Re: Lets hear your stupid fast small block combo's
[Re: The Sphinx]
#1053486
08/15/11 11:10 PM
08/15/11 11:10 PM
Posts: 21,066 in a cattle trailer down by th...
Guitar Jones
Well mine ain't stupid fast but it is a stock block. Haven't had it to the track yet as I'm still waiting on the proper pushrods and thanks to Todd at Competion Wedge I'll be able to fix that soon enough. I expect mid 9's in the crappiest air out of this combo and I don't see a reason why it shouldn't do it. Stock 360 block, tall filled with a Hughes girdle, torque plate honed and a 1/16 ring pack. W5 small chamber hand ported heads, 2.08/1.60 intake flows over 320 @ .700. 4" crank from BPE, Eagle H beams and Wiseco pistons with a 20cc dish including the valve reliefs. .006 out of the hole with .039 gasket. Crane SS solid roller with 1.6 rockers nets out to .698/.714 lift with the lash, 276/284 duration @.050. I've done oiling mods that include drilling all the passages to .500 minimum and radiusing all the corners I could get to and blocking the oil to the lifters. A Melling HV pump with a Canton rear sump pan filled with 05W20 synthetic and a .625 ID pickup tube.It has an M1 W5 tunnel ram with 2 750 Demon TR carbs. Currently has Crane Gold rockers on it but thanks to Todd @ Competion Wedge it will soon have Harland Sharps on it. 2" primary header and a 4" collector with turn downs. 4200 TA converter and a low gear 904 with a 4.86 geared 8.75 rear at 2600 pounds with me in it. The combo in my sig is basically the same but with a .672 lift flat tappet with the same duration @ .050 as the roller but with 2.02 valves in the head and a basically stock short block with hyper pistons. Plus it's about 15 years old without a freshening so I don't think the new combo will have any problems getting well into the 9's. Results will be posted.
"Come get your wife"
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Front and rear disc and hydroboost conversion. 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Guitar Jones]
#1053487
08/15/11 11:17 PM
08/15/11 11:17 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Stock block Steve.
I had a 378 which is a 360 bored .100" over. It ran 9.90's at 3400 lbs.
[Re: Leon441]
#1053488
08/15/11 11:23 PM
08/15/11 11:23 PM
Guitar Jones
Stock block Steve.
Well the OP said factory block. I suppose the R3 is a factory block, but considering there isn't much of anything else out there you could construe that to mean stock block.
[Re: Leon441]
#1053491
08/16/11 07:21 AM
08/16/11 07:21 AM
Posts: 340 western PA
stevet340
western PA
Stock block Steve.
Sorry, I thought he ment any Mopar block. I went 9.502 @ 138 mph with a stock 1970 block out of my 340 swinger I used to own with w-5 heads and @ 3100 lbs. 372 inches and no power adders. It eventually slpit in half so i went with a R-3 race block. Is that stupid fast???
[Re: stevet340]
#1053492
08/16/11 07:44 AM
08/16/11 07:44 AM
Posts: 428 Mountain City, TN
JesseR
Mountain City, TN
We've been 5.72 @ 119 with a stock block 340, 418 inches and W5s. 3220lbs with a 4.10 gear and street legal. This is with a .082 nitrous jet and 17 degrees of timing
82' dodge pickup with a 499 low deck
[Re: JesseR]
#1053493
08/16/11 08:25 AM
08/16/11 08:25 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
I have been 9.53 69 340 .055 over indy head 421 cu in with .073 jet at 3275lbs.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: DavidDean]
#1053496
08/16/11 06:00 PM
08/16/11 06:00 PM
Guitar Jones
I think 5's in the 1/8th with no power adders is pretty stupid fast for a stock block. I hope mine holds up until I can get another R3. I had 2 and sold them, but I don't plan on leaning on this one real hard. Shouldn't have to to get what I want anyway.
[Re: Leon441]
#1053498
08/16/11 09:03 PM
08/16/11 09:03 PM
Leon441
Lynchburg, VA
Stupid fast for a stock block is a relative statement. The weight of the car has to be considered.
Leon
[Re: Leon441]
#1053499
08/16/11 09:18 PM
08/16/11 09:18 PM
Posts: 1,090 north cakalaky
instigator
north cakalaky
A few years ago I was going 5.60's at 3500lbs on 408ci edelbrock heads.....
A few months ago went 128 mph in the 1/8th at about 50 more lbs..not a great et though..some bugs then.
65 Barracuda All aluminum Indy HEMI with some boost! COMING TO A TRACK NEAR YOU!
[Re: Leon441]
#1053501
08/16/11 09:47 PM
08/16/11 09:47 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Leon
Yep... I never had to make big power when running a light car... that way I dont stress parts and break things
[Re: Leon441]
#1053502
08/16/11 09:49 PM
08/16/11 09:49 PM
Posts: 3,112 LONG ISLAND
fishy340
LONG ISLAND
That twin setup you got is stupid fast!
Leon
i very much agree with that leon,he is stupid fast..on the other side dustermel i believe went 5.60 in a n/a sb..thats kinda stupid fast also..anything in the 5's is nice thats why as of right now,,im putting a speedtech plate on my junk..unless i find 10 g's somewhere
[Re: Leon441]
#1053503
08/16/11 10:12 PM
08/16/11 10:12 PM
JesseR
Mountain City, TN
It would have been nice to have had more time down there to see how fast we both could have gone, thats the only bad thing about index racing, we spent all of our time trying to dial our cars in
