Re: After 8 years my 71 340 Duster is off for paint & body!
[Re: cdp]
#1067945
09/03/11 09:54 PM
09/03/11 09:54 PM
Posts: 1,300 Washington
19cuda73
Washington
Great looking project. Love that color. It will be a head turner when its done.. Thanks for sharing your photos.
1966 Charger 383 4 speed (Black with Red interior) 1973 Cuda 340 4 speed (Lemontwist) 1972 Corvette
[Re: NV69B7RR]
#1067949
09/04/11 01:06 AM
09/04/11 01:06 AM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Holy cow is this steam cleaner the cats azz! No pics until tomarrow (got dark on me) but it is unreal how easily the Hotsy cleans off grease, grime, even undercoating and paint with no chemicals! The undercoating is comming off slowly but it does come off, I'll try some gasoline on it tomarrow to soften it up a little. The engine bay had a quicky repaint by the previous owner, I nailed it with the Hotsy and the new paint peeled right off down to the original (partially stripped and sanded off) paint. I'll have it all cleaned off mid day Sunday and I'll post more pics.
*NV69B7RR, please plan on taking a LOAD of detail photos of your car, every concievable nut, bolt, undercoating, paint patterns, the works. I'm doing it on mine as well, even though mines been through the perverbial ringer it still has a lot of good original details, yours should offer many more. We (the hobby) need as much detail on these LA cars as we can get, very few have been documented in detail.
[Re: ScottSmith_Harms]
#1067954
09/04/11 02:31 PM
09/04/11 02:31 PM
Posts: 20,540 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
Did light colored a-bodies get the bottom of the rocker panel, and the rocker pinch seam painted black? The upper one in the pic almost looks like it has black paint on it, but maybe it's from being wet? The bottom one looks like surface rust from road wear. The bottom of that car looks well preserved. East coasters are already getting jealous.
[Re: Neil]
#1067955
09/04/11 06:02 PM
09/04/11 06:02 PM
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Factory undercoated cars (cars that had the OPTIONAL undercoating added) did come with hood pads as part of the package, all other cars were to recieve "sound deadner" (under coating) in the wheel wells to quiet road noise. It seems that the LA plant "didn't get the memo" and only applied it to the rear of the car. My car was not optioned with undercoating so no hood pad.
The lower body did get a blackout applied but I believe it's because my car came with the lower body molding and it was part of that package, not due to the cars color. It's applied VERY similar to how a 71 Cuda is painted. I took a lot of pics and measurements to get it back on the correct way after paint. The molding mine came with is the same as this 71 Twister is wearing.
The bottom of this car is pristine aside from a few added holes drilled for bucket seats and a dollar bill sized rust spot in the drivers foot well (water leaked past the wiper seal and sat under the gas pedal). The primer/sealer is not as black as I expected, it's close to black but looks tinted towards a deep army green color, there are widely scattered flecks of original GY3 yellow over spray on most areas of the floor pan short of the deepest recess of the floor tunnel, but none of it is very heavy.
I am almost done cleaning off the undercoating, tedious and slow but it all came off (I only used hot water, no solvent yet) it only took a couple hours. The wheel wells were the worst, very heavy coating went slowly, about like a really nasty bead blast cabinet job. Now I'm giving the UC areas a solvent bath/soak and final steam cleanup and she'll be clean. To those whom will be trying this job.......Wear full cover clothing, plan on getting soaking wet, wear goggles to save your eyes, give yourself a full day for the job and cleanup. It's not that bad a job with the steam cleaner and it CERTAINLY blows away a torch and a scaper!
[Re: MUSLCA]
#1067960
09/05/11 01:16 AM
09/05/11 01:16 AM
Posts: 732 Canada
MUSLCA
Canada
[Re: MUSLCA]
#1067961
09/05/11 01:17 AM
09/05/11 01:17 AM
Posts: 732 Canada
MUSLCA
Canada
[Re: MUSLCA]
#1067962
09/05/11 01:19 AM
09/05/11 01:19 AM
Posts: 732 Canada
MUSLCA
Canada
last
