Re: Who builds an affordable well built 416 long block?
[Re: da50r]
#1078380
09/19/11 05:35 PM
09/19/11 05:35 PM
Posts: 27,468 So Cal
autoxcuda
So Cal
I'm getting bored of my 360. Looking for 450 HP and pump gas.
You do, built it yourself.
IMM built cast iron heads, Scat stroker kit, comp XE275HL cam, air gap, 750HP carb, TTI or Dougs headers. Should idle under 800 rpm.
[Re: da50r]
#1078388
09/19/11 10:48 PM
09/19/11 10:48 PM
Posts: 2,617 Stratford nj
cudadan
Stratford nj
,, easy to get 450 hp in a 360 without stroking it,, i have a stock 360 short block,, just with stock eddy heads 950 hp 4000stall and i run 11.50 in a 3390lb ebody, i can drive it anywhere
[Re: da50r]
#1078390
09/19/11 11:48 PM
09/19/11 11:48 PM
autoxcuda
So Cal
Hensley Racing built the engine , and it's still strong, so I think it's a good block for the build.
Hmmm. Do you just buy a $100 to $150 core std bore 360 block, machine that, and keep you current short or long block together as a proven unit?
[Re: da50r]
#1078393
09/20/11 09:35 AM
09/20/11 09:35 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
Yeah I know. It runs good, and it's not weak. It was around 350 rear wheel on a local Mustang dyno. So I'm kinda of saddened to think about taking apart a good engine.
I'd keep it together or sell it, pick up another core...street car, I'd start with a magnum block, use factory roller lifters, a hughes HER3642, and basically emulate this build:
Jesse Lackman's 520HP RHS headed 408
your location, I'd probably look at hensley to do the build
[Re: mkdart]
#1078395
09/21/11 06:38 PM
09/21/11 06:38 PM
Posts: 1,883 Northern OH
rapom
Northern OH
100mph, Closer to 101. with a 1.94 60ft. time. Right now I'm looking at next Wed. to see if I can get that 12.90. I've changed a few things so I'm hoping for the best. Jeff wants to be there when I run also. It was nice to meet you last weekend and I hope the tribulations with your engine are behind you.
