Re: Getting sick of the stroker - question about downsize
[Re: ahy]
#1059509
08/22/11 10:39 PM
08/22/11 10:39 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
I'll trade you my 360 cu. in. rotating assembly for your 408 cu in rotating assembly. you keep your block, heads, cam, etc. and I'll keep my block heads and cam (magnum vs presumably, an LA based build on your end?) you'll get streetability of a stock stroke engine, I get a 408. win-win!!! (my 360 magnum is fresh, zero miles)
**Photobucket sucks**
[Re: stumpy]
#1059513
08/23/11 08:12 AM
08/23/11 08:12 AM
Posts: 1,322 Michigan
crlush
Recam and detune the stroker. Unless you are running huge compression it's just a bigger cube engine in the long run.
[Re: wally426ci]
#1059515
08/23/11 02:22 PM
08/23/11 02:22 PM
Posts: 27,554 So Cal
autoxcuda
So Cal
It definitely helps me to get feedback from everyone.
I will openly take recommendations on cam specs here. I went from a Racer brown cam to a Comp cam. I hear good things about Lunati.
I like the sound of keeping my existing parts for the most part.
I think you need to state exactly what cam you have now to use as a benchmarks of what you don't want.
Still, this is all assuming the car has some decent tune right now. And that it's the cam that's making it rough as opposed to a bad tune, bad part, or something that needs to be repaired.
[Re: rapom]
#1059518
08/23/11 06:31 PM
08/23/11 06:31 PM
Posts: 2,849 Connecticut
FurryStump
Connecticut
Jeff Patterson built me a nice mild 408 stroker (.484 lift) for my 68 Charger. It is the wifes car so it had to be street friendly. I run A/C, and Power Steering, a nice street friendly edelbrock 800 and it only has a 2.94 gear. I took it to the track once and got a 13.28 out of it. I think it would run a 12.90 if I worked at it. Starts up nice in the cold and doesn't have a rich exhaust smell. Drove it up to the Woodword Dream cruise from Ohio and at 70mph, it was at a reasonable rpm. Keep your engine and change the cam and a few other things and you will enjoy the torque.
Just put in a soild lifter cam from him, very happy,very nice guy
[Re: FurryStump]
#1059519
08/24/11 11:06 AM
08/24/11 11:06 AM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
Maybe you just need a real good tune on it.
Maybe pitch that 750 for a better design. Never read about anyone happy with them. 800AVS?
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
[Re: b5a12bee]
#1059521
08/25/11 11:52 AM
08/25/11 11:52 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
yeah, most people suggest too much duration for a stroker that is going to be used on the street, IMHO
dump the 750 eddie, I'd go with an 800 eddie, or a demonsizzler built t-quad. I know on my 360, I gained a ton of drivability and 2" of idle vaccuum switching from the 750 eddie to a 600. there's a lot of info on the web of people never getting the 750 to run good...sounds like there's a flaw in the design of the internal passages of that carb
intake, Eddie RPM or air gap for a square bore carb, probably a eddie LD340 modded for the t-quad, if you can't find one, probably a weiand action plus, or maybe an M1 single plane (hard to find good spead bore mopar intakes)
for a cam, I'd use the lunati voodoo 60403 if you want to stick to a flat tappet.
fresh heads, a good 5 angle VJ, maybe some home porting opening up the bowls and pushrod pinch
should have a very strong, yet mellow engine that should idle at 800 RPM with probably 14" vaccuum
[Re: 75DART440]
#1059523
08/26/11 11:53 AM
08/26/11 11:53 AM
Posts: 2,554 Maryland
wally426ci
Maryland
Too funny. I am years away from taking it off the road as our 2nd daughter is due in October. I am leaning toward downsizing the carb, changing heads, cam, converter. Right now I am running a 68 340 cast iron intake.
[Re: wally426ci]
#1059524
08/26/11 10:50 PM
08/26/11 10:50 PM
Posts: 181 Kansas
Menzaero
Kansas
Keep the stroker - I have a mild 418 in my Dart with good performance and 14 to 15 MPG if I keep my foot out of it crusing around town. 10.1 CR (Ross 16cc Dish Pistons) 800 AVS Edelbrock on a Performer RPM X-Heads (69.3cc) and stock exhaust XE 274H Comp Cam (230/236 - .488/.491) 3:55 Gear Here is a Youtube link - http://www.youtube.com/watch?v=DrKBbVmQVf0
[Re: wally426ci]
#1059525
08/26/11 11:41 PM
08/26/11 11:41 PM
Posts: 7,664 IN
ahy
IN
Too funny.
I'm just curious... what is the issue with the heads? What's the benefit of changing?
[Re: ahy]
#1059526
08/27/11 01:47 AM
08/27/11 01:47 AM
DaytonaTurbo
Manitoba, Canada
I want to know as well. Heads won't make that much difference on the final driveability you seek.
I agree with everyone else, you need to pick a proper cam, install and degree it and you should be fine. I drove my 440 car everywhere before I pulled it apart and it was no problem.
