Re: Design me a 3G Hemi bracket engine
[Re: Irun5snd8th]
#1057169
10/22/11 11:48 AM
10/22/11 11:48 AM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
Will the stock rockers/shafts off a 5.7 head, work on the 6.1 heads??
If you like drag racing, support your local track.
[Re: sixpackgut]
#1057171
10/22/11 01:11 PM
10/22/11 01:11 PM
Posts: 11,733 Portage,michigan
B3422W5
Portage,michigan
I got a price from Arrimgton on a complete 6.1 stroker using Manley rotating assy, Arrington rocker gear( super nice) a drag pack intake, and a little deal they make that mounts the coil packs on the intake. Cost for this fully machined and assembled motor was under 14k, and would be less with a shortblock core if one had one. So i gotta believe if Arrington can use good parts and build a complete motor for that kind of money with a trick cam, rocker gear, good internals, arp hardware and a drag pack intake somebody could do it themselves for a good bit less than that. If you consider the cost to build a 650 horse well built motor of any type, i didnt think it was all that bad. I am probabaly going to have 6-7000 in a 360 i am gonna do that might make 500 horse
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam, footbrake street/strip car Best so far, 10.32 1/4 1.41 best 60 foot 6.56 at 104.17
[Re: sixpackgut]
#1057172
10/22/11 01:11 PM
10/22/11 01:11 PM
CHAPPER
Belpre,Ohio
yes, they are the same. only thing different and i dont understand why they did this but the rocker shafts on a 6.1 doesnt have the sheetmetal spacer to keep the rocker located. they have some weird wire wrapped around the shaft that doesnt do squat
My 5.7 has the wire around the shafts,,,,wondered about the idea behind that as they are easily moved by hand with very little effort. Just wondered about the shafts, as I am thinking about going with the 6.1 head on this 5.7 I'm building. Thanks FRED
[Re: CHAPPER]
#1057173
10/22/11 04:07 PM
10/22/11 04:07 PM
Posts: 833 MN
hemidup
MN
The way the new Hemi's are designed, you really don't need those clips or spacer's. The pushrod angle will keep the rocker arm tight to the rockershaft holdown. When you want to spin these new Hemi's up and control oiling...? That's another story.
Jerry Williams.
[Re: hemidup]
#1057174
10/22/11 04:15 PM
10/22/11 04:15 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
So what is a safe rpm without oiling mode? 6500?
[Re: hemidup]
#1057177
10/22/11 09:23 PM
10/22/11 09:23 PM
MattW
Ontario Canada
Your safe at 6500 rpm. Above 7000 rpm is when you get into the pucker factor.
So my previous post about the oiling issue, am i close in thinking that at a higher rpm the oil is moving so fast that it has a hard time making the 90 turn at the mains? This is why the fist and last bearing are alright but the middle ones strave for oil. Or am I out in left field. BTW thanks for the info
[Re: MattW]
#1057178
10/24/11 10:20 AM
10/24/11 10:20 AM
Posts: 17,926 S.E. Michigan
ZIPPY
S.E. Michigan
The sheetmetal spacers and wire rings/clips are just assembly aids.
Rich H.
Esse Quam Videri
[Re: jg309]
#1057184
10/25/11 09:38 PM
10/25/11 09:38 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
converter does not "fit" into the back of my crank. there appears to be a reducer in the crank. does that easily come out? i couldnt get it easily out.
what do i need to do here?
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: jg309]
#1057185
10/25/11 09:41 PM
10/25/11 09:41 PM
sixpackgut
Charleston
you read one reply & presum something thats not even true, you need to read the whole post before making such a statement,jg309
if your friend can make money on the intake selling it for 500-550, maybe he should buy one to copy. i just dont think anyone would be willing to ship off $1000 and hope to see it again. nothing personal.
BTW, i will buy one when he starts pumping them out
[Re: sixpackgut]
#1057187
10/25/11 10:21 PM
10/25/11 10:21 PM
Posts: 3,354 ohio
HEMIDARTS
ohio
His "friend" as he calls him is well known in the MOPAR racing camp. His "friend" is named Kent Ritter. Kent is a good man, and knows his stuff. Kent is also making a damn nice block that is every bit as good or maybe better than the R3. Kent is not a big fan of the " internet ". Most people know Kent from when he was sponsored by MOPAR with the Daytona's. Im sure Kent is not trying to rip people off here. It sounds like he is trying to fill a void. MOPAR says they are not making more intakes, or very few. The way i see it, that is nice of Kent to try and help people out.
[Re: HEMIDARTS]
#1057188
10/25/11 10:39 PM
10/25/11 10:39 PM
Posts: 3,877 Smyrna, South Carolina
STEFF
I wonder if he plans to get Chrysler's permission to cast their manifold? I'm sure Chrysler wouldn't mind a royalty check.
