Page 1 of 8 1 2 3 4 5 6 7 8
Some B1 Original pics.....**UPDATED** AGAIN** #105525
08/15/08 11:19 PM
08/15/08 11:19 PM
SoCal
Brian Hafliger Offline OP
SoCal
Going to do a set of B1 Originals for a customer, who is a friend of Bryan Sloans. It's going to be a 540BB, nice reliable HP.
I have some pics for guys that don't get to see them much or have never seen them.
I'm going to be gone for a week, taking a much needed vacation. Will be back soon. After I get back, I will have some more pics of different stages of port work till they are complete, along with flow #'s and port speed #'s.
All in fun, so no picking...
This is mostly for guys who might be intimidated by the B1's. You never see any articles with B1's in them, very rare. No build up articles, nothing to help mopar guys see how easy these heads are to use. Yeah, they cost alot, but they provide very good HP, and we're going to do it without porting the hell out of them.
This will be an ongoing post that I'll update from time to time as I do the work, showing what needs to be done and why.
These are my favorite heads of all time, so that's why I thought this would be something others would like to see.
Brian
Re: Some B1 Original pics......... [Re: Brian Hafliger] #105526
08/15/08 11:20 PM
08/15/08 11:20 PM
SoCal
SoCal
As shipped with no seat work, or guide work.
Re: Some B1 Original pics......... [Re: Brian Hafliger] #105527
08/15/08 11:21 PM
08/15/08 11:21 PM
SoCal
SoCal
Another shot of the chamber, no seat work.
Re: Some B1 Original pics......... [Re: Brian Hafliger] #105528
08/15/08 11:22 PM
08/15/08 11:22 PM
SoCal
SoCal
You can see there is a nice big lip that needs to be cut away. If you buy these from Koffel or Brodix, and you want them to, they will cut the valve seats, and finish the guides or a good shop can also do this.
Re: Some B1 Original pics......... [Re: Brian Hafliger] #105529
08/15/08 11:23 PM
08/15/08 11:23 PM
SoCal
SoCal
Lip in the intake bowl after seat work.
Re: Some B1 Original pics......... [Re: Brian Hafliger] #105530
08/15/08 11:25 PM
08/15/08 11:25 PM
SoCal
SoCal
Here's what the bowl looks like when the lip is cut out, and blended by hand.
Valve seats are cut as well.
2.300 intake valve
Re: Some B1 Original pics......... [Re: Brian Hafliger] #105531
08/15/08 11:26 PM
08/15/08 11:26 PM
SoCal
SoCal
Opposite side of intake bowl...
Re: Some B1 Original pics......... [Re: Brian Hafliger] #105532
08/15/08 11:28 PM
08/15/08 11:28 PM
SoCal
SoCal
This is the exhaust bowl after cutting the lip away and hand blending the bowl.
Both intake and exhaust bowl's took me about 30min. to blend by hand.
Re: Some B1 Original pics......... [Re: Brian Hafliger] #105533
08/15/08 11:28 PM
08/15/08 11:28 PM
SoCal
SoCal
Opposite side of exhaust bowl...
Re: Some B1 Original pics......... [Re: Brian Hafliger] #105534
08/15/08 11:30 PM
08/15/08 11:30 PM
SoCal
SoCal
Shot of the intake port from the flange. They look big, but they are not as big as you think.
They flow well though that's for sure!!
Re: Some B1 Original pics......... [Re: Brian Hafliger] #105535
08/15/08 11:31 PM
08/15/08 11:31 PM
SoCal
SoCal
Shot of the head before all the machine work.
Re: Some B1 Original pics......... [Re: Brian Hafliger] #105536
08/15/08 11:32 PM
08/15/08 11:32 PM
SoCal
SoCal
Intake flange side of the head.
Re: Some B1 Original pics......... [Re: Brian Hafliger] #105537
08/15/08 11:43 PM
08/15/08 11:43 PM
SoCal
SoCal
Here's what they flowed on my bench at 28" depression, 4.350 bore, pipe on exhaust.
Remember, this is only cleaned up bowls...they are not ported yet. We will get to that, but it's going to be a few weeks because I'm on vacation for a bit.
