Re: Request: Parts Catalog 1969-1971 edition(s)
[Re: Morty426]
#1075118
09/17/11 06:44 PM
09/17/11 06:44 PM
Posts: 2,315 South, FL
cudaized
South, FL
Ola,
I would guess that 2808142 is a lower level part number to the assembly 3417412.
The Bill Of Material for 3417412 might look like this:
3417412 Barracuda Tail Panel Assembly 2808142 Panel 280xxxx License Plate Bucket 0999xxx Square Weld Nuts (2) 1111xxx Sealant
Chris, That is the most plausible explanation. Thank you for your insight. I thought about this scenario [sub assembly] but did not have the resources (i.e. engineering drawing) to confirm my suspicions. The license plate section does not have any part numbers stamped. Just: SS-46 1 (?) and the nuts and sealant??? It makes the most sences (and a lot of things in the world today don't). Thank you.
[Re: 1cuda]
#1075119
09/17/11 06:46 PM
09/17/11 06:46 PM
cudaized
South, FL
i`ve got an nos tail panel that looks exactly like that one- frank.
Thank you frank. Looking forward to the info. How's your 71 V doing?
[Re: mccannix]
#1075120
09/17/11 06:48 PM
09/17/11 06:48 PM
cudaized
South, FL
Ola...yours does not appear to have the holes.
Terry, No Sir. No holes. Just a sloppy primer job! I haven't seen any with the holes pre-drilled. Hummm.
[Re: Morty426]
#1075121
09/17/11 06:53 PM
09/17/11 06:53 PM
cudaized
South, FL
The sub assembly idea for the Barracuda panel, is making more and more sense. Ola Quote:
I also checked my NOS Challenger panel and it has BOTH the number stamped and the stenciled on. They match 2963261
