Re: Launch picture question...
[Re: Jeepmon]
#1053769
08/15/11 10:59 PM
08/15/11 10:59 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I know what causes the left front to lift more than the right, but what is the fix to get both tires to lift equal ??
Its a ladder bar car, leaving at 4500 rpm, 3100 lbs and this pic was taken on a 9 second pass..
Does the car go straight on the launch
[Re: MR_P_BODY]
#1053770
08/16/11 12:20 AM
08/16/11 12:20 AM
Posts: 2,697 Renton Wa
topfueldart
Renton Wa
Anti Roll Bar in the rear.
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
[Re: topfueldart]
#1053771
08/16/11 12:30 AM
08/16/11 12:30 AM
MR_P_BODY
That will take care of it if its going straight now
[Re: MR_P_BODY]
#1053772
08/16/11 12:37 AM
08/16/11 12:37 AM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
Have you scaled it? When I scaled mine I was surprised that it was actually pretty good but I had one large battery on each side of the fuel cell in the trunk. After moving the left side battery over to the right, my car leaves level and high! What a difference it made for such a small change. It was a 108lb. swing moving it from the left to the right. So it makes sense to me that it worked so well. Also tire pressure in the rear slicks, ladder bar adjustment, shock adjustment, tire circumference from left to right, etc....can all play a part in a crooked launch. I would scale it first, and make it right then go from there. Nice Duster!! Brian
Brian Hafliger
[Re: bumps440]
#1053774
08/16/11 02:34 AM
08/16/11 02:34 AM
Posts: 8,094 Sunnyvale, CA
Jeepmon
Sunnyvale, CA
you need just a little more preload on the right rear ladder bar. What kind of bars do you have? are they easily adjustable ? One more flat or 2 on the adjuster will fix that right up.
The car was originally built in the 80's, so I'm not sure what brand bars they are.. but yes, its easy enough to add a flat or two..
Thats a difficult question to answer.. most of the time it will go straight, but every once in awhile, it will want to veer off to the right..
I was told that anti roll bars do not work on ladder bar set ups..
Have you scaled it?
My scales moved to Las Vegas... and I do have two batteries in the trunk, one on each side of the fuel cell.. and I also have mounts for weights in the trunk.. I can easily remove the left battery and put 70 lbs of weight on the right rear..
now time to build a motor for it.
Would you believe a trans.. and its coming out this weekend...
[Re: Chris'sBarracuda]
#1053777
08/16/11 08:49 AM
08/16/11 08:49 AM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I would steer clear of who told you anti roll bars don't work on a ladder bar car. They work very well. Actually they need to be stronger in a ladder setup, because of the short instant center which makes for high leverage for the twisting force. Get a ladderbar car screwed up enough, you can leave with the car on one slick. I have accomplished that! Here is a pic of my first anti roll, that bent on the first pass. It had a .125 x 1 1/4 tube.
[Re: Jeepmon]
#1053778
08/16/11 09:22 AM
08/16/11 09:22 AM
MR_P_BODY
I would scale it first but if you think its goes straight most of the time it should be close...if the car flexes (which its doing), then yes a anti roll will correct it but the anti roll is covering up flex... if it wasnt flexing you wouldnt need a anti roll(the ladder bars would hold it level)
[Re: Keith Richards]
#1053781
08/16/11 02:03 PM
08/16/11 02:03 PM
Posts: 3,210 robin hood country
deaks
robin hood country
Nice car jeepmom, the top colour looks like mine, is it prowler orange, also is there a reason you run without the hood and does it help at all. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: deaks]
#1053782
08/16/11 10:42 PM
08/16/11 10:42 PM
Jeepmon
Sunnyvale, CA
Earlier this year the hood pulled right thru the dsuz's and went a good 30' into the air.. So running the car without a hood is not done on purpose...
[Re: TC67CUDA]
#1053785
08/18/11 01:48 PM
08/18/11 01:48 PM
Jeepmon
Sunnyvale, CA
Hey Don my buddy had the same problem and ended up putting an anti roll bar and it straightened his launch right up.I probably should put one on too. BTW what were the rest of the numbers on your 9 sec run?
Right Lane Don Riley Car Number R705 Class PRO Q/P 0 Dial In 0.00 R/T .006 60' 1.343 330' 3.985 1/8 6.221 MPH 109.600 1000' 8.162 1/4 9.819 MPH 135.62
[Re: Jeepmon]
#1053786
08/18/11 06:07 PM
08/18/11 06:07 PM
deaks
robin hood country
What does it weigh?, is it a stroker?. Mick
