Page 7 of 31 1 2 5 6 7 8 9 30 31
Re: Design me a 3G Hemi bracket engine [Re: STEFF] #1057029
09/11/11 09:50 PM
09/11/11 09:50 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
Did anyone notice that they outfitted the 5.7 heads with 2.19 diameter intake valves?
What kind of heads did Jeff do for you Steff?
Alan Jones
Re: Design me a 3G Hemi bracket engine [Re: LA360] #1057030
09/12/11 09:24 AM
09/12/11 09:24 AM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
The 6.1's that came on my motor.
Re: Design me a 3G Hemi bracket engine [Re: STEFF] #1057031
09/12/11 04:20 PM
09/12/11 04:20 PM
IN
Irun5snd8th Offline OP
IN
Sounds like I will be making a call to BES. Steff, have you run yours yet?
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
Re: Design me a 3G Hemi bracket engine [Re: Irun5snd8th] #1057032
09/12/11 05:07 PM
09/12/11 05:07 PM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
Eric, maybe you will have better luck than I did with BES. they blew me off when I called. they told me to call there there other company HTTP or something that deals with all the 3G Hemi stuff.
I got the same crap from INDY all they wanted to do was send me a catalog.
I spent a good amount of $ on building my 6.1 stroker. None went to INDY or BES
IF you want to talk to one of the best guys in the business Call Jerry at Shardaon performance. He has helped me a ton. Always available for questions and he has built more 3G HEMIS than most of these other guys have thought about. He goes my " hemidup" on here
" gremlinsteve " and " Steff " " Zippy" are other sources that have first hand knowledge.
Re: Design me a 3G Hemi bracket engine [Re: 340RICK] #1057033
09/12/11 06:09 PM
09/12/11 06:09 PM
Dayton, Ohio
W
wldtm Offline
wldtm  Offline
W
Dayton, Ohio
I also talked to Jerry on the phone about a possible GT superstock gen 3 hemi engine, and was very informative and down to earth.
Justin
Interested in having you car wired? Drag car, street car, EFI swap? PM for details
Re: Design me a 3G Hemi bracket engine [Re: hemidup] #1057034
09/12/11 07:07 PM
09/12/11 07:07 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
The BES engine also used the older 5.7 Hemi heads. Take a look at the picture of the chamber and you'll see the quench pads. 5.7 Eagle heads don't have those. Also with our dyno testing our older 5.7 ported head made 30 hp/20 tq more than our ported 6.1's. Too many guy's get lost about cfm flow numbers and forget about port velocity.
I also agree with Zippy about CCV. I just picked up a set of those very rare 6.1 aluminum valve covers and plan to tig up some breathers on them. Just trying to figure out a design to put a baffle in them. I'm too cheap to buy the aftermarket taller one's. lol
Also, if there were oiling issues with the way these Gen III Hemi's are oiled, you would see the # 7/8 rods being taken out. Most failures are with the #5/6 and I have only seen 1 failure with the #3/4 and that was on Teuton's last weekend. I have my own theories as to why the center rod bearings are affected and after some more research, hopefully I can post up the fact's.
I could be wrong but the article shows a 5.7 eagle chamber head and they stated a late model head
Check it out. See the quench pads?
http://www.popularhotrodding.com/tech/1103phr_bes_417ci_gen_iii_hemi/photo_12.html
Here's a pic of the very first set of closed chambered Gen III Hemi heads we did back in 2006.
Not being an A- H$$$ but hear a picture of a eagle chamber I am trying to figure out what is different. Also trying to learn something
Re: Design me a 3G Hemi bracket engine [Re: MattW] #1057035
09/12/11 08:32 PM
09/12/11 08:32 PM
LA360 Offline
LA360  Offline
Is there a solid roller lifter available for them as yet?
Alan Jones
Re: Design me a 3G Hemi bracket engine [Re: LA360] #1057036
09/13/11 10:11 PM
09/13/11 10:11 PM
MN
hemidup Offline
hemidup  Offline
MN
No. Really don't need them with a top oiled system. In otherword's the oil dead heads at the lifter.
If I were ever to build a Engine Master's Hemi....I would have opted for ported 5.7 Eagle heads and flat top piston's. As you can see in the BES pic's, is that they used a quenched domed piston design with a small cc dish. Look's to me like a CP piston design.
Jerry Williams.
Re: Design me a 3G Hemi bracket engine [Re: hemidup] #1057037
09/13/11 10:27 PM
09/13/11 10:27 PM
LA360 Offline
LA360  Offline
So obviously no one has wanted to push the envelope with a solid roller camshaft as yet?
