70 Cuda - Door Hinges: do I have to remove fenders? #1072947
09/11/11 02:04 AM
09/11/11 02:04 AM
Texas
E
ef8Cuda340 Offline OP
E
Texas
Doors are sagging and I need to correct this problem. Can someone guide me on which is the best set of hinges or which set of pins to buy?
Also, as the heading says, do you know if I have to remove the fenders to remove the door hinges for this repair. I hope that is not a dump questions, but its late and dark outside for me to look right now. It's scary out there, too!
thanks in advance
Re: 70 Cuda - Door Hinges: do I have to remove fenders? [Re: ef8Cuda340] #1072948
09/11/11 11:35 AM
09/11/11 11:35 AM
Wisconsin
Stewpar Offline
Stewpar  Offline
Wisconsin
Remove doors: No
Door Hinges: Contact Rick @ http://restorick.com/
Admiration For Multiple Carburetor Vehicles...
Re: 70 Cuda - Door Hinges: do I have to remove fenders? [Re: Stewpar] #1072949
09/11/11 11:41 AM
09/11/11 11:41 AM
Greenville, N.C.
BarrsRestoration Offline
Greenville, N.C.
To help keep your sanity, I would suggest that you change them one at a time, while the door is open and supported. Start with the most worn (usually top) and align before removing the other one.
And no, you do not have to remove the fenders.
Re: 70 Cuda - Door Hinges: do I have to remove fenders? [Re: BarrsRestoration] #1072950
09/13/11 01:17 PM
09/13/11 01:17 PM
o
wunderless Offline
wunderless  Offline
o
Sounds advice right here.
If you can get a buddy to assist, that helps a tonne!
But existing is basically all I do.
Re: 70 Cuda - Door Hinges: do I have to remove fenders? [Re: wunderless] #1072951
09/13/11 01:30 PM
09/13/11 01:30 PM
Texas
E
E
Texas
I appreciate the support!
thanks!
Re: 70 Cuda - Door Hinges: do I have to remove fenders? [Re: Stewpar] #1072952
09/16/11 02:30 PM
09/16/11 02:30 PM
Up in the North and Far Away
AutoEngineer Offline
