Re: Heat/ Cooling Issue on B-Body [Re: 6bblFLASH] #1060741
08/28/11 11:40 AM
08/28/11 11:40 AM
N.E. Ohio
6bblFLASH Offline OP
N.E. Ohio
Pic 1
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: Heat/ Cooling Issue on B-Body [Re: 6bblFLASH] #1060742
08/28/11 11:41 AM
08/28/11 11:41 AM
N.E. Ohio
N.E. Ohio
Pic 2
Re: Heat/ Cooling Issue on B-Body [Re: 6bblFLASH] #1060743
08/28/11 11:42 AM
08/28/11 11:42 AM
N.E. Ohio
N.E. Ohio
Pic 3
Re: Heat/ Cooling Issue on B-Body [Re: 6bblFLASH] #1060744
08/28/11 11:42 AM
08/28/11 11:42 AM
N.E. Ohio
N.E. Ohio
Pic 4
Re: Heat/ Cooling Issue on B-Body [Re: 6bblFLASH] #1060745
08/28/11 11:43 AM
08/28/11 11:43 AM
N.E. Ohio
N.E. Ohio
Glamour Shot
Re: Heat/ Cooling Issue on B-Body [Re: feets] #1060746
08/28/11 12:28 PM
08/28/11 12:28 PM
State of Fascism
52savoy Offline
52savoy  Offline
State of Fascism
Thermal. Copper. Green. Shroud. 180 superstat.
Dennis, you are one of the most annoying people on this site.
Did you look at the photos? Did you see the blower snout? Did you see the blower tensioner pulley that would contact a fan clutch?
Simply annoying.
Re: Heat/ Cooling Issue on B-Body **UPDATE** PIC`s [Re: 6bblFLASH] #1060747
08/28/11 12:38 PM
08/28/11 12:38 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I'm looking and the photos won't 100% confirm it but to me it looks like theres a good amount of space between the alternator belt & the blower belt..... As long as there is nothing the photos don't show I'd look at shortening the blower snout, tensioner & crank pulley...
Re: Heat/ Cooling Issue on B-Body **UPDATE** PIC`s [Re: 1_WILD_RT] #1060748
08/28/11 03:00 PM
08/28/11 03:00 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Not a bad idea, B&M or someone like that should offer drive options.
Or use a manifold that moves the blower back some.
Re: Heat/ Cooling Issue on B-Body **UPDATE** PIC`s [Re: Challenger 1] #1060749
08/28/11 03:29 PM
08/28/11 03:29 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
It wouldn't take much to modify the parts he has.. A little machine work, a little welding... A BFH..
Re: Heat/ Cooling Issue on B-Body [Re: 6bblFLASH] #1060750
08/28/11 06:28 PM
08/28/11 06:28 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
awsome!you did not even have to move the rad. to move the blower back a 1/2" plate with studs for the blower and countersunk screws to the intake will move it back for you.if you have a scrap yard near you thay may have the aluminum or the contacts to get some scraps to do it but for now enjoy it before the snow comes!
Re: Heat/ Cooling Issue on B-Body [Re: Clanton] #1060751
09/06/11 08:34 AM
09/06/11 08:34 AM
N.E. Ohio
N.E. Ohio
Well I now have it cooling the way I`d like.
The pulley ratio was 3% UNDER-driven
So i made a pulley out of 2 cut/weld and now have 17% over-driven ratio.
That did it. Let it idle for 10min.s after a hard drive. Never topped 180*
Re: Heat/ Cooling Issue on B-Body **UPDATE** PIC`s [Re: 6bblFLASH] #1060752
09/06/11 09:56 AM
09/06/11 09:56 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
good to hear! so now the pulley is about 4.5"?
Re: Heat/ Cooling Issue on B-Body **UPDATE** PIC`s [Re: Clanton] #1060753
09/06/11 06:13 PM
09/06/11 06:13 PM
N.E. Ohio
N.E. Ohio
Top pulley 6-1/8th OD. Crank is 7-1/8th.
Using my math is 16.35% over-driven.
Re: Heat/ Cooling Issue on B-Body **UPDATE** PIC`s [Re: 6bblFLASH] #1060754
09/06/11 07:24 PM
09/06/11 07:24 PM
Yep correct, I assumed earlier (incorrectly) that he had a 7&1/4" crank pulley
Re: Heat/ Cooling Issue on B-Body [Re: JohnRR] #1060755
09/06/11 09:18 PM
09/06/11 09:18 PM
Spring, TX
70cudaproject Offline
Spring, TX
I would ditch that flex fan and mount the electric fans in front of the radiator .
Why not mount an electric fan with a thermostat between the engine and radiator? That way when it gets hot the fans can run at whatever speed they need to to keep it cool - even when the engine is at idle. Better yet it frees up some parasitic lose due to the mechanical fan (or at least transfers it to the alternator). BTW you can find some inexpensive fans that are slim off newer vehicles, and I like the thermostat controlled ones the best.
Re: Heat/ Cooling Issue on B-Body [Re: 70cudaproject] #1060756
09/06/11 09:20 PM
09/06/11 09:20 PM
Spring, TX
Spring, TX
...OR I should read further and see you fixed your problem.
