Dipstick full mark in relation to top of pan? (440-4) #1053022
08/14/11 08:33 PM
08/14/11 08:33 PM
Highland, CA
Mosin Offline OP
Mosin  Offline OP
Highland, CA
Hi All,
First the basic question, followed by a brief background explanation for those interested/curious:
Q: In relation to the top of the oil pan (i.e. where the pan meets the block at the pan gasket) can anyone tell me the correct position/measurement for the dipstick full mark? In other words, in inches, how far below the top of the pan should the maximum oil fill line be on a 440?
Brief background: After my RV 440-4 was rebuilt in 2008 it seems the dipstick (actually the stock ~3ft dip cable) tube was bent, incorrectly positioned, or both, leading me to add *way* too much oil for the past ~35K miles. Right now the dipstick full mark is essentially at the top of the pan, so I want to adjust it down to where it should be.
TIA for any responses!
PS Photo of the beast in question...
Re: Dipstick full mark in relation to top of pan? (440-4) [Re: Mosin] #1053023
08/14/11 08:43 PM
08/14/11 08:43 PM
Florida STAYcation
IcorkSOAK Offline
Financed his waterbed
IcorkSOAK  Offline
Florida STAYcation
Do you know what pan is on it ? ...some RV pans are SEVEN quarts...
Re: Dipstick full mark in relation to top of pan? (440-4) [Re: IcorkSOAK] #1053024
08/14/11 08:51 PM
08/14/11 08:51 PM
Highland, CA
Mosin Offline OP
Mosin  Offline OP
Highland, CA
I didn't want to give TMI at first, but the pan type/capacity is part of the problem in my determining the correct level. A few months back I picked up a straight and clean front/truck sump pan from a Mopar yard in Phelan, CA, and noticed that its dimensions were larger than the beat-up stock front sump pan I was changing it out for. Assuming based on measurements that it held perhaps a quart or two more than my stock 7qt pan, I kept adding oil until it hit the bottom of my dip stick...which took 10qts!! Knowing this was way too much oil, but not knowing exactly what the capacity of this sump is, I decided to inquire about the maximum full mark in any configuration with a 440, which I believe should be the same no matter what type/capacity pan or vehicle with a 440 (?) Hence the question...
Re: Dipstick full mark in relation to top of pan? (440-4) [Re: Mosin] #1053025
08/15/11 03:18 AM
08/15/11 03:18 AM
Florida STAYcation
IcorkSOAK Offline
IcorkSOAK  Offline
Florida STAYcation
What I would do is fill your old pan up with 7 quarts of water and eye-ball the inside of the pan on where that puts you.
When you are mixing-up diff pans with diff tubes and dip-sticks that can be a rats-nest. You might have to pull the pan and eye-ball the whole combo ....
10 quarts ?... ...maybe you got a SS pan !
Re: Dipstick full mark in relation to top of pan? (440-4) [Re: IcorkSOAK] #1053026
08/15/11 05:21 AM
08/15/11 05:21 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
What year trucks used a front sump? I thought that only RVs used the front sump.
My 74 truck uses the rear sump pan with the wierdo dipstick. It has a fitting on the side of the pan that the dipstick fits into.
Re: Dipstick full mark in relation to top of pan? (440-4) [Re: IcorkSOAK] #1053027
08/15/11 05:25 AM
08/15/11 05:25 AM
Highland, CA
Mosin Offline OP
Mosin  Offline OP
Highland, CA
Thanks for the tip Doc! I balanced the old pan, filled it with 7qts of water, and took measurements from the top of the pan to the water (1 1/2 inches) then from the bottom of the windage tray valley to the water (just under 1/2 in.). Photos attached.
If 1/2 in below the windage tray valley looks/sounds like the correct maximum fill level for the oil (<==that would be the key question!) then I believe my question about where to position the dipstick has been answered, and I'll set it accordingly.
Re. the capacity of my "new" pan, it must be an 8 qt pan at least, as it is 1.5 inches deeper at the deep end/sump, and 3/4 in. deeper in the shallow end. If indeed it is an 8 qt pan, with and extra qt for the filter this would bring the total engine oil capacity to 9 qts, which I will of course confirm (and post back) once I get the pan off.
Thanks again for the responses and advise!!
Re: Dipstick full mark in relation to top of pan? (440-4) [Re: Kern Dog] #1053028
08/15/11 05:31 AM
08/15/11 05:31 AM
Highland, CA
Mosin Offline OP
Mosin  Offline OP
Highland, CA
It's an RV... 1976 Winny Brave named Pandora. Here she is on the dyno at Westech...
Re: Dipstick full mark in relation to top of pan? (440-4) [Re: Kern Dog] #1053029
08/15/11 05:35 AM
08/15/11 05:35 AM
Highland, CA
Mosin Offline OP
Mosin  Offline OP
Highland, CA
Here's the photo of the original pan w/ 7 qts water and the WT. Fluid level is just under 1/2 in from WT valley floor:
Re: Dipstick full mark in relation to top of pan? (440-4) [Re: Mosin] #1053030
08/15/11 05:43 AM
08/15/11 05:43 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
I'm not trying to be critical. I just read this and wasn't sure. Trucks and their parts interchange is new to me. I've been a car guy for all my life but just started tinkering with these trucks....
Re: Dipstick full mark in relation to top of pan? (440-4) [Re: Kern Dog] #1053031
08/15/11 05:54 AM
08/15/11 05:54 AM
Highland, CA
Mosin Offline OP
Mosin  Offline OP
Highland, CA
Apologies for the confusion! I my search for a pan in better condition I saw that 440source and other sites listed them as "front/truck" sumps, which I thus thought was the correct terminology. Here's an example:
http://store.440source.com/Oil-Pickup-Front-Sump-Truck-USED/productinfo/100-1028/
http://www.440source.com/oilpans.htm (scroll down to the 6th and 7th pans depicted)
I should have emphasized "motorhome" Oh well, it gave me an excuse to show off Pandora on the dyno...
Re: Dipstick full mark in relation to top of pan? (440-4) [Re: Mosin] #1053032
08/15/11 05:59 AM
08/15/11 05:59 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Does the front sump use a traditional path for the dipstick ie: thru the block near the motor mount?
Re: Dipstick full mark in relation to top of pan? (440-4) [Re: Kern Dog] #1053033
08/15/11 06:16 AM
08/15/11 06:16 AM
Highland, CA
Mosin Offline OP
Mosin  Offline OP
Highland, CA
I believe so: driver's side, through the block, just under the motor mount.
Re: Dipstick full mark in relation to top of pan? (440-4) [Re: IcorkSOAK] #1053034
08/15/11 04:46 PM
08/15/11 04:46 PM
Highland, CA
Mosin Offline OP
Mosin  Offline OP
Highland, CA
As per the above picts, can anyone confirm whether or not ~1/2 inch below the windage tray valley would be the correct (or at least a safe) full oil mark for a 440? TIA!
Re: Dipstick full mark in relation to top of pan? (440-4) [Re: Mosin] #1053035
08/17/11 10:36 PM
08/17/11 10:36 PM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
That's where I run mine, never a problem in years.
Re: Dipstick full mark in relation to top of pan? (440-4) [Re: Bill MeLater] #1053036
08/17/11 11:25 PM
08/17/11 11:25 PM
Highland, CA
Mosin Offline OP
Mosin  Offline OP
Highland, CA
Many thanks for the response. Tonight I'll be pulling off the new pan to find out exactly what its capacity is, and set the dipstick level. Should be interesting!
