Page 11 of 19 1 2 9 10 11 12 13 18 19
Re: After 8 years my 71 340 Duster is off for paint & body! [Re: 69Cuda340S] #1068125
10/14/12 12:13 PM
10/14/12 12:13 PM
Spokane Washington
ScottSmith_Harms Offline OP
Mr Wizzard
Mr Wizzard
Spokane Washington
Thanks! The florescent lighting in the booth sort of washes it out, it pops a lot better in natural light.
Re: After 8 years my 71 340 Duster is off for paint & body! [Re: 69Cuda340S] #1068126
10/14/12 01:37 PM
10/14/12 01:37 PM
Virginia's Eastern Shore
dmoore Offline
dmoore  Offline
Look'n good Scott
Re: After 8 years my 71 340 Duster is off for paint & body! [Re: UCUDANT] #1068127
10/14/12 08:45 PM
10/14/12 08:45 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
Heres the Drivers side innder wheel lip termination point.
What is the dimension of the rocket moulding clip from tip to tip? How is it attached to the rocker?
Re: After 8 years my 71 340 Duster is off for paint & body! [Re: RoadRunnerJD] #1068128
10/14/12 10:26 PM
10/14/12 10:26 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
The single metal clip is the forward most clip, there are only 2 per car, they bolt on last. The plastic clips are held in place with studs that are welded to the body, they look like nails with 1/4" dia heads. The trim is put on the plastic clips first then after being put on the car the steel clip is added as the final anchor point.
Re: After 8 years my 71 340 Duster is off for paint & body! [Re: ScottSmith_Harms] #1068129
10/15/12 05:35 PM
10/15/12 05:35 PM
Toronto (YYZ) Ontario
YYZ Offline
YYZ  Offline
It looks great, Scott! The Curious Yellow looks to be right on (did you go with Centari or something else?)
Re: After 8 years my 71 340 Duster is off for paint & body! [Re: ScottSmith_Harms] #1068130
10/15/12 06:47 PM
10/15/12 06:47 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Yes it's a fun deal doing one for myself, it's been a long time coming for sure.
I can tell you one thing, this deal isn't cheap! A thousand bucks every time I turn around! Seat covers, upholstry shop labor, misc. machine shop labor, suspension parts, clutch, presure plate, flywheel, tires, center caps, seat belts, weather stripping, carpeting, head liner, door panels, cat wiskers, bumper rechroming, brake work, drive shaft, center section, leaf spring kits, lug nuts, etc, etc, etc.!
Whadya talkin' about Scott?? You can get a "frame off" resto for $25k any day of the week! If you don't believe me, just start a thread on resto costs!
Car is looking great; I hope to see it sometime...
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: After 8 years my 71 340 Duster is off for paint & body! [Re: DPelletier] #1068131
10/15/12 10:30 PM
10/15/12 10:30 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Just updated my shopping list, and I'm sure I've left some stuff out.......
Fuel lines (hard lines and rubber KV – Tank to Carb)
Fuel pump
Brake Lines (hard and flex)
Shocks
Fuel tank (a correct one!)
Rallye Wheel Center caps
Door glass mechanism nylon guides and wear parts (need these badly!)
Leaf spring kits (I already have real zinc liners, need the rest)
Black arm rest bases
Trunk Matt
Spare tire cardboard cover
Undercoating material for wheel wells
8.75 brake and axle seal and brake rebuild parts
U-joints and caps
Trans Mount
Battery
Exhaust
Disc brake caliper rebuild parts
Head lamps
Disc Brake Rotors
Belts
Hoses
Complete decal kit for the car
Cosmolene
Re: After 8 years my 71 340 Duster is off for paint & body! [Re: ScottSmith_Harms] #1068132
10/16/12 02:39 PM
10/16/12 02:39 PM
DPelletier Offline
DPelletier  Offline
C'mon Scott, surely that stuff can't be more than a couple hundred bucks!
