quick brake assembly question #1053434
08/15/11 02:03 PM
08/15/11 02:03 PM
Mass
68bb Offline OP
super street
68bb  Offline OP
super street
Mass
Hello
This is on my 70 dart with 8 3/4 rear with 1 3/4" brakes. I'm sorry I don't know the correct part names. There is a cable that has an eyelet that hooks around the top brake shoe pivot point and wraps around down to the piece that holds tension on the adjuster. Should that cable be a little loose or very taught? Mine is a little loose, same on both sides and I don't think anything is installed wrong but just wanted to check.
thanks
Tony
Re: quick brake assembly question [Re: 68bb] #1053435
08/15/11 02:07 PM
08/15/11 02:07 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
should be taught or tight, it's the auto brake shoe adjust cable
Re: quick brake assembly question [Re: A12] #1053436
08/15/11 02:10 PM
08/15/11 02:10 PM
Mass
68bb Offline OP
super street
68bb  Offline OP
super street
Mass
Thanks for the reply. Any common mistake I could have made during assembly that would cause the cable to be loose?
Re: quick brake assembly question [Re: 68bb] #1053437
08/15/11 02:17 PM
08/15/11 02:17 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Missing or not hooked over the plate at the top with the guide groove
Re: quick brake assembly question [Re: A12] #1053438
08/15/11 02:18 PM
08/15/11 02:18 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
not attached properly at the bottom??
Re: quick brake assembly question [Re: A12] #1053439
08/15/11 02:23 PM
08/15/11 02:23 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
see the tension spring from the ratchet arm for the adjuster to the inside of the brake shoe in this photo? Is that correct on yours?
MikeR
Re: quick brake assembly question [Re: A12] #1053440
08/15/11 02:23 PM
08/15/11 02:23 PM
Mass
68bb Offline OP
super street
68bb  Offline OP
super street
Mass
A12 thanks for taking the time to post the photos. I'll check my installation compared to them.
Tony
Re: quick brake assembly question [Re: A12] #1053441
08/15/11 02:25 PM
08/15/11 02:25 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Or, assuming that the brakes are 10 inch, that somehow you now have adjuster cables for 11 inch brakes,(doubtful) Are the correct lower springs in place?
Re: quick brake assembly question [Re: A12] #1053442
08/15/11 03:03 PM
08/15/11 03:03 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Ive also seen the self adjuter arm not installed correctly or the spring not installed right either.A few Ive seen the spring lose tension and wont hold the arm down properly.Rocky
Chrysler Firepower
