Re: Post your next bullit build,
[Re: Randy..]
#1051193
08/11/11 11:36 PM
08/11/11 11:36 PM
Posts: 522 Lenox Iowa
MMiller
Lenox Iowa
I'm planning a 470ish stroker with a pair of ported Max Wedge iron heads. 13 or so to 1 compression, E85 and a roller. Put it in a 75 Dodge 4X4 truck.
Before anyone says I should use aluminium such and such heads, the class I pull in requires Iron Factory block and heads.
Michael
93 W250 CTD getrag, Bosch 185 injectors, AFE air filter. Trailer puller, daily driver, 90 W250 CTD 727 with smokin 5" stacks. Off road truck
75 Dodge W200 440 4spd 4x4 locked front and rear, twin disc clutch, E85. Pulling truck
[Re: Moparnut426]
#1051195
08/12/11 12:00 AM
08/12/11 12:00 AM
Posts: 5,681 South Dakota
hotairballoonpilot
South Dakota
funny kasey very funny. I am in the same boat just not as deep as you are. the 340 in my duster when we did it 10+ years ago I was building it/trying to build it for strip/street duty. maxed out credit cards that we thanks to the wife got paid off about 7 years ago btw. Anyway I wanted a fast nasty loud car that I could drive on the street and people would go wow. I remember driving buy a guy and seeing him say "Healthy" I wanted that. Well things went down the hill on the 340 pulled it out and put the motor my brother bought for his car (Lil Red 360 motor) Nothing special lower compression. Hooked to my 727 tranny that has a higher stall and rear end with 4.56's and the best the car did was 16's on the track like 4 or 5 years ago. Was bummed seeing that but figured the odd ball combo explains that. Well now with kids I want to get the car running and back together(hasn't seen light of day since last years mopar show and that was 1st time in 2 years it seen light I think) and beable to jump in it and go get an ice cream cone and not worry about if or what will happen to it. Just beable to drive it and enjoy it. kinda sounds like what you are thinking.
corey
Contact Me about AMD Prices
[Re: hotairballoonpilot]
#1051196
08/12/11 12:45 AM
08/12/11 12:45 AM
Posts: 6,163 Melbourne , Australia
LA360
I have a low budget 360 I am putting together. It has Speed Pro Hypertec pistons, factory rods and crank, ported 587 castings, will run a dual plane with a 950 and a solid cam. Should work out alright until I finish off my P7 engine. Am toying with the idea of a bone stock 318 to go into the car for now, I have a baby on the way!
Alan Jones
[Re: MR_P_BODY]
#1051197
08/12/11 09:18 AM
08/12/11 09:18 AM
Posts: 12,478 Taxes & Virus's R-US, NY
Dragula
I have two engines I am doing this year.....Both are more of a rebuild, and both need new blocks. The first is my stroker W2 motor is getting turned into a pump gas monster, and the other is to rebuild my hemi with a new hemi block and switch to push rod oiling. Motor is out, heads are flowed and CC'd, intake and headers have been redone, and pistons will be ordered soon. We already have a couple of blocks, so now I just need to pick rings. Motor is out, pars are all over the garage, just need a new block. Sold the vintage block, need a new block, and new push rods & lifters....
[Re: tboomer]
#1051199
08/12/11 12:47 PM
08/12/11 12:47 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
I just want to get my new Indy EZ headed 493 to the track real soon. I am using a Dwayne Porter speced flat tappet cam that is nitrided and I use the EDM lifters. It is 264 & 270 at .050 with around .630 lift with 1.6 rockers. Cant wait to get some passes on it and do some tuning. Ron
[Re: rt66jim]
#1051204
08/12/11 06:12 PM
08/12/11 06:12 PM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
My next one will be a big inch pump gas wedge with victor heads. Or I will turn my current 499 into a pump gas but have to get some more power out of it because it cant slow down at all!
67' charger 499 RB
10.57 at 127
[Re: Scott58]
#1051206
08/13/11 09:01 AM
08/13/11 09:01 AM
Posts: 3,112 LONG ISLAND
fishy340
LONG ISLAND
604 Pump Gas Hemi street/strip engine:
Stage V Millenium heads Titanium valves and retainers Barton/T&D rocker gear World aluminum block Oliver 7" steel rods 11.7 CR "mild" Comp solid roller @280, .700"
Scott
thats the way i would go,if i were doing a bb please let us know how u make out,,,and good luck.
[Re: fishy340]
#1051207
08/14/11 12:46 PM
08/14/11 12:46 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Got some more parts to sell for pennies on the dollar of what they cost to start with. Then I am going to purchase the block and get going on at least 439 CID P7 all aluminum engine. It will be capable of running on pump gas. Hopefully an F4 procharger feeding two 140mm turbos. Then if we have any areas that we lack power there will be three fogger nitrous systems. The engine will run on anything from water to alcohol to gas to deisel. Bruno Liberty extreme tranny. Gonna set records for an all steel street car in drag racing and the salt flats. Look for the U-tube videos cause I am going to initiate the largest police chase while I am at it. A new TV show will be coming out "Wild Police Chases" "The one that got away". They will never find me because this is sure to self destruct in a very explosive finally.
Hurry up and check out page 4 of the race parts for sale ads I need a lot of money as you should be realizing by now.
Leon
[Re: Leon441]
#1051208
08/14/11 12:47 PM
08/14/11 12:47 PM
Posts: 2,028 Trumbull,CT.
jim sciortino
Trumbull,CT.
Leon
