Any reason NOT to use SB chain tensioner? #1057951
08/20/11 03:09 PM
08/20/11 03:09 PM
Belle Mead, NJ
65Frank Offline OP
super street
65Frank  Offline OP
super street
Belle Mead, NJ
I'm in the process of putting a new timing chain in my 65 Poly and I was planning to use a chain tensioner. Are there any issues with these (plastic slides breaking, excessive chain wear, etc) or am I just being anal? I'm going with a double roller chain if that makes a difference.
Frank
Re: Any reason NOT to use SB chain tensioner? [Re: 65Frank] #1057952
08/20/11 05:00 PM
08/20/11 05:00 PM
ST clair shores MI
moretoys Offline
moretoys  Offline
ST clair shores MI
My buddy uses one,but he races his car,see's 6500-6800 rpm.stroked 340, w-5 head runs low 10's.They do come apart after about a year or so.we figure it's the rpm that are killing these so soon.These are factory chrysler parts.The factory does use them also,They wear out and break too,but it's usually alot of miles.The only way we know they break is by changing the oil and the tension springs are on the drain plug.(A magnetic drain plug)May of 2010 we replaced it and june of this year it's broke again.Got the broken peices out,running the car as is.timing has had no change.Will it last ?? Do they break-yes
Re: Any reason NOT to use SB chain tensioner? [Re: 65Frank] #1057953
08/20/11 08:26 PM
08/20/11 08:26 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Ran one for 300+ passes 6500+ rpm and some street driving no proplems. Thought about using it again on a freshen-up but for 38 bucks just bought a new one.
"Just a Bracket car dressed up like a streetcar"
Re: Any reason NOT to use SB chain tensioner? [Re: Just-a-dart] #1057954
08/20/11 10:03 PM
08/20/11 10:03 PM
dogdays Offline
dogdays  Offline
It's a great idea, most chain driven overhead cam engines have them with the plastic slides and they last for 100K or so. On your LA motor they'll keep the chain tight even when it starts to wear and get longer.
One thing I discovered, when I bought mine for the roller 318, was that they are not strictly a Mopar part. You can get them in Cloyes boxes, and another brand or two as well. They all look the same to me. Check Rock Auto to see what I mean.
I wonder if they have enough travel to tighten a stock length chain on a block with line-honed mains?
R.
Re: Any reason NOT to use SB chain tensioner? [Re: 65Frank] #1057955
08/21/11 01:58 AM
08/21/11 01:58 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Frank
I really do not see the connection, plus we barely know you.
Re: Any reason NOT to use SB chain tensioner? [Re: Kern Dog] #1057956
08/21/11 04:44 AM
08/21/11 04:44 AM
5thAve Offline
5thAve  Offline
My 360 got a new timing chain around the time people were starting to talk about the tensioner and I asked about it and a lot of people said not to bother with it. I don't know if there was any real reason or it was because it was a new thing so people were scared of it??? Either way I didn't bother with it and with the limited use that car gets the timing chain will probably never wear out anyway.
Re: Any reason NOT to use SB chain tensioner? [Re: 5thAve] #1057957
08/21/11 11:53 AM
08/21/11 11:53 AM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
even a brand new chain will have a small amount of slack,if it didn't you would not be able to get it on.
The tensioner will take all that slack up for rock solid timing.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Any reason NOT to use SB chain tensioner? [Re: dusturbd340W5] #1057958
08/21/11 12:00 PM
08/21/11 12:00 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
I've had mine on for about 12k miles, no problems!! i do like how it has the tang to direct the oil on to the chain better, i also enlarged the oil hole on the attaching bolt.
Re: Any reason NOT to use SB chain tensioner? [Re: ademon] #1057959
08/21/11 01:59 PM
08/21/11 01:59 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
No personal experience with them.
I've read that you need to moly lube them on install so they don't get chewed up on initial start up, and that double rollers chew them up also. No smooth links on the outside?
Anyway, I'm sure you will get more replies.
Re: Any reason NOT to use SB chain tensioner? [Re: RodStRace] #1057960
08/21/11 07:00 PM
08/21/11 07:00 PM
Kissimmee Fl.
Kissimmee Fl.
I am running 1 on my Race motor with a double roller and last year swapped out the cam with a larger roller and the tensioner looked like brand new.I shift this thing at 7800 every time.
