383 stroker motor has anyone built one. #1048123
08/06/11 10:56 AM
08/06/11 10:56 AM
Maryville tn
67coronetman Offline OP
Maryville tn
Hello everyone i need to know who out here as built a 383 stroker motor and what all was done.? I am going to use a factory 440 crank i know it will need to be turned down.
please help with rods used and so on 383 rods or 440 rods what kind of advise could you give me i know there will be those that will say use a 400 block i am using what is avaiable at this time and i am trying to save money on using factory parts as much as i can.!
Any links or info would be very helpful and thanks.
Old car are me......
Re: 383 stroker motor has anyone built one. [Re: 67coronetman] #1048124
08/06/11 11:30 AM
08/06/11 11:30 AM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
Muscle Motors sells several stroker kits for the 383. Should be the same as a 400/451 other than the piston/bore size. They go bigger too.
Re: 383 stroker motor has anyone built one. [Re: Dean_Kuzluzski] #1048125
08/06/11 01:01 PM
08/06/11 01:01 PM
Maryville tn
Maryville tn
Yeah i looked at them but i need to saty in my budget with a 440 crank i have and use as much of my stock parts as i can times are very tight as it is for many of us.!
Re: 383 stroker motor has anyone built one. [Re: 67coronetman] #1048126
08/06/11 01:09 PM
08/06/11 01:09 PM
AndyF Online content
AndyF  Online Content
Look in the tech archives. I wrote a couple of articles on my 383 stroker as well as several long posts.
Re: 383 stroker motor has anyone built one. [Re: AndyF] #1048127
08/06/11 01:37 PM
08/06/11 01:37 PM
Maryville tn
Maryville tn
On here or on a different site.? or send me a link or my email would be of big help.
Thanks Mark
Re: 383 stroker motor has anyone built one. [Re: 67coronetman] #1048128
08/06/11 01:41 PM
08/06/11 01:41 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Diamond pistons has a stocking piston to use the 440 crank and 383 rods with 1.94 pin.
with the 440 length rod they go to .990 but if you phone or go through a dealer (better) they will do 1.094 rod.
BIG BLOCK MOPAR 383
4.280 3.750 6.360 1.720 597 1.094 x 2.930 -4.0cc 10.6 9.8 9.5 09024280 51910
4.310 3.750 6.360 1.720 600 1.094 x 2.930 -4.0cc 10.7 9.9 9.6 09024310 51912
BIG BLOCK MOPAR 383 W/ 440 ROD
4.280 3.750 6.768 1.320 call .990 x 2.930 -4.0cc 10.7 9.9 9.6 09024280 51950
4.310 3.750 6.768 1.320 call .990 x 2.930 -4.0cc 10.8 10.0 9.7 9024310 51952
http://www.diamondracing.net/MoParSection.pdf
word of caution/advice It cost as much to R&R a stock rod re-size ends new rod bolts not to mention should be polished and shot peened as new after market rods!!
this rod has the .990 pin
http://chucker54.stores.yahoo.net/eagchrysrb411.html
http://www.summitracing.com/parts/ESP-6760B3D/
when you get the crank mains cut have them cut down the counter balances 1/8" or so??
pistons at mancini's
http://chucker54.stores.yahoo.net/di104bo3st4.html
Re: 383 stroker motor has anyone built one. [Re: Dodgem] #1048129
08/06/11 01:55 PM
08/06/11 01:55 PM
SE PA
Born2Run Offline
Born2Run  Offline
SE PA
Re: 383 stroker motor has anyone built one. [Re: Dodgem] #1048130
08/06/11 08:02 PM
08/06/11 08:02 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
once again, nothing to 400s on same 383 specs