Alan Jones
Re: Design me a 3G Hemi bracket engine [Re: LA360] #1057038
09/13/11 10:40 PM
09/13/11 10:40 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Has anyone used the PN P5153816AB 6.1 block? I assume this is the same as the production 6.1 engines are equipped. Is there much finish machining needed to make it usable? The price looks pretty low for a ready to run block. Anyone know if they are even available? Thanks
Re: Design me a 3G Hemi bracket engine [Re: LA360] #1057039
09/13/11 10:43 PM
09/13/11 10:43 PM
MN
hemidup Offline
hemidup  Offline
MN
As stated before, not necessary. 8400-8500 rpm, the stock hyd lifters can handle it. At 8900 RPM, expect to bend some exh valves.
Jerry Williams.
Re: Design me a 3G Hemi bracket engine [Re: hemidup] #1057040
09/13/11 10:55 PM
09/13/11 10:55 PM
Toronto
mshred Offline
mshred  Offline
Toronto
subscribed!
Re: Design me a 3G Hemi bracket engine [Re: goldmember] #1057041
09/14/11 08:42 AM
09/14/11 08:42 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I have used it. It is a mass produced OE factory stock bare block with caps. If you're building a stock engine, there isn't any finish machining required. If building something else, you'll want to machine to whatever you need. Availability is zero at this time, because the plant has switched over to 6.4L engines/6.1s are not available in production Chrysler vehicles anymore.
There is a chance they MIGHT become available again at some point, but it will require a very expensive tooling changeover at the plant, and it may or may not happen. All a guy can do is keep an eye on it and hope for the best.
Rich H.
Esse Quam Videri
Re: Design me a 3G Hemi bracket engine [Re: ZIPPY] #1057042
09/14/11 08:57 AM
09/14/11 08:57 AM
Mesa, AZ
cagebob1 Offline
cagebob1  Offline
Mesa, AZ
SO..Does that mean that the 6.4 block could become available? What are the differences?
Re: Design me a 3G Hemi bracket engine [Re: cagebob1] #1057043
09/14/11 09:03 AM
09/14/11 09:03 AM
LA360 Offline
LA360  Offline
Would it not be easier to buy a complete low miles engine??
Alan Jones
Re: Design me a 3G Hemi bracket engine [Re: cagebob1] #1057044
09/14/11 09:20 AM
09/14/11 09:20 AM
NY usa
540challenger Offline
NY usa
THe 2 major differences if iam not mistaken is
1. The Bore size
2. The Cam tunnel newer 5.7 and 6.4 uses a different cam core b/c of the VVT. Last time i check cams choices were far less since must "aftermarket" cams for them are reground stock cams.
Also as of now there is no aftermarket computer that can control the VVT. However the name of the company escapes me right now but there is a way to lock the VVT so you don't have to worry about that. Check the LX forum for more info on locking the VVT a bunch of guys are doing it over there.
Re: Design me a 3G Hemi bracket engine [Re: 540challenger] #1057045
09/14/11 10:14 AM
09/14/11 10:14 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Unless I'm overlooking something it seems to me it'd be fairly simple on the manufacturing end to convert the VCT/VVT engines to standard cam, so folks can have some fun with them.
The main part it would take, is a partially machined VCT cam core. Machine the bearing journals only, don't drill the VCT oil holes, and just sell them to the aftermarket grinders and let them finish grinding the lobes.
I wonder if that could happen
No, seriously.
I am not hinting at anything, just wondering if it is viable.
Rich H.
Esse Quam Videri
Re: Design me a 3G Hemi bracket engine [Re: ZIPPY] #1057046
09/14/11 12:12 PM
09/14/11 12:12 PM
STEFF Offline
STEFF  Offline
Hey Z,
The lack of 6.1 blocks is only temporary correct? Aren't they required for service parts supply?
Re: Design me a 3G Hemi bracket engine [Re: STEFF] #1057047
09/14/11 12:28 PM
09/14/11 12:28 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
There MIGHT be more of them produced, but if that happens I don't think it will continue for very long.
I know it might contradict what I've said previously, but this new stuff is always changing and new rumors are always flying around. I don't interface directly with those decision makers either, so I've gotta find out 15th hand which makes that particular info very rough.
I had believed there would be a dry spell, and they would come back....what I don't know is, when they will come back and if so how long it will last.
overall impressions:
It appears to me that the company wants to go reman on that type of service part ASAP after production has stopped or has been altered in some way, that prevents the part from being produced in the right quantities without tremendous expense. Look at what has happened to Gen 3 cylinder heads already. At some point, probably sooner rather than later, new ones are not going to show up in reman packaging...and reman will really be reman.
Maybe I am wrong and the supply won't stop, but my gut is not telling me that
Rich H.
Esse Quam Videri
Re: Design me a 3G Hemi bracket engine [Re: ZIPPY] #1057048
09/14/11 12:48 PM
09/14/11 12:48 PM
NY usa
NY usa
Zippy What block is being used for the 392 (525hp)crate engine. I would assume it doesn't have the VCT cam tunnel. My guess it is just a 5.7 stroked
