Re: Just curious
[Re: 1_WILD_RT]
#106975
08/19/08 11:52 AM
08/19/08 11:52 AM
Posts: 103 Tampa, FL
Saint Crispan
Tampa, FL
Ok, now I'm really not understanding.
An alternator works by spinning wires inside of magnets, and that's how it generates power. Supposedly, the shaft is supposed to be "frictionless", right? The only part which touches is the bearings, because there are no brushes. There is no contact between the magnets and the wires, so where does the resistance come from? Assuming the motion is constant (constant RPM) then why would it be harder to turn when the draw is 40 amps as opposed to 20 amps? The magnets don't change...the field resistance doesn't change...the number of loops of wire doesn't change...so where does the additional loss of horsepower come in?
Re: Just curious
[Re: Saint Crispan]
#106976
08/19/08 12:12 PM
08/19/08 12:12 PM
RapidRobert
I understand that it takes more HP when the alt is under heavy load but I am awed when an individuals math conversion skills are higher than mine(which actually includes almost everyone) . when an alt kicks on or if I full field one I can hear the eng slow down.
Re: Just curious
[Re: Saint Crispan]
#106978
08/19/08 01:29 PM
08/19/08 01:29 PM
Posts: 4,743 Moved to N.E. Tennessee
GomangoCuda
An alternator works by spinning wires inside of magnets, and that's how it generates power. That's backwards. The Rotor is an array of electromagnets that is spinning inside of the coils of wire called a Stator. There are no permanent magnets.
Supposedly, the shaft is supposed to be "frictionless", right? Impossible
The only part which touches is the bearings, because there are no brushes. There sure are brushes, 2 brushes send voltage through the slip rings to the Rotor.
There is no contact between the magnets and the wires, so where does the resistance come from? You never played around with magnets?
Assuming the motion is constant (constant RPM) then why would it be harder to turn when the draw is 40 amps as opposed to 20 amps? The magnets don't change...the field resistance doesn't change...the number of loops of wire doesn't change...so where does the additional loss of horsepower come in? At the risk of over simplification, the more the current draw the longer the voltage regulator keeps the stator energised.
Maybe this will help. Maybe not.http://www.nationsautoelectric.com/function.html
Re: Just curious
[Re: GomangoCuda]
#106979
08/19/08 01:42 PM
08/19/08 01:42 PM
Lost horsepower from automotive alternators comes from several places, some of them insignificcant, but they all add up, and are manifested mostly as heat
First, there is some loss in the belts and pulleys. A V belt has much more loss, fer instance, than a serpentine system
There is SOME loss just in the rotor current. The power needed to operate the field, while small, IS a loss
So you have
Losses due to friction in the bearings
Losses due to friction in the pulleys/ belts
electrical losses--no machine is 100% efficient. THIS IS WHY alternators run so hot--the heat you feel is not only radiated heat from the engine, but the alternator itself gets hot from internal electrical as well as mechanical losses. Some of these are caused by
Losses due to rotor current--while rotor current is small, it IS a loss
rectifier diodes
Losses in the copper windings
Magnetic losses in the core known as hysteresis
Alternators are not as efficient at some RPM's. I can't quote a "curve" for this, but all AC devices suffer from this, even your stereo.
I'm sure someone with an accurate engine dyno could built a chart showing how these add up
Re: Just curious
[Re: GomangoCuda]
#106980
08/19/08 01:56 PM
08/19/08 01:56 PM
Saint Crispan
Tampa, FL
Thank you. Thank you all very much, that was a really good explanation. I was reading on this board a few months ago, a thread on HHO. I have recently been looking into HHO, and I couldn't understand how the losses suffered in horsepower would offset any gains made by feeding straight oxygen and hydrogen into the airflow. I mean, I can see how on newer engines it'd be a wash, because the computer would be monitoring the entire process would simply lean or richen the mix as necessary...but I was curious to know what would happen on my '72, which has no computer. I'm still curious. Anyone want to add their thoughts on this?
Re: Just curious
[Re: RapidRobert]
#106984
08/19/08 04:14 PM
08/19/08 04:14 PM
dogdays
What a mess. If you don't believe it takes power to turn an alternator shaft, you must not think a motor shaft can develop power. One is the inverse of the other.
There is a really simple way to think of an alternator and that is, it is a power converter. It is a black box that converts kinetic energy into electrical energy. It cannot make more energy than it takes in, actually because we live in an imperfect world it will always put out less electrical energy than the kinetic energy it takes in, the residual losses show up as heat.
It is not magic and there are rules. One horsepower equals 746 watts of electricity. One watt equals one volt times one amp.
So if your "12 volt" system is actually generating 14 volts, then a one amp current will make a power output of 14 watts. Dividing 746 by 14 we get 53.3 amps. So if your system is DRAWING 53.3 amps then the alternator is outputting one horsepower's worrth of electrical energy. Stands to reason that the alternator would have to input more than one horsepower to account for the losses. Let's assume with all the inefficiencies it takes 1.2 horsepower input to produce 1.0 horsepower (746 watts or 53.3 amps @ 14 volts)output. We can calculate the efficiency as (1.0 over 1.2) or 0.8333 or 83.33% efficient.
This is probably not far from reality, I'd say a safe guess would be around 75% overall efficiency. So if your system is drawing 100 amps at 14 volts with 75% overall efficiency it will take exactly 2.50 horsepower from the crankshaft.
Now there is another component to acceleration and that is rotating inertia. An engine has only so much power and the power it takes to accelerate the rotating pieces is not available to accelerate the entire mass of the car. Every little bit hurts, so besides accelerating the alternator in a straight line and carrying the load of the current draw, the engine has to accelerate the rotating part of the alternator along with all the spinning things in and on the car. (yes, and when the car is at steady-state speed no power is lost accelerating all of the spinning things.)
R.
Re: Just curious
[Re: cataclysm80]
#106986
08/19/08 05:06 PM
08/19/08 05:06 PM
Saint Crispan
Tampa, FL
Dogdays, you are right, I bow to your wisdom.
I am impressed with your math, especially after I had already read this on Wikipedia:
"Efficiency of automotive alternators is limited by fan cooling loss, bearing loss, iron loss, copper loss, and the voltage drop in the diode bridges; at part load, efficiency is between 50-62% depending on the size of alternator, and varies with alternator speed. In comparison, very small high-performance permanent magnet alternators, such as those used for bicycle lighting systems, achieve an efficiency of around only 60%. Larger permanent magnet alternators can achieve much higher efficiency."
Your rough estimate is not very far off from theirs.
(Grunt.)
But I just can't help it. I'm going to have to set it up and give it a shot myself. Don't get me wrong, I admit freely that you all are right, I'm just the type that has to prove it to myself, even after I have all the info and the knowledge of my superiors to draw upon.
On the other hand...I'm not nearly in any sort of all-fired hurry like I was a few months ago.
