Launch picture question... #1053767
08/15/11 10:52 PM
08/15/11 10:52 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
I know what causes the left front to lift more than the right, but what is the fix to get both tires to lift equal ??
Its a ladder bar car, leaving at 4500 rpm, 3100 lbs and this pic was taken on a 9 second pass..
Re: Launch picture question... [Re: Jeepmon] #1053768
08/15/11 10:56 PM
08/15/11 10:56 PM
Westbury, NY
bumps440 Offline
super gas
bumps440  Offline
super gas
Westbury, NY
you need just a little more preload on the right rear ladder bar. What kind of bars do you have? are they easily adjustable ? One more flat or 2 on the adjuster will fix that right up.
Re: Launch picture question... [Re: Jeepmon] #1053769
08/15/11 10:59 PM
08/15/11 10:59 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Does the car go straight on the launch
Re: Launch picture question... [Re: MR_P_BODY] #1053770
08/16/11 12:20 AM
08/16/11 12:20 AM
Renton Wa
topfueldart Offline
topfueldart  Offline
Renton Wa
Anti Roll Bar in the rear.
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
Re: Launch picture question... [Re: topfueldart] #1053771
08/16/11 12:30 AM
08/16/11 12:30 AM
MR_P_BODY Offline
MR_P_BODY  Offline
That will take care of it if its going straight now
Re: Launch picture question... [Re: MR_P_BODY] #1053772
08/16/11 12:37 AM
08/16/11 12:37 AM
SoCal
Brian Hafliger Offline
SoCal
Have you scaled it? When I scaled mine I was surprised that it was actually pretty good but I had one large battery on each side of the fuel cell in the trunk.
After moving the left side battery over to the right, my car leaves level and high! What a difference it made for such a small change. It was a 108lb. swing moving it from the left to the right. So it makes sense to me that it worked so well.
Also tire pressure in the rear slicks, ladder bar adjustment, shock adjustment, tire circumference from left to right, etc....can all play a part in a crooked launch.
I would scale it first, and make it right then go from there.
Nice Duster!!
Brian
Brian Hafliger
Re: Launch picture question... [Re: Brian Hafliger] #1053773
08/16/11 01:24 AM
08/16/11 01:24 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
SHOW OFF
Well the picture is kinda crooked so how can we tell. I know it could use some shocks, both front and rear It looks pretty good to me. Glad to hear you got the 9's out of the way now time to build a motor for it.
Re: Launch picture question... [Re: bumps440] #1053774
08/16/11 02:34 AM
08/16/11 02:34 AM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
The car was originally built in the 80's, so I'm not sure what brand bars they are.. but yes, its easy enough to add a flat or two..
Thats a difficult question to answer.. most of the time it will go straight, but every once in awhile, it will want to veer off to the right..
I was told that anti roll bars do not work on ladder bar set ups..
Have you scaled it?
My scales moved to Las Vegas... and I do have two batteries in the trunk, one on each side of the fuel cell.. and I also have mounts for weights in the trunk.. I can easily remove the left battery and put 70 lbs of weight on the right rear..
Would you believe a trans.. and its coming out this weekend...
Re: Launch picture question... [Re: Jeepmon] #1053775
08/16/11 03:06 AM
08/16/11 03:06 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Really...That bites. Gonna give Johnny a call?
Re: Launch picture question... [Re: Al_Alguire] #1053776
08/16/11 03:22 AM
08/16/11 03:22 AM
Arizona
Chris'sBarracuda Offline
Arizona
Try making it hit the right stop first..
Still looking for the Uni-Filter..
Chris..
Re: Launch picture question... [Re: Chris'sBarracuda] #1053777
08/16/11 08:49 AM
08/16/11 08:49 AM
gregsdart Offline
gregsdart  Offline
I would steer clear of who told you anti roll bars don't work on a ladder bar car. They work very well. Actually they need to be stronger in a ladder setup, because of the short instant center which makes for high leverage for the twisting force. Get a ladderbar car screwed up enough, you can leave with the car on one slick. I have accomplished that!
Here is a pic of my first anti roll, that bent on the first pass. It had a .125 x 1 1/4 tube.
Re: Launch picture question... [Re: Jeepmon] #1053778
08/16/11 09:22 AM
08/16/11 09:22 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I would scale it first but if you think its goes
straight most of the time it should be close...if
the car flexes (which its doing), then yes a anti
roll will correct it but the anti roll is covering
up flex... if it wasnt flexing you wouldnt need a
anti roll(the ladder bars would hold it level)
Re: Launch picture question... [Re: MR_P_BODY] #1053779
08/16/11 10:19 AM
08/16/11 10:19 AM
Windsor ,Ca.
K
Keith Richards Offline
K
Windsor ,Ca.
Don, How old are the tires? or how many runs on them? I don't see too much too worry about in the picture you posted. Old tires will and can throw you one way or the other pretty easy, my car does that as it always wears out the sidewalls usually before the tread at least with the last Hoosiers (especially when it was 60' ing 1.23 with the 4.56 gears). With fresh tires if it still goes slight right add preload to the passenger side. I am there to help you if needed. I also like to rotate the tires side to side about every 25 -30 passes to let the sidewalls live longer.
Re: Launch picture question... [Re: Keith Richards] #1053780
08/16/11 10:24 AM
08/16/11 10:24 AM
Windsor ,Ca.
K
K
Windsor ,Ca.
One other thing, If you want to scale the car on a weekend I am sure I would be able to borrow my buddies scales, if not you would have to do it at his shop during the week. Let me know I am here to help.
Keith
Re: Launch picture question... [Re: Keith Richards] #1053781
08/16/11 02:03 PM
08/16/11 02:03 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
Nice car jeepmom, the top colour looks like mine, is it prowler orange, also is there a reason you run without the hood and does it help at all.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: Launch picture question... [Re: deaks] #1053782
08/16/11 10:42 PM
08/16/11 10:42 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
Mick
Earlier this year the hood pulled right thru the dsuz's and went a good 30' into the air.. So running the car without a hood is not done on purpose...
Re: Launch picture question... [Re: Jeepmon] #1053783
08/16/11 11:20 PM
08/16/11 11:20 PM
In the 8's
FY1TA Offline
FY1TA  Offline
In the 8's
Anti-roll bar fixed mine from flexing .
Re: Launch picture question... [Re: FY1TA] #1053784
08/17/11 11:26 PM
08/17/11 11:26 PM
Seaside,Ca.
TC67CUDA Online content
TC67CUDA  Online Content
Seaside,Ca.
Hey Don my buddy had the same problem and ended up putting an anti roll bar and it straightened his launch right up.I probably should put one on too. BTW what were the rest of the numbers on your 9 sec run?
Re: Launch picture question... [Re: TC67CUDA] #1053785
08/18/11 01:48 PM
08/18/11 01:48 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
Right Lane
Don Riley
Car Number R705
Class PRO
Q/P 0
Dial In 0.00
R/T .006
60' 1.343
330' 3.985
1/8 6.221
MPH 109.600
1000' 8.162
1/4 9.819
MPH 135.62
Re: Launch picture question... [Re: Jeepmon] #1053786
08/18/11 06:07 PM
08/18/11 06:07 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
What does it weigh?, is it a stroker?.
Mick
best 60ft 1.36
