Over Center Clutch Pedal spring #1067579
09/02/11 04:47 PM
09/02/11 04:47 PM
Indiana
Beastiedoggie Offline OP
Indiana
Can someone tell me how to install the overcenter clutch pedal spring for the Body. I have a new one and i'm sure its not going to be easy
Thank you guys
beast
Re: Over Center Clutch Pedal spring [Re: Beastiedoggie] #1067580
09/02/11 05:06 PM
09/02/11 05:06 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
I have used the washer or quarter in between each coil trick to both remove and install them in the past.
Re: Over Center Clutch Pedal spring [Re: 70440+6bbl] #1067581
09/02/11 05:13 PM
09/02/11 05:13 PM
Indiana
Indiana
Ok so ur saying place something in betweem each coil? or is it enough to do just one coil...and can you tell me about how much stretch i'll need to get it on?
beast
Re: Over Center Clutch Pedal spring [Re: Beastiedoggie] #1067582
09/02/11 05:28 PM
09/02/11 05:28 PM
St. John's Newfoundland
440newport Online content
440newport  Online Content
I used wooden shims. You'll have to shim most of the coils. With the pedal to the floor install the spring, and then with the pedal in the up position most of the shims will pretty much fall out.
Re: Over Center Clutch Pedal spring [Re: 440newport] #1067583
09/02/11 06:05 PM
09/02/11 06:05 PM
Indiana
Indiana
Thank U Newport...that answers my question!
beast
