Re: After 8 years my 71 340 Duster is off for paint & body!
[Re: MUSLCA]
#1067965
09/05/11 01:06 AM
09/05/11 01:06 AM
Posts: 732 Canada
MUSLCA
Canada
Do you have more pictures of that Demon??
[Re: MUSLCA]
#1067966
09/05/11 01:47 AM
09/05/11 01:47 AM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
That IS that Demon It's had a lot of work done to it since that trip. The original numbers matching 340 4 speed drivetrain is under the bench for safe keeping and it now has a 525hp 416 stroker 340 in it, new wire harness, restored dash assembly, new Dr. Diff 4.10 center section, rebuilt suspension, new bumpers, tires, brakes, etc. It runs VERY strong on the street and is a hoot to tear around in!
[Re: ScottSmith_Harms]
#1067970
09/05/11 06:20 AM
09/05/11 06:20 AM
Quicktree
Holy cow is this steam cleaner the cats azz! No pics until tomarrow (got dark on me) but it is unreal how easily the Hotsy cleans off grease, grime, even undercoating and paint with no chemicals! The undercoating is comming off slowly but it does come off, I'll try some gasoline on it tomarrow to soften it up a little. The engine bay had a quicky repaint by the previous owner, I nailed it with the Hotsy and the new paint peeled right off down to the original (partially stripped and sanded off) paint. I'll have it all cleaned off mid day Sunday and I'll post more pics.
*NV69B7RR, please plan on taking a LOAD of detail photos of your car, every concievable nut, bolt, undercoating, paint patterns, the works. I'm doing it on mine as well, even though mines been through the perverbial ringer it still has a lot of good original details, yours should offer many more. We (the hobby) need as much detail on these LA cars as we can get, very few have been documented in detail.
holy cow, you did that in your driveway? the EPA local rivers and streams will love you. not to mention your neighbors
[Re: MUSLCA]
#1067976
09/05/11 08:20 PM
09/05/11 08:20 PM
Posts: 4 Indiana
dusted2
Indiana
[Re: dusted2]
#1067977
09/06/11 12:03 AM
09/06/11 12:03 AM
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Ok, so here's the latest, I was basically done with the undercoating project and ready to hand it over to the body guy, but, I still had a few gallons of diesel left in the hotsy and decided to see how much of the Earl Shieb $99.00 white paint job I could hose off....As it turns out the answer was....nearly all of it! Turns out that it had been painted black long ago, thankfully only the outer body was done, that paint had been partially removed by a previous owner before the cheap white paint went on, the rest of the yellow you see is the original paint and THAT is a good thing! I can still make out all of the original details, the lower body paint blackout, the side stripe and tail panel locations, etc. so I can dimension and photograph all of them to get them back on exactly right. It's now cleaned as far as I can take it short of media blasting. Now the few sins of it's past can be clearly seen but it's a short list and all together she's still as solid as a rock for a baseline restoration project. So, if you ever wondered how much work you can take on and make a short job of it with a steam cleaner check out the following pics! Here's what I discovered: The hood and passenger fender, and latch tray support brace are used replacements, not a problem as I have NOS examples of each so those will go on. It has the typical A-body curse (door jamb striker latch pegs are cracked around the posts) It has a few light older body repairs, deck lid, tail panel, leading edge of the roof, rear end of the drivers quarter, passenger door, a big shallow dent in the passenger quarter, and a few other minor scuffs. None are serious enough to demand a new panel. The only rust is the already mentioned drivers footwell spot and some small holes at the very bottom of the quarter panel, couple small butt welded in patches and good to go. So far so good!
