Re: 8 3/4 back brace
[Re: 8urvette]
#1065262
08/30/11 01:13 PM
08/30/11 01:13 PM
Posts: 684 St. Charles, MO.
Slingshot383
St. Charles, MO.
It's just a threaded spud, you can use a long allen screw or cap bolt, use a jam nut to lock it down just past finger tight. It should hit the center of the caps, prevents them from moving rearward and getting broken or spit out.
1994 Undercover Chassis 125" altered
stack injected big block, soon blown and injected
Member of The Torque and Recoil Club
[Re: Slingshot383]
#1065265
08/30/11 03:09 PM
08/30/11 03:09 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Its simple to make... I lay it on the back with the same gap at each end then set my dividers to the gap then scribe the tubing keep your dividers square to the axle housing ..... DONT WELD IT ALL AT ONCE weld 1" sections and jump around so you dont bow the axle tubes
[Re: 8urvette]
#1065272
02/23/15 02:04 AM
02/23/15 02:04 AM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
here's a pic of mine. was in a trans brake turbo car. 3600 lbs. started shearing pinion gear stems when the car was going hi 9s. Never had failures except for shearing pinion gears.
