Re: 11.39 @ 118.23
[Re: Kevins493]
#1051766
08/16/11 03:39 PM
08/16/11 03:39 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Jeff, go with caltracs. You've seen my 60' with them.
you gonna help me install them Kev?
Re: 11.39 @ 118.23
[Re: Mr.Yuck]
#1051767
08/16/11 03:56 PM
08/16/11 03:56 PM
Posts: 2,379 MD
Kevins493
MD
Re: 11.39 @ 118.23
[Re: Mr.Yuck]
#1051768
08/17/11 09:49 AM
08/17/11 09:49 AM
Posts: 75,274 A gulag near you.
JohnRR
A gulag near you.
Thanks HYPER, I forgot to add I'm also running a Snow Performace water/Meth injection system.
Jeff , what kit did you buy ? Any pics of how you installed it ?
Re: 11.39 @ 118.23
[Re: JohnRR]
#1051769
08/17/11 10:34 AM
08/17/11 10:34 AM
Mr.Yuck
Brookeville, Md
I bought the stage 1 kit http://www.snowperformance.net/product.php?pk=31
You can see it sort of here. The bottle mounts up front w/ the pump mounted on the bumper bracket. Then it runs up to a NOS solenoid (this just keeps the water/meth from accidently leaking into the intake) The 'noid is wired to the switch that starts push the mixture w/ the vacuum drops to zero and you're at WOT. I'll get sme better pics next time I get out there...
Re: 11.39 @ 118.23
[Re: Kevins493]
#1051770
08/17/11 01:37 PM
08/17/11 01:37 PM
Posts: 3,210 robin hood country
deaks
robin hood country
Be interesting to see back to back runs with race fuel and then the meth inj, how much do you use on a 1/4 mile run. Oh and congrats. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
Re: 11.39 @ 118.23
[Re: deaks]
#1051771
08/17/11 01:42 PM
08/17/11 01:42 PM
Mr.Yuck
Brookeville, Md
how much meth/h20? not much maybe an 1/2" a run. Race fuel would probably net the same results, but then I'd have to drain the tank and fill it w/ 110 and 110 is $7.12+ a gallon here. washer fluid is $.99/gallon
Re: 11.39 @ 118.23
[Re: JohnRR]
#1051773
08/17/11 03:35 PM
08/17/11 03:35 PM
deaks
robin hood country
You wouldn't need that level of octane anyway. My old motor used to run on pump 97, that we get here and that was 11.2.1 and my 12.5.1 440 i run now, i mix 97 and race 112 50 50. Mick
Re: 11.39 @ 118.23
[Re: JohnRR]
#1051774
08/17/11 03:40 PM
08/17/11 03:40 PM
Mr.Yuck
Brookeville, Md
Where does it inject into ?
1/2" open aluminum spacer under the center carb. Drill, tap, screw in fogger.
Re: 11.39 @ 118.23
[Re: deaks]
#1051775
08/18/11 01:11 AM
08/18/11 01:11 AM
JohnRR
A gulag near you.
Mick unfortunately we don'thave that good of gas here , But I do agree that is higher octane than is needed for an 11.0 motor with alum heads and good squish/quench.
