Page 45 of 55 1 2 43 44 45 46 47 54 55
Re: I'm back with a new Mopar project! [Re: all spooled up] #1061913
09/28/14 11:28 AM
09/28/14 11:28 AM
Tampa
DusterDave Offline OP
Tampa
looks good ? does it fit in your garage with out letting air out of the tires
I didn't have to touch the tires. After we installed the cage in the driveway, we rolled the Jeep back in, and I noticed about 2" of clearance between the top of the cage and the bottom edge of the garage door.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: I'm back with a new Mopar project! [Re: all spooled up] #1061914
09/30/14 10:08 AM
09/30/14 10:08 AM
Orlando Florida
blown572dart Offline
Orlando Florida
Looks great
Re: I'm back with a new Mopar project! [Re: blown572dart] #1061915
09/30/14 11:39 PM
09/30/14 11:39 PM
Lehigh Acres, Florida
rickstershemi Offline
Looks great
WOW.....A Blast From The Past .... Howdy Jimmy
Rickster
Re: I'm back with a new Mopar project! [Re: rickstershemi] #1061916
10/01/14 07:36 PM
10/01/14 07:36 PM
Tampa
Tampa
Thanks, Jimmy!
Since the dreaded wiring work will be dealt with soon, I ordered a Weatherpack connector kit. Deutsch connectors are indeed nicer, but the Weatherpacks fit my budget better. I did spring for the proper crimping tool, at least.
Re: I'm back with a new Mopar project! [Re: DusterDave] #1061917
10/02/14 03:29 PM
10/02/14 03:29 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
Nice kit! Where did you pick that up?
Re: I'm back with a new Mopar project! [Re: Jwilli500] #1061918
10/02/14 08:40 PM
10/02/14 08:40 PM
Tampa
Tampa
Re: I'm back with a new Mopar project! [Re: DusterDave] #1061919
10/03/14 03:21 PM
10/03/14 03:21 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
Thanks Dave!
Re: I'm back with a new Mopar project! [Re: Jwilli500] #1061920
10/04/14 11:54 PM
10/04/14 11:54 PM
Tampa
Tampa
I took the first step in the wiring job by mounting the fuse panel. I would have connected those wires to the ignition switch, but I'll first need to purchase a crimper that can make F-type crimps.
Re: I'm back with a new Mopar project! [Re: DusterDave] #1061921
10/06/14 11:09 PM
10/06/14 11:09 PM
Tampa
Tampa
Yesterday, I sprayed the rear bumper assembly and the inside of the tailgate with Monstaliner. I didn't install the tailgate yet, because I still need to do a cut and buff on the paint.
Re: I'm back with a new Mopar project! [Re: DusterDave] #1061922
10/08/14 10:18 PM
10/08/14 10:18 PM
Tampa
Tampa
Weatherpack 22 pin bulkhead connector. This will mount in a hole on the firewall.
Re: I'm back with a new Mopar project! [Re: DusterDave] #1061923
10/11/14 03:38 PM
10/11/14 03:38 PM
Tampa
Tampa
While I'm waiting for the postman to deliver my Type B terminal crimper today, I wanted to get busy with something in the meantime. So, after doing the cut 'n buff on the tailgate this morning, I installed it........FOR THE LAST TIME!!
Re: I'm back with a new Mopar project! [Re: DusterDave] #1061924
10/19/14 12:54 PM
10/19/14 12:54 PM
Tampa
Tampa
After giving it much thought, I decided where to install the bulkhead connector.
I made a bracket to help support the group 65 battery tray. I made it multi-functional by adding a flat space on top to mount electrical components. I mounted a heavy duty bus bar down below, which will be a 12 volt power source for the winch, stereo system, etc.
This twin bus bar will be mounted behind the dash. This will provide a central place for a ground, and for a switched power source.
