Re: 440 in the Imperial running weird - vacuum advance? [Re: Caddy] #1075589
09/16/11 08:45 PM
09/16/11 08:45 PM
the frozen wastes...
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
Re: 440 in the Imperial running weird - vacuum advance? [Re: BobAsh] #1075590
09/17/11 07:06 AM
09/17/11 07:06 AM
Middle of Illinois
Ski 61701 Offline
Ski 61701  Offline
Middle of Illinois
In looking at the pics of the motor, it looks like you have a Pertronix ignition coil on it. It also looks like the coil wiring goes through the ballast. I wonder if you have a coil that is already set at say 1.5 ohms, and adding the fact you have the ballast which reduces the voltage, you might not be getting enough juice to spark? Have you looked under the distributor cap to see if the previous owner updated to a pertronix ignition? On that coil the part # should be present, go to pertronix's website and see what you have. Just something to think about, in addition to all of the other's tips for you.
Re: 440 in the Imperial running weird - vacuum advance? [Re: Ski 61701] #1075591
09/19/11 04:45 PM
09/19/11 04:45 PM
pa.
dan9 Offline
dan9  Offline
pa.
I have found out too that Pertronix does not like the lower voltage. An easy thing to check. Also make sure they are not using the coil hot wire to operate an electric choke. This will pull voltage away from the coil.
