How long to replace timing belt on 3.5?
#1050083
08/09/11 09:08 PM
08/09/11 09:08 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
It's time for me to do the timing belt on my 2002 Concorde with the 3.5 V6. The car has 95,000 miles. The thermostat seems to be sticking. If I'm going to drain the coolant I might as well to the 100,000 mile service.
How much time should I expect this to take? It looks like no special tools are needed but things are going to be a little tight down there.
Re: How long to replace timing belt on 3.5?
[Re: feets]
#1050085
08/09/11 09:50 PM
08/09/11 09:50 PM
Posts: 11,543 chicagoland,usa
buildanother
chicagoland,usa
Remove that upper plastic panel, plus the steel body colored panel beneath it, hood latch etc. Get the 4 10mm headed bolts off of fan assem and once thats out of the way, it's a breeze. Rad can stay in, balancer can stay on, the rest you should be easily able to handle. You really can sneak the belt in and out of there w/out manhandling at balancer. You'll need a vice to push the little tensioner actuator back in and a beefy nail or something to push through the hole in the actuator. There is a little smile shaped belt shield behind balancer that has to be removed like the 2 timing belt covers. The only thing you have to get under car for is to back the 2 accessory drive belt adusters off, once you loosen the 15mm nut a couple of turns. Beer actually might help too if nec.
[Re: buildanother]
#1050086
08/09/11 10:09 PM
08/09/11 10:09 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Don't atempt the cam seals with out the special tool to line up the cam gear and cam when you bolt them back together, you will get a rough idle, mabey loose a few HP. There is nothing to acurately index them with out it.
The belt it self is not too hard, just a few hours.
[Re: moparx]
#1050089
08/09/11 11:35 PM
08/09/11 11:35 PM
feets
Senior Management
Senior Management
Irving, TX
I was planning on replacing the water pump, belt, tensioner, and pulley. The thermostat needs to be replaced and it'll be time for the fluids too.
I really need to tackle the knocking suspension too. The cradle bushings are wasted and something has started banging around on bumps. This is a great car but I'm going to be cursing at it pretty soon.
[Re: feets]
#1050090
08/10/11 08:06 AM
08/10/11 08:06 AM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
Remember to triple check the cam timing also.Ive had a few where the cams moved off the mark when the tensioner releases.Really not a terrible job.If I hadnt just done the wifes PT Id do yours if you would have done the wifes.Rocky
Chrysler Firepower
[Re: feets]
#1050092
08/10/11 08:17 AM
08/10/11 08:17 AM
Posts: 8,430 St Charles MO
70Coronet500Vert
St Charles MO
Cam timing can be tricky or it can be a breeze. The first time I did it, lined up perfectly, stayed lined up and I reassembled.
After the new Cloyes tensioner bolt broke and destroyed my valves, the second time I did it, the timing kep jumping a tooth or two. The dots were just off. If took 3 or 4 times to get it right.
I released the tensioner, rotated the engine twice by hand then rechecked the dots.
It's not a hard job at all. I would tell people a day simply because of the way things go when I work on cars.
No matter how responsible he may seem, never give your gun to a monkey! 1970 Coronet Vert 1972 Charger 1974 Satellite Sebring Plus Sundance 2001 Ram 4x4 2002 Intrepid 2006 300C
[Re: Dartman75]
#1050095
08/11/11 03:34 PM
08/11/11 03:34 PM
feets
Senior Management
Senior Management
Irving, TX
I had one sway bar end link go bad last year.
This time it turned out to be the inner tie rod bushings. The right side bushings were GONE. The rubber had broken up and fallen out. That was not a fun job. I was able to get to it by turning the wheel all the way left and removing the air intake hoses. They're under the throttle body which is under the cowl. Once you get your hands on them you can't get your head in there to see anything. It's a 100% braille operation. It took about 90 minutes to do at home on the ground and in the dark. The knocking sound is gone and the car feels a wee bit better today.
