I replaced the original switch with a new one tonight. There was no difference in the behaviour of the lights however, it is nice knowing that I have a new switch as the other was a litter worse for wear.
The lights are dimming and flickering when the rpms drop to idle. The intensity of the lights increase as the speed of the alternator increases. The volt meter reads a continuous 13.6v - 13.8v I could run a test I suppose and let it run a little longer to see if it drops off below 12v.
I trust the upgraded electronic reg when it arrives will help to maintain the current.
![](/ubbthreads/images/graemlins/luck.gif)
Thx