Re: I'm back with a new Mopar project! [Re: DusterDave] #1061925
10/19/14 08:15 PM
10/19/14 08:15 PM
LQQKS AWESOME Dave....battery support sounds familiar....LOL What's the forecast for the first spin...????? I'm gonna have to plan a trip and go for a ride in that puppy
Rickster
Re: I'm back with a new Mopar project! [Re: rickstershemi] #1061926
10/20/14 12:08 AM
10/20/14 12:08 AM
Tampa
Tampa
I'm hoping to have it ready to drive by late December. My birthday is the day after Christmas, so that would be a nice present to myself.
Re: I'm back with a new Mopar project! [Re: DusterDave] #1061927
10/22/14 12:53 AM
10/22/14 12:53 AM
Tampa
Tampa
I got the starter relay mounted in an out of the way spot, close to the starter, yet accessible. It's ugly, so I didn't want it in plain sight. It's pretty much wired up, except for the main positive battery cable and a couple hex nuts. In order to cut the positive battery cable to the proper length, I'll need to know which side the positive post is on, which means I'll need to buy the battery.
The winch is wired up, and I ran the main alternator feed wire. I purchased a voltage regulator kit, complete with harness. Hopefully it will arrive by Friday or Saturday, so I can get that bit squared away. I know this doesn't seem like much, but since I'm not electrically inclined, each connected wire and each installed component is a little victory.
The Autometer 3-3/8" GPS speedo came in today. It has a lot of neat features. For instance, if I ever get stuck out in the middle of Moab, it can tell me what my coordinates are, and my heading. I can relay that information with my CB to a search party, and when they find me, they can load up my bones in a box and ship me home.
Re: I'm back with a new Mopar project! [Re: DusterDave] #1061928
10/22/14 11:48 PM
10/22/14 11:48 PM
If I didn't know better....I might be concerned about the starter solenoid getting submerged and failing..... triggering loss of power and no GPS Coordinates to send to the Publix Bag Crew for your imminent rescue......Sorry Had too
Love the Crap outta that Jeep
Rickster
Re: I'm back with a new Mopar project! [Re: rickstershemi] #1061929
10/26/14 09:53 AM
10/26/14 09:53 AM
Tampa
Tampa
Rickster
Rick, the bottom of the starter relay is 36" off the ground. I highly doubt I'll ever encounter a 36" puddle in a mall parking lot!
Re: I'm back with a new Mopar project! [Re: DusterDave] #1061930
10/26/14 09:55 AM
10/26/14 09:55 AM
Tampa
Tampa
Making progress on the wiring. The voltage regulator is installed and wired up, and the alternator is wired up, but I decided to increase the output cable size from 8 AWG that came with the kit to 6 AWG fine strand cable. I have a 120 amp alternator, and 8 gauge wasn't going to cut it. I ordered the 6 gauge cable and lugs online, and they should get here by midweek.
I added Weatherpack connectors to the stop-turn-tail lights, the reverse lights, and the front side markers.
The headlight switch is wired up. As I was routing the headlight wires to the front yesterday, I thought about using the two wires (hi-beam and low-beam) as activation wires for headlight relays. So, this morning I did some searching online, and found this really well built headlight relay kit.
http://www.ceautoelectricsupply.com/h4headlightrelaykits.html
It will allow full battery voltage to be sent directly to the headlights, resulting in maximum brightness. Uses nice quality Hella waterproof relays. While its not cheap, I think its a good investment, and I don't mind paying a little more for safety related stuff. While I'm at it, I'm also going to upgrade to H4 headlights.
Re: I'm back with a new Mopar project! [Re: DusterDave] #1061931
10/28/14 06:53 AM
10/28/14 06:53 AM
Q
Quicktree Offline
Quicktree  Offline
Q
Dave what lock device is that on your spare tire rack, I need to build one for mine? are you still in Florida I would love to see your jeep when you finish.
Re: I'm back with a new Mopar project! [Re: Quicktree] #1061932
10/28/14 01:30 PM
10/28/14 01:30 PM
Tampa
Tampa
Actually, I don't have a locking device for my spare tire, yet. I'll need to look into that.
Yes, I'm still in Tampa. If you're ever in the Tampa area, you're welcome to swing on by JeeperDave Trailsports, Inc. (aka, my two car garage. )
