440 in a '56 dodge help? Anyone done it? #1060708
08/23/11 10:57 PM
08/23/11 10:57 PM
Buckeye Lake
56_Royal_Lancer Offline OP
My Mouth Is Shut II
My Mouth Is Shut II
Buckeye Lake
Well, I am going for it, putting a 440 in my '56 Dodge. Who here has done it, and what advice can you offer? I remember a guy on here with a 440 in a '56 Plymouth. You out there, brother?
Re: 440 in a '56 dodge help? Anyone done it? [Re: 56_Royal_Lancer] #1060709
08/25/11 08:20 AM
08/25/11 08:20 AM
Marysville, OH
Marty cRUIZer Offline
Marysville, OH
I have haven't done it or know anyone that has, but it sounds like a kool project!! Keep us posted!
Marty
Marysville, OH
Re: 440 in a '56 dodge help? Anyone done it? [Re: Marty cRUIZer] #1060710
08/25/11 10:21 AM
08/25/11 10:21 AM
NEW JERSEY
dynamite Offline
dynamite  Offline
NEW JERSEY
Yeah I'm here..biggest problem was the drivers side headers...I'll try to post some pics...It's now a 493 stroker
Re: 440 in a '56 dodge help? Anyone done it? [Re: 56_Royal_Lancer] #1060711
08/25/11 10:29 AM
08/25/11 10:29 AM
NEW JERSEY
dynamite Offline
dynamite  Offline
NEW JERSEY
I'm not a computer guy ,,I know I have pics of the install but can't find them..If you want to you could call me for more info..I at first put the motor in the stock chassis,get rid of the heater box and move the battery to the trunk,just for the room.Later I put the Volere,Aspen type front end in..actually from a Chrysler 5 th ave..great install and nice ride but the P/S box screwed up the headers, you can see the disc brake caliper in this picture..772-335-2709 Larry..the car ran a consistant 12.5 with a mild 440, with 906 heads..727 trans and an 8 3/4 rear.3;91 gears..will find out soon times with the 493...a lot stronger
Re: 440 in a '56 dodge help? Anyone done it? [Re: 56_Royal_Lancer] #1060712
08/25/11 10:41 AM
08/25/11 10:41 AM
NEW JERSEY
dynamite Offline
dynamite  Offline
NEW JERSEY
try to send more pics
Re: 440 in a '56 dodge help? Anyone done it? [Re: 56_Royal_Lancer] #1060713
09/04/11 01:46 AM
09/04/11 01:46 AM
Oklahoma City, OK
moposcar Offline
moposcar  Offline
Oklahoma City, OK
I Put a 383 with a 727 in a 56 Coronet 4 door. I cheated though and used a fat man fab front end. I put A/C in the car, so had to weld up the firewall. I also had to run an electric fan. I used the original radiator but put the fan as a pusher in the front. I had to massage the tunnel a bit, and I put in a B&M shifter for the trans.
I was able to use the origianal trans crossmember, I just took an old e-body cross member that was in bad shape and cut the mounting lug off of it. I then welded it to the original cross member. I have about a half inch between the Passenger side head and the firewall.
Re: 440 in a '56 dodge help? Anyone done it? [Re: moposcar] #1060714
09/04/11 03:08 PM
09/04/11 03:08 PM
Buckeye Lake
My Mouth Is Shut II
My Mouth Is Shut II
Buckeye Lake
Good tip on the crossmember. I was just given a FREE 5th Avenue so it looks like I'm going to clip it with the 5th Ave. subframe. I'll post updates as things progress.
Re: 440 in a '56 dodge help? Anyone done it? [Re: 56_Royal_Lancer] #1060715
12/04/11 05:34 AM
12/04/11 05:34 AM
Sorrento, BC, Canada
4speeds4me Offline
4speeds4me  Offline
What did you decide, Mike? I have a 56 2-door HT in the shop I'm thinking about doing this to. Got a line on a couple 56 Plymouths now too. It's a disease, I tell ya, a disease!
2 Demons...no, not my kids!
Re: 440 in a '56 dodge help? Anyone done it? [Re: 4speeds4me] #1060716
12/04/11 12:07 PM
12/04/11 12:07 PM
Buckeye Lake
My Mouth Is Shut II
My Mouth Is Shut II
Buckeye Lake
Decided to stick with the stock frame/suspension (a few details on the other thread). If you are planning a similar swap I should have details about the engine plate, headers, etc after 1/1/12. Once I find out exactly what works I will pass along the info. In fact, I plan on making a template of the engine plate for anyone else that is interested in going this route.
Re: 440 in a '56 dodge help? Anyone done it? [Re: 56_Royal_Lancer] #1060717
03/11/12 12:20 AM
03/11/12 12:20 AM
OHIO
THE GLASS MAN Offline
OHIO
so how is the new project going?
Re: 440 in a '56 dodge help? Anyone done it? [Re: THE GLASS MAN] #1060718
03/11/12 08:42 PM
03/11/12 08:42 PM
Buckeye Lake
My Mouth Is Shut II
My Mouth Is Shut II
Buckeye Lake
Fire in the hole! Got the 440 running for the first time this afternoon. Sounds gooood, it's uncapped right now. Rear is in, brakes done, a little final wiring, tweak this, seal that and we are ready for an exhaust system. Then it will be time for a little
Re: 440 in a '56 dodge help? Anyone done it? [Re: 56_Royal_Lancer] #1060719
03/11/12 09:45 PM
03/11/12 09:45 PM
Redwood City Ca.
B1arno Offline
B1arno  Offline
Redwood City Ca.
Very cool! You're moving pretty fast on it. When will we see some pictures?
Re: 440 in a '56 dodge help? Anyone done it? [Re: B1arno] #1060720
03/11/12 10:12 PM
03/11/12 10:12 PM
Buckeye Lake
My Mouth Is Shut II
My Mouth Is Shut II
Buckeye Lake
I've been taking pictures and keeping part #s, but between work, life and this project I have not had time to post much. When the car is done I plan on starting a new thread with details.
