Re: Carb selection for stroker 340
[Re: john volo]
#1052562
08/14/11 10:32 AM
08/14/11 10:32 AM
RapidRobert
Aye mate. At 1st blush I'd agree w you on the basic 3310 750 vac but since you are in the market for a new purchase I'd prob step up & go w one of the Holley clones that has all the adjustable circuits so if (when) you get serious about dialing it in w an AF meter you will b able to get it completely spot on (not a holley guy so no recommendations but someone will)
[Re: john volo]
#1052565
08/14/11 02:33 PM
08/14/11 02:33 PM
Posts: 413 northeast ohio
mkdart
northeast ohio
John, Your going to love that cam,I had the same one in my 360 before I stroked it.
Old combo,360,KB 107 flat tops,factory heads pocket ported by hughes, 37/42 solid cam,RPM intake,tti step headers w/ full exhaust,tko-600 5 speed,391 gear. I have 2 carbs that I would switch back and forth with.Holley 750 vac.secondary and a 750 DP.I like the way it runs with the DP better.
Mike
