Page 2 of 4 1 2 3 4
Re: Edelbrock Victor heads: post your combos, please!!! [Re: sixpackgut] #1049276
08/10/11 10:47 AM
08/10/11 10:47 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I can only post the parts that will be going together, not any actual results from using them.
how about some pics of those fancy victors?
what rocker did you end up using?
I posted some pics of them a ways back on this thread: https://board.moparts.org/ubbthreads/show...rue#Post6188397
I picked up a set of Hughes' rockers in 1.6/1.5 ratio to use w/ the Victors to run on some RAS shafts.
Re: Edelbrock Victor heads: post your combos, please!!! [Re: BradH] #1049277
08/10/11 12:14 PM
08/10/11 12:14 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
wow, missed that post and i stalk yours
Re: Edelbrock Victor heads: post your combos, please!!! [Re: sixpackgut] #1049278
08/10/11 03:20 PM
08/10/11 03:20 PM
BradH Offline
BradH  Offline
Considering you know where I live (and have even been to my house even though I wasn't there at the time), that's kind of scary...
Re: Edelbrock Victor heads: post your combos, please!!! [Re: BradH] #1049279
08/10/11 04:03 PM
08/10/11 04:03 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
i just wanted to leave a reminder on the importance of useing oil in an engine
Re: Edelbrock Victor heads: post your combos, please!!! [Re: sixpackgut] #1049280
08/10/11 07:51 PM
08/10/11 07:51 PM
BradH Offline
BradH  Offline
You should just stick to posting pictures of your girlfriend wearing nothing but a 5-point harness. /
Re: Edelbrock Victor heads: post your combos, please!!! [Re: BradH] #1049281
08/10/11 08:12 PM
08/10/11 08:12 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
You got a link to those pictures Brad?
Getting old just means you were smarter than some and luckier than others.
Re: Edelbrock Victor heads: post your combos, please!!! [Re: dannysbee] #1049282
08/14/11 02:28 PM
08/14/11 02:28 PM
Westbury, NY
bumps440 Offline
super gas
bumps440  Offline
super gas
Westbury, NY
Want to keep this active.
what manifolds are the best on these with MW ports?
there are many indys to chooses from and the Edelbrock Super victor for max wedge ports 2893
Any one done any testing lately.
Re: Edelbrock Victor heads: post your combos, please!!! [Re: bumps440] #1049283
08/14/11 08:00 PM
08/14/11 08:00 PM
junction city oregon
V
viperblue72 Offline OP
V
Re: Edelbrock Victor heads: post your combos, please!!! [Re: viperblue72] #1049284
01/04/12 04:59 PM
01/04/12 04:59 PM
tboomer Offline
tboomer  Offline
Thought I would bring this back up again!! Any of you guys make the move to the Victors?
Re: Edelbrock Victor heads: post your combos, please!!! [Re: tboomer] #1049285
01/04/12 05:31 PM
01/04/12 05:31 PM
Idaho
LaRoy Engines Offline
Idaho
LaRoy Ported Edelbrock 440 Victors
500 ci/440 Wedge
1090 King Demon
Indy 3X Intake
Erson Solid Roller 280/288 @ .050"
Harland Sharp 1.6 rockers
440 Source Stroker Kit
14.5:1 on E85
600 lb-ft 5100-7300 rpm
650 lb-ft 5400-6400 rpm
658 lb-ft @ 6000 rpm
800 hp 6600-7400+ rpm
846 hp @ 7200 rpm
Re: Edelbrock Victor heads: post your combos, please!!! [Re: tboomer] #1049286
01/04/12 08:38 PM
01/04/12 08:38 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
John....I should have said the EZ-1..If I keep my car,Those are the ones I want..Now...Back to the Victors!!!
Thats what I am using the EZ heads. But I dont think they will flow as good as other Indy heads or the Victors because the exh is not raised. I mean they work very good I just believe the Victors and Indy -1 heads flow even better. Ron
Re: Edelbrock Victor heads: post your combos, please!!! [Re: 383man] #1049287
01/04/12 08:47 PM
01/04/12 08:47 PM
tboomer Offline
tboomer  Offline
Ron...Your car works very well! Dwayne did good on those heads! And heyoldguy...That there is pretty stout!!
Re: Edelbrock Victor heads: post your combos, please!!! [Re: tboomer] #1049288
01/04/12 09:15 PM
01/04/12 09:15 PM
V
V
Seems like brian at imm engines (ou812)has an article coming out about them? Or maybe its super stealths I can't remember.