The exhaust port is weak like this, but it won't be when I'm done with it.
This is just to show what can be expected if you bought them with the work done, or had someone do it for you without spending a ton of $$$ on porting. However, your goal will have a direct affect on how much porting you will need to get the HP you want. I see too many people over port these heads and I will show how to get good flow and HP without hogging these things out to h20!
Lift Int. Ex.
.200 139 102
.300 205 145
.400 267 183
.500 322 218
.600 358 242
.700 381 258
.800 387 268
Keep in mind I have no done any chamber work, or real porting yet, so the mid lift #'s up to .450 are weak...but look at the jump on both intake and exhaust at .500!
Port speed at the pushrod pinch area, at .500 lift is only 245fps which means the air speed is rather slow. However, after chamber work and proper porting you will see the air speed go up here. That's when you have to manage the air speed by enlarging this area some. But we don't do it on the pushrod side of the port.
I'll explain in detail when we get to that point.
Enjoy the pics, and I'll answer questions as we go.
Brian
Brian Hafliger
Re: Some B1 Original pics......... [Re: Brian Hafliger] #105538
08/15/08 11:48 PM
08/15/08 11:48 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Thanks for the pics, I've seen many done but never what they look like out of the box. I'll be watching for updates. Enjoy your vacation
Re: Some B1 Original pics......... [Re: Brian Hafliger] #105539
08/16/08 11:50 AM
08/16/08 11:50 AM
Tucson, Arizona
clonestocker Offline
Tucson, Arizona
Brian,
My brother inlaw had a 452in B1. It ran 7.90's in a 1650lbs dragster. The motor was so simple it was sick.
400 block
440 crank w/counter weights turned down
12.5 comp
alum rods
1050 Holley
Roller Cam
I also have laying around a Koffel build sheet for his bosses 500 in B1 that was built in the early 90's.
matt
[img] [/img]
Re: Some B1 Original pics......... [Re: Brian Hafliger] #105540
08/16/08 12:54 PM
08/16/08 12:54 PM
Rancho Cucamonga, Calif.
P
PUNK Offline
PUNK  Offline
P
I just wish someone made a cast tunnel ram for B1 origional heads.
10.53 @ 125mph. 1.37 60 foot. Caltracs and Monoleafs, AFCO shocks.
Heads by INDIO MOTOR MACHINE; IMM.
CP Pistons, PC Carbs.
Re: Some B1 Original pics......... [Re: PUNK] #105541
08/16/08 02:15 PM
08/16/08 02:15 PM
NY/NJ
DV8 Offline
mopar addict
DV8  Offline
mopar addict
NY/NJ
Those heads belong to Mark Weaver. We are both pretty anxious to see the step by step improvements made throughout the porting/machining process. They will compliment the World Wedge block and CP pistons nicely along with a custom spec'd IMM solid roller cam. I just wish someone made a cast tunnel ram for those heads. That would be great. A custom fabbed sheat metal manifold would be cool, but at $3500...its out of the question/budget. I didnt realize that there wasnt a market for a cast tunnel ram for B1 heads. Bummer. B1s just seem so popular for people that want big power.
What's he putting it in, that Valiant he bought?
~S~
"The function of man is to live, not exist..."
Re: Some B1 Original pics......... [Re: PUNK] #105542
08/16/08 06:54 PM
08/16/08 06:54 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
could an Indy tunnel ram for 440-1 heads be made to fit??
....BAD A$$ STREET CAR.....
Re: Some B1 Original pics......... [Re: n20mstr] #105543
08/16/08 07:39 PM
08/16/08 07:39 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
I will let you know sometime this week. I have the Indy tunnel ram and a B1 weld yourself tunnelram. The B1 must weigh 30 pounds more and looks like death warmed over.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Some B1 Original pics......... [Re: pittsburghracer] #105544
08/16/08 08:24 PM
08/16/08 08:24 PM
West Virginia
B1Frank Offline
B1Frank  Offline
West Virginia
Photos look good, like you said, I have a lot more work on mine on the intake-side and the manifold.
