Re: Thermoquad stalling and idling rough when hot.
[Re: mopowergtx]
#1049996
08/09/11 04:32 PM
08/09/11 04:32 PM
Posts: 2,091 oberlin, Ohio
Rapid340
oberlin, Ohio
That carb should run fine as-is with a mild cam like that. My guess is a vacuum leak or the wells may be leaking. I think drilling holes was a mistake. I will be at the nationals on saturday and wouldnt mind taking a look if you bring it along. I will PM you my cell #.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
[Re: mopowergtx]
#1049997
08/09/11 11:57 PM
08/09/11 11:57 PM
Posts: 404 Central New York
bfury
Central New York
Try moving the throttle shaft up and down while it is running at idle. The holes in the aluminum base that the shaft goes through sometimes elongate and cause a vacuum leak. In the day we used to drill each side and put in bushings to seal to the shaft better.
No Stock
[Re: mopowergtx]
#1049999
08/11/11 10:49 AM
08/11/11 10:49 AM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
Drilling the holes will lean it out.
Throttle shafts wear the most on the passenger side.
Ethanol blends make it run leaner. Less BTU's in ethanol.
Your vacuum numbers are too low.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
