Re: anyone use this Lunati cam ? [Re: 52savoy] #1054165
08/18/11 02:56 AM
08/18/11 02:56 AM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
ouch - 270@050
i think i'd say thats too much for my aims
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: anyone use this Lunati cam ? [Re: tex013] #1054166
08/18/11 11:54 PM
08/18/11 11:54 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
am i correct in thinking that i will need 6 - 8 degrees more duration on a solid to be somewhat equivilent to a hydro cam.hence from what some are saying i may really need closer to 260 or 265 to see a real gain,plus raise my peak power to around 6300 from 5800 now.
Tex
Yep, you are correct
Re: anyone use this Lunati cam ? [Re: Sport440] #1054167
08/19/11 12:54 AM
08/19/11 12:54 AM
gregsdart Offline
gregsdart  Offline
What I was getting at is the 590 will make great power down low, and you won't have to shift higher than 6200. It will however, have a rough idle. How close do you think you are on all other aspects of your combo? Jetting? timing? Cold air intake? 60 ft? Maybe a post on your entire combo, along with shift points, and all details of the time slips is a good idea. There may be some gains to uncover, which will help in deciding just how much cam you need to obtain your goals. With as loose a converter as you have, you can get away with about anything though.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
Re: anyone use this Lunati cam ? [Re: gregsdart] #1054168
08/19/11 01:54 AM
08/19/11 01:54 AM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
Sport440 thanks for the clarification
Greg
Current set up 68 Satellite
3764lbs with driver
440+055.10.78 comp.
509 cam,Crane 1.5 rockers.about 5.5"vacuum in gear
stealth heads,pocket ported only,open up behind valve and touch up radius,clean up ports
M1 single plane manifold
mighty demon 825,78/88 jets,6.5PV,35 front squirter,35 rear.1" open spacer,tried others no real difference
hooker 1 7/8 comp headers,3"system plus H pipe to diff,3"aero chambers
QA1 single adj front shocks,Rancho rear shocks with Caltracs.
dana with 4.1 gears
Hoosier radial slicks,275/60R15
six pack hood with cold air box.
sumped fuel tank,-8 line to mallory 140 pump,-8 line to mallory dead head reg,-8 line to carb fuel log,-8 to needles
18DBTC initial plus 18deg in at 2300 ish
leave the line at about 2800,can't hold much past this,vert flashes to 5100.it is a dynamic 9 1/2
best mph 119.47,Et 11.187@118.95
sixties best 1.54 average 1.55's
i shift at 6000rpm,trap 6300/6350
i have run this jetting for a couple of years,more fuel does not seem to help,AFR last time checked on the dyno was 13.0-13.2 this showed 416 RWHP and max TQ of 791.5 at 110KMH(about 3500RPM).Peak power was 57/5800rpm
rough idle,so does the 509
the cam does seem to be knocking off at or just after the stripe
1/8 mph is 95-mid 96 7.08-7.15
the only thing not checked as said is P to V
personally i am a little suprised how fast this has gone
thanks
Tex
New best MPH 130.32
Re: anyone use this Lunati cam ? [Re: tex013] #1054169
08/19/11 05:22 AM
08/19/11 05:22 AM
robin hood country
deaks Offline
deaks  Offline
robin hood country
I think your combo works well but you will have to up the cam to gain significant power and or have the heads fully ported. The .590 isn't 265 it's 271 dur at .050 and it is lumpy.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: anyone use this Lunati cam ? [Re: deaks] #1054170
08/19/11 08:10 PM
08/19/11 08:10 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
Deaks,
thanks.
all my info shows 265 but ?
i think i will need at least 258/260@050 to see a real gain.
Tex
New best MPH 130.32
Re: anyone use this Lunati cam ? [Re: tex013] #1054171
08/19/11 09:32 PM
08/19/11 09:32 PM
Utah
topbrent Offline
topbrent  Offline
Utah
tex013:
Tex
With that 5100 flash rpm, you have enough converter to run the 590.
If you do run one, I would install it advanced to at least 102° and probably start at 100°
Read the posts by VernMotor and 572Charger.
https://board.moparts.org/ubbthreads/show...amp;Search=true
Here is a post on the actual measurements of the MP 590
440Jim:
In addition to the actual duration at 0.050", this is what Dwayne Porter measured on one a few years ago.
MP .590 cam, actual measurements-
DUR. @
.020=303.5
.050=270.5
.100=235.0
.150=205.0
.200=177.0
.250=148.5
.300=117.0
.350=76.0
lobe [Email]lift@TDC[/Email] @105 ICL=.140
LSA 106
Re: anyone use this Lunati cam ? [Re: topbrent] #1054172
08/19/11 09:48 PM
08/19/11 09:48 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
cool thanks,i was going off the DC cam lists
Tex
New best MPH 130.32
Re: anyone use this Lunati cam ? [Re: tex013] #1054173
08/19/11 10:40 PM
08/19/11 10:40 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
I measured my mp 590 @ 272 @ .050 no lash. Toss in your effective duration loss with lash, of around 7* and what do you get. I never measured mine with lash figured in though.
MP,s 265*@.050 number is a calculated number off of its advertised duration of 312. 312 x .85 = 265.2
Your car IS Bad Ask!m I think you should keep with the MP cam route and go with the MP 590 if it will fit P/V, your Verts already fine. You will see your two tenths.
Thats the route Im taking.
73 Sport 440, 509 cam w/Eddys 3.91 and 28.1"/27.3 tire. Et. 60 ft. 1.435, 1/8th. 6.61 @ 101.80 mph. 1/4. 10.472 / 127.78 mph. 2950# race/with me,and pump gas.
Re: anyone use this Lunati cam ? [Re: Sport440] #1054174
08/20/11 04:07 AM
08/20/11 04:07 AM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
thanks again,
much food for thought
Tex
New best MPH 130.32
Re: anyone use this Lunati cam ? [Re: tex013] #1054175
08/21/11 05:51 AM
08/21/11 05:51 AM
Utah
topbrent Offline
topbrent  Offline
Utah
If you are looking for a bit more good info to get your car in the 10's, there is much to read in the "fast 3.75" stroke combos" thread:
https://board.moparts.org/ubbthreads/show...rt=all&vc=1
