Re: E85, Alcohol, Or Racing gas.. [Re: MegaDart] #1062548
08/26/11 10:47 AM
08/26/11 10:47 AM
Johnstown
69dart Offline
69dart  Offline
Johnstown
I'm sticking with E85. I ran gas for years but after running E85 for few years now I'm not going back. I've torn down my engines after running gas and the valves and pistons would be covered with carbon build-up. On E85 everything still looks new, the oil stays cleaner and you never have to worry about the engine getting too HOT when double entered.
Racing gas around here is about $7 per gallon vs $3.15 for e85. I made a ton of 1/8 mile runs this past weekend double entered and averaged about 1/2 gallon per run for the weekend.
I always liked the smell of racing gas but I dont like how your clothes smell if you just walk in the trailer or garage. The fumes seem less obtrusive to me. The only down side I've found with E85 is cold starts. If its cool outside its takes forever to fire up for the 1st start of the day. I've learned by giving a couple shots of Starting Fluid it will take right off and save your starter.
One interesting thing I heard this weekend from a guy running Alky. He said he gets his Alky from the hospital. Says they use it to cool and clean imaging equipment. Apparently they'll sell it for around $70 or 80 per drum. Thats really cheap fuel.
33 Plymouth Roadster - 383 - 5.90 1/8th 9.58 1/4
68 Dart - 340
66 Belvedere - 400
Windy Hollow Garage - https://www.youtube.com/@windyhollowgarage
Re: E85, Alcohol, Or Racing gas.. [Re: 69dart] #1062549
08/26/11 11:17 AM
08/26/11 11:17 AM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
You can buy alcohol most anywhere,but there are 2 grades you want the 99.9% for your race-car.The lower grade is for industrial use,mostly for cleaning. I do not remember what percent it is,but the 99.9% is pure alcohol and that's the one you want.Most places sell both grades,I have been told the industrial grade is refined alcohol.
PS what the Hospital use's may not be the 99.9% if it is it will say it on the drum.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: E85, Alcohol, Or Racing gas.. [Re: dartman366] #1062550
08/26/11 02:38 PM
08/26/11 02:38 PM
Northeast Georgia
47hudson Offline
47hudson  Offline
Northeast Georgia
Either way you go just make sure your fuel supply is up to snuff. Both are going to require more fuel volume than gas.
Re: E85, Alcohol, Or Racing gas.. [Re: MegaDart] #1062551
08/26/11 03:58 PM
08/26/11 03:58 PM
NC
440Jim Offline
440Jim  Offline
NC
My Dart runs 5.2x/8.2x and uses approx. 1gal for 1/8mile pass including all warmups, driving up and back, etc.
1/4mile uses approx. 1.5gal. With a Rupert 1250cfm.
Injection will double your fuel consumption.
That is a good example.
Everyone's setup will differ.
I have gotten better at conserving fuel with my Ron's injection system. So it isn't double a carb, but often people will burn more injected than using a carb. From what I have seen, you burn as much driving in the pits as going down the track. But with a carb or leaning the injection (or the primer plus system), it cuts it way back.
I was burning 0.7 gal/run with race gas.
I was burning 1.5 gal/run with methanol. And 1 gallon warm-up for the beginning of the day.
I was burning 1.0 gal/run with E85.
But now I have it down better driving in the pits and at the last few 1/8 mile races (1/4 mile track and still a long drive in the pits), I am only burning 0.8 gal/run with E85.
My friend's 493 CID little 1980's Charger was recently switched to a borrowed alcohol carb and he is only burning less than 1.0 gal/run (1/8 mile). It runs 5.7/9.1
Re: E85, Alcohol, Or Racing gas.. [Re: 440Jim] #1062552
08/27/11 04:12 PM
08/27/11 04:12 PM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
I have not done the math, but I am sticking with 110 race gas. I only make 50 passes a year. Besides, that E85 stuff smells like buttered popcorn, and makes me want to have a beer.
Re: E85, Alcohol, Or Racing gas.. [Re: cgall] #1062553
08/27/11 04:34 PM
08/27/11 04:34 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I switched over to E-85 for 2 reasons... ease of
getting the stuff(3 miles away) and the cost...
112 octane was 9.xx a gal VS 3.15 or so (and thats
up when I first changed over)... side binnies are that
it runs cooler and it didnt slow me down at all and
runs more consistent
Re: E85, Alcohol, Or Racing gas.. [Re: MR_P_BODY] #1062554
08/28/11 06:52 PM
08/28/11 06:52 PM
Mt. Vernon, Ohio
dartman366 Offline OP
Mt. Vernon, Ohio
Hey Jim, love the new sig pic!!
Re: E85, Alcohol, Or Racing gas.. [Re: dartman366] #1062555
08/28/11 08:05 PM
08/28/11 08:05 PM
Tennessee
steeldust Offline
steeldust  Offline
Tennessee
Hey MR P & 440 JIM will FRIDAY night i t.t my car with the new DOMINATOR that RUPERT made for my car 1st pass 6.07 at 117 2nd 6.05 at 117 3rd 6.04 at 117 4th 6.00 at 118 5th 6.00 at 118 looking good will for the race SATURDAY 6.05 at 118 2nd 6.04 at 118 3rd 6.02 at 118 i was thinking man that`s just right for the 1st round will BRAD said it`s cool down a lot it`s going to run will i said ok maybe a 6.01 or a 6.00 man was i wrong the car pull the wheels up i had a 0.24 R.T to his 0.89 R.T and i was gone about 50 or 60 feet from the line i let off and i lost i went 5.98 at 110 BRAD was right in good air the will go 5.80s maybe 5.70s like it is i am going to do some jetting an put some more weight in man that DOMINATOR is what my motor likes i was letting you all know how it`s running and it is useing about 3/4 a gallon with a small burn out and about 1 gallon with a big burn out.
Re: E85, Alcohol, Or Racing gas.. [Re: steeldust] #1062556
08/28/11 09:46 PM
08/28/11 09:46 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
Steeldust, are you going to Bristol next week end for the MOPAR race?
Re: E85, Alcohol, Or Racing gas.. [Re: Dabee] #1062557
08/28/11 10:57 PM
08/28/11 10:57 PM
Tennessee
steeldust Offline
steeldust  Offline
Tennessee
I am going to try to but i went to 411 last week at their new heads up race and i raced Friday night and Saturday at the bounty at I-40 if i don`t go and race i will come Saturday and stay all day and see what is going on . Are you going? Hey 411 is having real good heads up racing ever month .
Re: E85, Alcohol, Or Racing gas.. [Re: steeldust] #1062558
08/29/11 09:32 AM
08/29/11 09:32 AM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
Yes, I am going all three days. I'm going to try to m ake it over to I-40 in Oct. Sept is booked up with family stuff.
Re: E85, Alcohol, Or Racing gas.. [Re: steeldust] #1062559
08/29/11 10:12 AM
08/29/11 10:12 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I did some jet work on mine(1050 dom) and I found
that I need 2 jet sizes higher to run in the summer
heat... if I raced in the cooler weather I would
need 2 more sizes up
