Re: !!!Broke my auto trans tail shaft!!!! what cause it
[Re: Dart1031]
#1058757
08/22/11 10:40 AM
08/22/11 10:40 AM
Posts: 12,041 Finally a HUSKER again
Moparnut426
Am I seeing things, or is the bushing in that mount junk?
I agree, Looks like all the weight is smashing it down almost grounded to the bolt going through it.
That could be it. If its a motor plate car, its putting stress everywhere.
Kasey
[Re: dennismopar73]
#1058762
08/22/11 12:30 PM
08/22/11 12:30 PM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
I thought if you ran solid engine mounts you had to have a solid trans mount?
67' charger 499 RB
10.57 at 127
[Re: dragram440]
#1058763
08/22/11 12:41 PM
08/22/11 12:41 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I sure wouldnt... reason why is flex in the car... if you have 2 points solid (now thats a straight line) it can pivot BUT if you have a front plate, mid plate and a solid trans mount, now you have 3 points which doesnt mean its still a straight line, specially when you induce flex... I always use a rubber trans mount and I have never broke a tail shaft.... some guys use the solid trans mount as a engine limiter... I prefer to put a engine limiter on the engine(I happen to use 2 of them)
[Re: rickraw]
#1058766
08/22/11 07:42 PM
08/22/11 07:42 PM
Posts: 694 Michigan
Super Scamp
With mulitable good answers on this post, I'm going to throw my in the mix. 1. you see the shaft and the cast aluminum is almost completely sheered off in a complete circle. 2. stress from the axle twist in the upward movment pulling the drive shaft out of the trans as the motor is twisting the tork monster. 3. Time for a front plate, or solid mounts. 4. Poloy mount on the trans. 5. Snubber on the twisting 8 3/4 I have see a friend break his tale shaft in the speed "O" area and he locked up his trans and hurt the 8 3/4 to the ponit of putting in a Dana, and 2500 dollar trans.
Just One Man's Opinion
Mopar Mafia Racing
[Re: Super Scamp]
#1058767
08/22/11 08:22 PM
08/22/11 08:22 PM
Posts: 4,027 Dearborn Hts, MI
Sledge_57
Dearborn Hts, MI
Have that DS checked again. When I broke mine it was "supposedly" good too. Brand new from Mancinis balanced and all.
After it took out the tailshaft housing I took my shaft to a GOOD DS shop (Dynotech) not only was my "NEW" DS not balanced worth a damn, it was bent like a banana.
Doug
1967 "Pedal Car" 500" low deck , TF 727, 4.30 Locker Best to Date: 11.67 @ 114.9 1.64 60ft
"Kids in cars cause accidents. Accidents in cars cause kids..."
[Re: mopar65]
#1058771
08/22/11 09:28 PM
08/22/11 09:28 PM
Posts: 6,780 Alabama
Mopar-Al
Alabama
Just to clarify the wording a bit more here. You pushed the yoke into the tailshaft all the way and then pulled it out 1 inch for clearance? As Mr P had said, it needs 3/4 inch to travel. not 1 inch sticking out. If you didn't have this travel, it will bind and break. Many a person has fallen to this mis hap before. [/quote
I guess i am not following what you are saying. but yes if i remember right.i pushed the yolk in all the way and pulled it out a inch and then measured for my drive shaft lenght. are you saying that was the wrong way of doing it? if so what is the right way? thanks mopar65
that's the right way
[Re: Mopar-Al]
#1058772
08/22/11 10:22 PM
08/22/11 10:22 PM
We had our first break like that in a car with elephant ears, stock trans mount, etc and when we finally welded in a limiter to control fore and aft movement of the engine it never happened again--just my 2 cents worth--good luck getting her fixed
[Re: Sledge_57]
#1058773
08/22/11 11:30 PM
08/22/11 11:30 PM
Posts: 1,090 Saskatchewan, Canada
barracudabob
Exactly the same thing happened to me. I bought a really good (expensive) driveshaft. Second run, broke the tail housing. Sent the driveshaft to a driveline shop, and it was bent, and poorly balanced. They rebalanced and straightened it, no more problem.
[Re: MR_P_BODY]
#1058776
08/23/11 01:24 AM
08/23/11 01:24 AM
Posts: 2,537 PORT ALBERNI , BC., CANADA
superwrench
Solid mount the engine...but never solid mount the trans...use the Poly bushings. Something needs to give a bit.
