Page 3 of 3 1 2 3
Re: How Fast with Indy EZ heads? [Re: sixpackgut] #1052476
08/18/11 11:19 AM
08/18/11 11:19 AM
MD
JACK1440 Offline
JACK1440  Offline
MD
here's another Sixpack.
Re: How Fast with Indy EZ heads? [Re: tboomer] #1052477
08/18/11 11:21 AM
08/18/11 11:21 AM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
I also presume that everyone using these heads are using the MW ports?
Mine are MW ports. Also another good thing about the heads is there are no external oil lines to mess with unless you go with the big ez's.
2013 NHRA D4 Stock Champ
#4 in the World IHRA Stock
2x IHRA Div.4 Stock Champ
14x Track Champ
All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: How Fast with Indy EZ heads? [Re: sixpackgut] #1052478
08/18/11 11:22 AM
08/18/11 11:22 AM
MD
JACK1440 Offline
JACK1440  Offline
MD
one more
Re: How Fast with Indy EZ heads? [Re: JACK1440] #1052479
08/18/11 11:38 AM
08/18/11 11:38 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
one more
i have one of those hood scoops and might put it on my car. might have to sit on a cowl though
Re: How Fast with Indy EZ heads? [Re: Dragula] #1052480
08/18/11 01:18 PM
08/18/11 01:18 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
What is the main difference between these and say the 440-1's, the port height?
EZ's use stock height exhaust ports, Stock rockers, and no external oiling.
Re: How Fast with Indy EZ heads? [Re: JERICOGTX] #1052481
08/18/11 03:45 PM
08/18/11 03:45 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
Can't wait to see what my turd will run it's a stock stroke 440 w/ez-1 660 lift cam (to much duration)going in a 71 demon w/4;56 and 14x32 tires
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Page 3 of 3 1 2 3