The nice thing is that you are knowledgeable enough to avoid many mistakes during the resto and also you know who to deal with and what stuff to avoid.
My Superbee was part of my "Mopar education" and though I tried hard to make the right decisions, I did make many mistakes...luckily (?) most of them were solved by just shovelling more cash at the car! I have more repop stuff in storage than I do on the car; it became commonplace for me to order a repop part, look at it, toss it in the storage room and search ebay for a good or rebuildable original.
Also, some stuff just wasn't available; I sure wish that RPM stuff was out then and I wouldn't have used all that "simulated cast grey" paint on parts....oh well.
With your knowledge and contacts, I bet you can do a truly top drawer resto for not much more than most of us spend for something that, while nice, isn't anywhere near as correct.
Re: After 8 years my 71 340 Duster is off for paint & body! [Re: ScottSmith_Harms] #1068133
10/25/12 10:06 PM
10/25/12 10:06 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
The latest pics before it comes home for the assembly process, hood and deck lid attached and properly painted, the color looks like it should out in the sun, BLINDINGLY yellow!
Re: After 8 years my 71 340 Duster is off for paint & body! [Re: ScottSmith_Harms] #1068134
10/25/12 10:07 PM
10/25/12 10:07 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
b
Re: After 8 years my 71 340 Duster is off for paint & body! [Re: ScottSmith_Harms] #1068135
10/25/12 10:07 PM
10/25/12 10:07 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
c
Re: After 8 years my 71 340 Duster is off for paint & body! [Re: ScottSmith_Harms] #1068136
10/25/12 10:07 PM
10/25/12 10:07 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
d
Re: After 8 years my 71 340 Duster is off for paint & body! [Re: ScottSmith_Harms] #1068137
10/25/12 10:08 PM
10/25/12 10:08 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
e
Re: After 8 years my 71 340 Duster is off for paint & body! [Re: ScottSmith_Harms] #1068138
10/25/12 11:01 PM
10/25/12 11:01 PM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
Looking good! Now its time for the real fun begin after the nerve racking ride home from the body shop..
Re: After 8 years my 71 340 Duster is off for paint & body! [Re: NV69B7RR] #1068139
10/26/12 10:26 PM
10/26/12 10:26 PM
MO
cdp Offline
cdp  Offline
MO
In a few weeks, you should have it all put back together. LOL..
Looking awesome.
I painted my 340 swinger Lemon Twist, and during the spring and fall shows, the bugs loved the car. It was a bug magnet!
Hope you don't have the same problem.
Re: After 8 years my 71 340 Duster is off for paint & body! [Re: cdp] #1068140
10/26/12 11:40 PM
10/26/12 11:40 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
None to worry, we don't have NEARLY the insects that you'll have in the south, been there done that in Florida (Love Bugs)!
Re: After 8 years my 71 340 Duster is off for paint & body! [Re: ScottSmith_Harms] #1068141
10/27/12 07:36 AM
10/27/12 07:36 AM
ME
79machocharger Offline
ME
Very nice
Re: After 8 years my 71 340 Duster is off for paint & body! [Re: 79machocharger] #1068142
10/27/12 11:17 AM
10/27/12 11:17 AM
Southern by Choice
Shoozy Offline
I have a foot fetish
Shoozy  Offline
Southern by Choice
I see a run. Seriously, blinding is an apt description and it looks mahhhvelous.
Old, tired, and sometimes broke down. Me, not my car...
Re: After 8 years my 71 340 Duster is off for paint & body! [Re: Shoozy] #1068143
10/27/12 11:50 AM
10/27/12 11:50 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Looks awesome Scott!!! Are you keeping a log or coming up with a manual for us A body guys to use as a reference/blueprint like the E body guys have?
Re: After 8 years my 71 340 Duster is off for paint & body! [Re: ademon] #1068144
10/28/12 03:36 PM
10/28/12 03:36 PM
Canada
MUSLCA Offline
MUSLCA  Offline
Canada
Looking good Scott........
Love that GY3........
Wilson
