Re: Design me a 3G Hemi bracket engine
[Re: hemidup]
#1056989
09/01/11 12:31 PM
09/01/11 12:31 PM
Posts: 1,074 detroit, mi
POS Dakota
detroit, mi
Good Post. I better keep this one some day I might graduate from A engines to one of these.
I cringe anytime someone wants to make over 600 hp with a LA block. I have no fear of taking these new Gen III Hemi's over 8 and thats a conservative number.
Then what would this make you do??? Snap Pencils?
http://i226.photobucket.com/albums/dd274/jmonar5695/truck/IMG_0237.jpg
That's a magnum block at the wheels through a 518 trans BTW...so think about what it makes at the flywheel.
That was built at shady dell and owned by a kid on my other message board. It didnt blow up. It didnt like to hold oil for long, but it didnt blow up.
[Re: Dragula]
#1056990
09/01/11 01:09 PM
09/01/11 01:09 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
As far as the ignition goes forget the dist i dont know why you would want to go that route prolly would end up costin more.
The engine masters engine was distributer driven....If you know why, please do tell.
Keep in mind that most Engine Master challenger are almost given the parts especially if your the one that has won in the past. If they are paying for the product they aint paying retail! The distributor for a hemi is a simple solution for people hard to convert. Is their any more power to be gained but it is easier to sell
Same goes for the Jesel rocker arm I would love to see the gains over Stock rockers with the Jesel on a sub 650 hp hemi.
I will still say that the G3 hemi is probable the cheapest way to make hp. Even with the DP at 1000.00 Matt
[Re: Irun5snd8th]
#1056993
09/05/11 10:09 PM
09/05/11 10:09 PM
Posts: 2,864 IN
Irun5snd8th
IN
So I talked to several people that campaign drag pak cars last Friday. I am still a little hesitant due to the fact that several of these engines blew up this weekend. Now I say that with a grain of salt because these guys are all now pushing the envelope with these engines. But... I am hearing there is an oiling issue with these engines. Barton told me there definitely is one and he has the cure for it but would not come off any more info than that. Knowledge costs money I suppose. Still I have talked with Wheatcraft and they have never had any of these issues with the mini dragster. I was also told by one racer that he found out the hard way that you definitely need to run the SRT filter. On a side note, the Mopar guys tell me the distributor setup is coming in like three weeks.
AFCO, Rons Fuel Injection sponsored Dodge Challenger
Mention Street Lethal Motorsports
[Re: Irun5snd8th]
#1056994
09/06/11 11:51 AM
09/06/11 11:51 AM
Posts: 18,048 S.E. Michigan
ZIPPY
S.E. Michigan
That's good you asked around, and you were told correctly. Yes, in stock form they do have 8,500+ rpm oiling issues... Given the HP you want to make, though...you're all set....you should be able to make that power at 7000 or less, and because of that it will live a long time.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#1056995
09/06/11 08:17 PM
09/06/11 08:17 PM
MattW
Ontario Canada
Imagine that!! oiling issues at 8500+ RPM What stock prodution engine doesn't. the LA engine would starve #3 and 4 main bearing if you spun it past 7000 rpm and fill the valve covers with oil. The RB needed inlarge oil passages for proper oiling. What is an SRT filter?
[Re: sunroofgtx]
#1056997
09/08/11 03:50 PM
09/08/11 03:50 PM
Posts: 2,864 IN
Irun5snd8th
IN
Zippy, if possible, can you elaborate a little further on the oiling issue?
[Re: Irun5snd8th]
#1056998
09/08/11 06:57 PM
09/08/11 06:57 PM
ZIPPY
S.E. Michigan
I haven't investigated it much, mostly because there hasn't been any reason to....All the stuff I've worked with has been done at 7,000 or below. With a decent pan that rpm hasn't been a problem, but to many that's grocery getter territory and not even worth talking about. The srt filter is a filter from a viper. At one time, a direct connection bulletin that was sent out about it...the bulletin basically says the oiling system is known good to a certain number below 7000, and that the viper filter is the best one... lesser filters alone can cause oiling issues even if everything else is OK, which is all true. It doesn't go into any modifications on how to run 9 grand or anything like that, though. I'm pretty sure a 10 quart fill and an accumulator has been in use for awhile now on some of the high rpm rigs. Maybe ask around a little more if you're leaning that way, the latest hot setup may have changed. Drainback has always appeared a little lacking to my eye, but knowledgeable builders I have spoken with don't agree with my opinion, so I guess I don't know what I'm talking about. Not really sure, but the comment about filling the valve covers with oil kinda hits home....I'm not trying to be smart, just relating discussions I've had. I am also not really a fan of the crankcase ventilation running through those two tiny little passages in the intake manifold either, but nobody else seems to have a problem with it. With the super tall cast valve covers available from Indy or whoever makes them for Indy, it doesn't seem like it would be a big deal to run a couple external drainback hoses + traditional breathers, to see if there is any difference....but nobody ever does it, so maybe that whole line of thinking is a waste of time. I have to remind myself: just because a stocker does not do it....does not mean an idea might not be beneficial, or that it would have no effect...it means a stocker isn't allowed to do it, so there is no sense in them experimenting with it... Did you get yourself a core yet and check it out????
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#1056999
09/08/11 11:35 PM
09/08/11 11:35 PM
Posts: 2,864 IN
Irun5snd8th
IN
Well here is what I am looking at. 5.7 block (picked one up basically for free) 6.1 heads (not sure who where the best place to go on those is yet), drag pak manifold, 392 stroker, Callies crank and possibly rods, Diamond pistons (the Mopar guys tell me that Diamond worked with them the most and Diamond makes a nice piece anyway) Comp Cams seems to be the place to go on the camshaft. Melling pump, apparently the SRT filter is a must. I dont plan on this thing going any higher than my current setup unless it makes a bunch more steam on top end and gets the rpm up higher but even then 73-7400 would be max and I only run 1/4 a couple weekends a year. Perhaps some drainback lines could help the situation? I have been hearing some conflicting info on how much oil to run. I am hearing some guys saying the standard 6 quart fill and then others stating you need 10 to 11
[Re: Irun5snd8th]
#1057000
09/09/11 10:28 AM
09/09/11 10:28 AM
ZIPPY
S.E. Michigan
Some of the guys who say they have a 6 or 7 quart fill have another 3+ in the accumulator they aren't discussing... If you get a chance, take a gander at drainback + CCV, and tell me if I'm way off base. If my ideas are dumb I'll stop bringing it up. A 14th opinion on that would be appreciated
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#1057001
09/09/11 03:50 PM
09/09/11 03:50 PM
Posts: 2,864 IN
Irun5snd8th
IN
Sounds like I may be putting my accusump back on the car. So where is the best place to pick up a set of heads and what are the differences between a 6.1 head and a Eagle 5.7 head?
[Re: MattW]
#1057005
09/09/11 04:47 PM
09/09/11 04:47 PM
Posts: 2,864 IN
Irun5snd8th
IN
Does the Eagle bolt up to the dragpak intake the same as a 6.1?
[Re: Irun5snd8th]
#1057006
09/09/11 04:50 PM
09/09/11 04:50 PM
Posts: 2,864 IN
Irun5snd8th
IN
Sounds like the Eagle may get me where I want to be compression wise without ordering a custom piston. I like that idea!
[Re: Irun5snd8th]
#1057007
09/09/11 05:44 PM
09/09/11 05:44 PM
MattW
Ontario Canada
Yes
