in place of the stock brackets. You do not have to modify the new hangers or the body.
In this application, you can't just "move the spring perch" because the U-bolts would end up on top of the housing end.
Re: 8-3/4 rear end selection question [Re: DoctorDiff] #1078657
09/21/11 03:18 PM
09/21/11 03:18 PM
Upper Midwest
Upper Midwest
68 C body is very close to a bolt in. In fact many have done it by just tweaking the springs slightly. That is what I used on 75 Cordoba and just modified the perch slightly.
Sorry Doc, You are right I was going the wrong direction on previous post. (Deleted.)
Re: 8-3/4 rear end selection question [Re: moparbroz] #1078658
09/21/11 04:24 PM
09/21/11 04:24 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
go here and it should answer most,if not all, questions
http://bionicdodge.com/Download/Mopar_8_3_4_Rear_End_Guide.PDF
Re: 8-3/4 rear end selection question [Re: terzmo] #1078659
09/21/11 05:46 PM
09/21/11 05:46 PM
California
California
Awesome resource. Thanks!
Hebrews 11:1
Re: 8-3/4 rear end selection question [Re: moparbroz] #1078660
09/21/11 06:24 PM
09/21/11 06:24 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I also stock custom and standard length 30 and 35 spline high-strength axle packages for most 8 3/4" and Dana 60 applications.
Re: 8-3/4 rear end selection question [Re: DoctorDiff] #1078661
09/21/11 06:55 PM
09/21/11 06:55 PM
California
California
Cass- I will probably need more than just the hanger and shackle kit from you. Can you email be a parts explosion of an 8-3/4 housing, axel and suregrip unit so I can dtermine what I will need? Thanks!
Hebrews 11:1
Re: 8-3/4 rear end selection question [Re: moparbroz] #1078662
09/24/11 11:39 PM
09/24/11 11:39 PM
kansas city, mo
rave_12000 Offline
rave_12000  Offline
kansas city, mo
why do you need to change axles?? looks like correct ones are still in the housing. use a needle grease gun tip to pack the outer axle bearings. i think i have an extra carrier out in the garage.
Re: 8-3/4 rear end selection question [Re: terzmo] #1078663
09/25/11 12:45 AM
09/25/11 12:45 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
That has some REALLY bad info because people don't understand track width versus actual axle width. Track width on all 62-70 B's is not 59.2...
Want a better reference, it's here in the tech archive...
http://www.moparts.org/Tech/Archive/axle/16.html
Re: 8-3/4 rear end selection question [Re: RobX4406] #1078664
09/25/11 12:58 PM
09/25/11 12:58 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
I believe the 70-71, 72? c body is a nice direct bolt in. A buddy just put one in a 74 charger.
That 69 rearend appeared to have axles in it...
