3" Wheel Studs #1051872
08/13/11 08:59 AM
08/13/11 08:59 AM
WI
68hemiss Offline OP
68hemiss  Offline OP
WI
While installing 3" wheel studs on my 68 Barracuda (front) it seems that the aftermarket studs only have a 3/8" knurl while the factory studs have 1/2"-5/8". I am using new factory style rotors and hubs (2-peice) and the knurl is not long enough to hold the hub to the rotor. I know that when a wheel is attached it will hold the assembly together but I was wondering if anyone made a 3" wheel stud with a longer knurl? I have looked but they all seem the same?
Thanks,
Mark J
Re: 3" Wheel Studs [Re: 68hemiss] #1051873
08/13/11 09:04 AM
08/13/11 09:04 AM
IN
ahy Offline
ahy  Offline
IN
Agree you need it tight or you will be fighting it the first time a wheel has to come off. I use the MP 3" studs (1/2-20) from Mancini and knurl is sufficient.
Re: 3" Wheel Studs [Re: ahy] #1051874
08/14/11 10:12 AM
08/14/11 10:12 AM
WI
68hemiss Offline OP
68hemiss  Offline OP
WI
Thanks,
I had to go back to an older MP catalog to see a pic as Mancini doesn't have a pic. It looks like the shank is longer and the knurl is moved further from the head - this could work - any other suggestions?.
Re: 3" Wheel Studs [Re: 68hemiss] #1051875
08/14/11 08:48 PM
08/14/11 08:48 PM
East Coast, NJ
fig426 Offline
fig426  Offline
East Coast, NJ
A few different size knurls and the pics I found show the knurl at the base. Which studs are you looking at because I'm not seeing them and I need them also.
Chris from New Jersey
Re: 3" Wheel Studs [Re: fig426] #1051876
08/15/11 12:32 AM
08/15/11 12:32 AM
HR3128 Offline
HR3128  Offline
Here is a page from the arp catalog. they may have what you need.
The 7707 is the only thing I could find that would fit my 71 Satellite front discs. $60 some dollars for a package of 5.
The other part numbers are priced alot lower.
Re: 3" Wheel Studs [Re: HR3128] #1051877
08/15/11 08:17 AM
08/15/11 08:17 AM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Many years ago I had a local machine shop bore the holes bigger for the 2 piece rotors. They did that so they could use a stud the had in stock for something else. I could not find anyone who offered the correct 3" studs for Kelsey Hayes 4 piston calipers with the 2 piece rotor. This was in the late 80's so things might be different now, the point is where there is a will, there is a way
