Page 11 of 11 1 2 9 10 11
Re: Post your custom front disc brake setups. [Re: OzHemi] #1076574
05/09/12 05:13 PM
05/09/12 05:13 PM
QLD Australia
Keith Black® Offline
QLD Australia
..another:
(we CNC'd billet brackets as they are non-kit calipers. they're actually Wilwood's largest available calliper).
disc's 14.25.
Darren, out of curiosity...what does the engineer have to say about those home made spindles?
Hi Jeff, he doesn't like them. They're actually the Fat Man spindles and the only 2 in drop spindles available at the time. They'd be ok, but I will probably (most definitely) replace them with the one-piece Magnum force units.
Darren Beale
Keith Black Racing Engines®
Re: Post your custom front disc brake setups. [Re: Keith Black®] #1076575
05/09/12 09:28 PM
05/09/12 09:28 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
I wouldn't have thought he would have liked it. I know the engineer I know of probably would have at it. That is good at least you have another option for it in mind.
Re: Post your custom front disc brake setups. [Re: OzHemi] #1076576
08/11/12 06:20 PM
08/11/12 06:20 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
I've upgraded mine again...
4 piston brembos are off, and going on are the 8 piston ones.
Before..
And after...
Matching AMG Brembo rear calipers are now on.
Re: Post your custom front disc brake setups. [Re: OzHemi] #1076577
08/11/12 07:08 PM
08/11/12 07:08 PM
Midwest
fuseable Online rolleyes
fuseable  Online Rolleyes
Midwest
Since this is a brake thread I will throw this in. Will the Wilwood radial on the AR kit fit under a 15" wheel? How does it compare dimensionally to the slider on a 11.75 rotor, ( I mean what would the dimension be from the outer edge of the caliper from center line, or any other way to compare the two setups)?
Re: Post your custom front disc brake setups. [Re: fuseable] #1076578
08/11/12 07:33 PM
08/11/12 07:33 PM
Ontario,Canada
brads70 Offline
brads70  Offline
Ontario,Canada
Here is my creation for 73 c-body spindles and rotors -Viper calipers on my Challenger...
[IMG]http://i651.photobucket.com/albums/uu240/B_Richmond/PDRM0835.jpg[/IMG
