Re: buying a degree wheel
[Re: S/ST 3040]
#1053372
08/15/11 01:47 PM
08/15/11 01:47 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
I have the Moroso 18" wheel & a Comp Cams crankshaft socket which mounts the wheel perfectly & gives me a way to turn the crank without disturbing the wheel..
Only issue with a big wheel is trying to degree a cam with the engine in the car... That's where the 7" is handy..
[Re: 1_WILD_RT]
#1053373
08/15/11 02:05 PM
08/15/11 02:05 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
I have used the same for years, and the crank socket makes it way , way easier for degreeing, much faster. Best bang for the buck. Of course, you can buy the new BHJ optical laser pointed degree wheel set up for about $600.00...
RIP Monte Smith
[Re: Dodgem]
#1053377
08/15/11 08:53 PM
08/15/11 08:53 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
But you need a smaller one for in car usually!
