Re: Edelbrock Victor heads: post your combos, please!!!
[Re: sixpackgut]
#1049276
08/10/11 10:47 AM
08/10/11 10:47 AM
BradH
I can only post the parts that will be going together, not any actual results from using them.
how about some pics of those fancy victors?
what rocker did you end up using?
I posted some pics of them a ways back on this thread: https://board.moparts.org/ubbthreads/show...rue#Post6188397
I picked up a set of Hughes' rockers in 1.6/1.5 ratio to use w/ the Victors to run on some RAS shafts.
[Re: BradH]
#1049277
08/10/11 12:14 PM
08/10/11 12:14 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
wow, missed that post and i stalk yours ![](/ubbthreads/images/graemlins/blush.gif)
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#1049278
08/10/11 03:20 PM
08/10/11 03:20 PM
BradH
Considering you know where I live (and have even been to my house even though I wasn't there at the time), that's kind of scary... ![](/ubbthreads/images/graemlins/eeek.gif)
![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: BradH]
#1049279
08/10/11 04:03 PM
08/10/11 04:03 PM
sixpackgut
Charleston
i just wanted to leave a reminder on the importance of useing oil in an engine ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: sixpackgut]
#1049280
08/10/11 07:51 PM
08/10/11 07:51 PM
BradH
You should just stick to posting pictures of your girlfriend wearing nothing but a 5-point harness. / ![](/ubbthreads/images/graemlins/devil.gif)
[Re: tboomer]
#1049286
01/04/12 08:38 PM
01/04/12 08:38 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
John....I should have said the EZ-1..If I keep my car,Those are the ones I want..Now...Back to the Victors!!!
Thats what I am using the EZ heads. But I dont think they will flow as good as other Indy heads or the Victors because the exh is not raised. I mean they work very good I just believe the Victors and Indy -1 heads flow even better. Ron
[Re: tboomer]
#1049289
01/04/12 09:16 PM
01/04/12 09:16 PM
Posts: 9,894 Weddington, N.C.
Streetwize
Weddington, N.C.
When I do another Big block I will definately try the Vics; I bought my Chapman 285's after the success Steve Dulcich had in our Engine Masters competition and they're awesome heads but they're tough to find, It looks like the cnc and professional porters have found the program that will pretty near match them on flow. They weren't available when I built my last MW stroker though and although I think a CNC Indy-1 is still the ultimate for drag racing, the higher velocity ports of the Vics should be better for a dual purpose motor in terms of mid range and roll on torque.
If there's one thing I do prefer on the Chaps is the Ability to run the RB Wax Wedge intakes on a low deck, Apparently every once in a while Ma has a good idea by accident. I also like the B1 sytle billet pedestals which I think adds a lot of stability with stiff roller springs, I wish Edelbrock offered it as an option.
[Re: tboomer]
#1049291
01/05/12 12:56 AM
01/05/12 12:56 AM
383man
Balt. Md
Ron...Your car works very well! Dwayne did good on those heads! And heyoldguy...That there is pretty stout!!
Oh by all means Ted you are right as the EZ heads are very good heads and for a guy like me who wants to keep it simple and have a decent running street/strip car you cant beat them. I just have heard that you can get more out of the heads with the raised exh ports. But I did not want the hassle of the header fitting and offset rockers. I went with the EZ heads as I felt if I do want to step it up more dowm the road that the EZ's have more potential the the Eddy RPM's which I was going to use. I would not hesitate to use the EZ's again and I am glad I did as it easily met my goal of running 10's on pump thru the full exh and driving to the track. Ron
Oh and thanks for the kind words Ted. ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Brian Hafliger]
#1049294
01/05/12 01:39 AM
01/05/12 01:39 AM
Posts: 4,152 SO. CAL.
70blackfish
SO. CAL.
Seems like brian at imm engines (ou812)has an article coming out about them? Or maybe its super stealths I can't remember.
Yeah, but we're starting with a 400, with budget in mind. The second article will be a stroker BB and ported MW Victors. Once you get past the pushrod clearancing they are a great cylinder head.
If the guys at Koleno play along there will be a 3rd article based on their lowdeck block, and MAX effort Victor heads using either a vac pump or maybe dry sump. We want to see the very best they have to offer in a single 4 barrel build. Brian
were can I see this story?