Re: Edelbrock Victor heads: post your combos, please!!! [Re: tboomer] #1049289
01/04/12 09:16 PM
01/04/12 09:16 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
When I do another Big block I will definately try the Vics; I bought my Chapman 285's after the success Steve Dulcich had in our Engine Masters competition and they're awesome heads but they're tough to find, It looks like the cnc and professional porters have found the program that will pretty near match them on flow. They weren't available when I built my last MW stroker though and although I think a CNC Indy-1 is still the ultimate for drag racing, the higher velocity ports of the Vics should be better for a dual purpose motor in terms of mid range and roll on torque.
If there's one thing I do prefer on the Chaps is the Ability to run the RB Wax Wedge intakes on a low deck, Apparently every once in a while Ma has a good idea by accident. I also like the B1 sytle billet pedestals which I think adds a lot of stability with stiff roller springs, I wish Edelbrock offered it as an option.
WIZE
In Car:
Re: Edelbrock Victor heads: post your combos, please!!! [Re: Streetwize] #1049290
01/05/12 12:09 AM
01/05/12 12:09 AM
Wisconsin
sjs64polara Offline
sjs64polara  Offline
Wisconsin
I have a 505 with a little over 10.8:1 compression in my 64, MW Victor heads with 1.6 T&D rockers, and a Bullet 640 roller. The intake is a MW Rick Allison cross ram with (2) 835 Holley carbs done by Ken Jones.
Don’t recall exact number but I believe it was around 720/730 ish hp and the same for the torque. The max hp was made at 5500 rpm on pump gas and I shift at 6k. The 64 is 3650lbs+ and runs low 10.50’s depending on traction. The 60 foots are poor and the RacePak shows a lot of wheel spin. I know it has more in it but I haven’t figured it out yet.
Just make sure you have hood clearance…… I needed to use the 5”max wedge scoop because of the raised ports.
Re: Edelbrock Victor heads: post your combos, please!!! [Re: tboomer] #1049291
01/05/12 12:56 AM
01/05/12 12:56 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Oh by all means Ted you are right as the EZ heads are very good heads and for a guy like me who wants to keep it simple and have a decent running street/strip car you cant beat them. I just have heard that you can get more out of the heads with the raised exh ports. But I did not want the hassle of the header fitting and offset rockers. I went with the EZ heads as I felt if I do want to step it up more dowm the road that the EZ's have more potential the the Eddy RPM's which I was going to use. I would not hesitate to use the EZ's again and I am glad I did as it easily met my goal of running 10's on pump thru the full exh and driving to the track. Ron
Oh and thanks for the kind words Ted.
Re: Edelbrock Victor heads: post your combos, please!!! [Re: 383man] #1049292
01/05/12 01:37 AM
01/05/12 01:37 AM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
I run the victors and Dwayne ported them. makes about 725hp
dwayne also spec the roller cam too.
street/strip car
Re: Edelbrock Victor heads: post your combos, please!!! [Re: viperblue72] #1049293
01/05/12 01:37 AM
01/05/12 01:37 AM
SoCal
Brian Hafliger Online content
Brian Hafliger  Online Content
SoCal
Yeah, but we're starting with a 400, with budget in mind. The second article will be a stroker BB and ported MW Victors.
Once you get past the pushrod clearancing they are a great cylinder head.
If the guys at Koleno play along there will be a 3rd article based on their lowdeck block, and MAX effort Victor heads using either a vac pump or maybe dry sump. We want to see the very best they have to offer in a single 4 barrel build.
Brian
Brian Hafliger
Re: Edelbrock Victor heads: post your combos, please!!! [Re: Brian Hafliger] #1049294
01/05/12 01:39 AM
01/05/12 01:39 AM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
Brian
were can I see this story?
Re: Edelbrock Victor heads: post your combos, please!!! [Re: viperblue72] #1049295
01/05/12 03:09 AM
01/05/12 03:09 AM
usa
hot67cuda Offline
hot67cuda  Offline
usa
I only went to track once last summer with my victors car went 10.43 4 passes i was a little diapointed.I did no tunnig at all.I think the eng would be a lot happier with a bigger cam.I have a small roller in it now.265at .050 630 lift other that my 3500lb ride will see the 9,I do a lot of street driving I,m a carpenter in the sommer i park the truck and me and my helper will take the cudatruck to the job site with saws tool belt and all.yes we are carfull not to hurt my car lol.
Page 2 of 4 1 2 3 4
