what is the satin black paint im seeing on some rods? #1052618
08/14/11 10:18 AM
08/14/11 10:18 AM
elkhart, indiana, usa
grizzley155 Offline OP
i have my 41 in primer now and i need to block and seal.im looking to apply the satin black .is this a one step paint? any thoughts from you body and paint guys?
Re: what is the satin black paint im seeing on some rods? [Re: grizzley155] #1052619
08/14/11 12:21 PM
08/14/11 12:21 PM
Buckeye Lake
56_Royal_Lancer Offline
My Mouth Is Shut II
My Mouth Is Shut II
Buckeye Lake
All I have is my own experience to go by- my car is 2-stage black minus the clear. It has been on it for 4 or 5 years with minimal fading.
Re: what is the satin black paint im seeing on some rods? [Re: 56_Royal_Lancer] #1052620
08/14/11 01:29 PM
08/14/11 01:29 PM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
i see summit sells hot rod black in their brand of paint. i`m painting my desoto with a mix of flat and gloss to get the amount of flat/semi gloss/gloss i want. i`m using rustolumium sold at lowes in the gallon can. about $30 a gallon.
Re: what is the satin black paint im seeing on some rods? [Re: 56_Royal_Lancer] #1052621
08/14/11 03:17 PM
08/14/11 03:17 PM
ty ,your paint looks ,thats the look im going for. thanks again
Re: what is the satin black paint im seeing on some rods? [Re: 65rbdodge] #1052622
08/14/11 03:23 PM
08/14/11 03:23 PM
ty for your info.the price per gal. sounds good. now its just getting the boby ready.
Re: what is the satin black paint im seeing on some rods? [Re: grizzley155] #1052623
08/14/11 03:33 PM
08/14/11 03:33 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
You can use cheap primer (bad, since it will be porous and will have to be removed for a good layer of paint), Blitz Black or other cheap implement paint (doesn't hold up well, also should be removed), up through decent auto paint with flattener added, to speciality paints.
Best to discuss it with your paint supplier and get the best product you can afford.
Can it be scuffed and shot over?
Can it be cleaned?
Can it be touched up?
How long are you planning on keeping it?
Indoor or outdoor storage?
Re: what is the satin black paint im seeing on some rods? [Re: RodStRace] #1052624
08/14/11 05:36 PM
08/14/11 05:36 PM
ty, i have used trinity paints before with good results. i went to the web site today and see they are offering hotrod black also. it is 35 a gal. acrylic lacquer primer. high compatibility.im going to order it and give it a shot.
Re: what is the satin black paint im seeing on some rods? [Re: grizzley155] #1052625
08/15/11 09:39 AM
08/15/11 09:39 AM
E
earlymopar Offline
earlymopar  Offline
E
What is typically done now is a 2-stage process no different from a high gloss normal paint job. The only difference is that the top clear coat is flat or in some cases semi-gloss. The paint types, thicknesses, # of coats and general process is all the same.
Re: what is the satin black paint im seeing on some rods? [Re: grizzley155] #1052626
08/15/11 02:32 PM
08/15/11 02:32 PM
Mesa, AZ
Bill_T Offline
Bill_T  Offline
Mesa, AZ
Also check out the "Hot Rod Flatz" line. HRM or CC (can't remember) painted a car with it in a recent issue....
