Page 2 of 3 1 2 3
Re: My car fall on its face at the 1000 ft? long [Re: topside] #1047956
08/06/11 09:34 PM
08/06/11 09:34 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Cab, I think you're about right on the secs/gal; I seem to recall that 20 secs/gal is good for a low-10-sec car.
Fig, take a really good look at your spark plugs & check your float settings, and if there's any rubber hose in the system, make sure there aren't any internal cuts that can create a flap inside the hose that reduces the amount of fuel it can flow. If you're running a stock pickup, make sure the fuel isn't pulling away from it; on my Roadrunner, I added a length of suitable hose that lays on the bottom and extends rearward a bit inside the tank. My Duster uses a sump.
He's right on those numbers BUT those are a VERY
GENERAL number... weight of the car comes into play...
it takes more power to move a 3500# car to low 10s
VS a 2500# car to the same... more power requires
more fuel
Re: My car fall on its face at the 1000 ft? long [Re: MR_P_BODY] #1047957
08/06/11 10:13 PM
08/06/11 10:13 PM
more fuel
Lots of variables in this hot rodding business Lots of gremlins also
Re: My car fall on its face at the 1000 ft? long [Re: fig426] #1047958
08/06/11 10:17 PM
08/06/11 10:17 PM
Arizona
Chris'sBarracuda Offline
Arizona
1 gallon in 45 seconds from the blue pump. Picked up a Holley 150 black pump today. It's flow rate is pretty good, came with a new regulator, and it's alcohol compatible if I ever decide to change over. Looking like rain for tomorrow so hopefully if it's dry Wednesday night I'll bring it up to Island for a few passes. http://www.holley.com/12-150.asp
45 seconds...
That can't be good..
Chris..
Re: My car fall on its face at the 1000 ft? long [Re: Chris'sBarracuda] #1047959
08/07/11 12:26 PM
08/07/11 12:26 PM
East Coast, NJ
fig426 Offline OP
fig426  Offline OP
East Coast, NJ
Island is rained out today. Gonna have to wait until Wednesday.
Chris from New Jersey
Re: My car fall on its face at the 1000 ft? long [Re: fig426] #1047960
08/07/11 05:08 PM
08/07/11 05:08 PM
St. Louis Mo.
10 o to go Offline
"Happy Don"
10 o to go  Offline
"Happy Don"
St. Louis Mo.
do you have a fuel pressure gauge that you can see .Shoud be dropping at that point at losing HP . Fuel line, fuel filter
bet is the issue as others have said .
2009 418" build dan smith built new 9.96 131.82 6.23 108 1.30 60 foot best to date 9/15/09 8in 727 430 dana 2860 lb 3040 lb w driver
Re: My car fall on its face at the 1000 ft? long [Re: 10 o to go] #1047961
08/07/11 06:47 PM
08/07/11 06:47 PM
East Coast, NJ
fig426 Offline OP
fig426  Offline OP
East Coast, NJ
I can't see the guage from the seat. It's on the inner fender. All my lines are clear, filter is good. I'm gambling on the blue pump not keeping up. The black pump is in and I'll find out what happens Wednesday night, weather permitting.
Re: My car fall on its face at the 1000 ft? long [Re: fig426] #1047962
08/07/11 06:52 PM
08/07/11 06:52 PM
Southern by Choice
Shoozy Offline
I have a foot fetish
Shoozy  Offline
Southern by Choice
How long for the black pump to pump a gallon?
Old, tired, and sometimes broke down. Me, not my car...
Re: My car fall on its face at the 1000 ft? long [Re: Shoozy] #1047963
08/07/11 06:59 PM
08/07/11 06:59 PM
East Coast, NJ
fig426 Offline OP
fig426  Offline OP
East Coast, NJ
140 gph at 7psi. So mathematically it flows 1 gallon in 25.75107296137339055793991416309 seconds. Approximately
Re: My car fall on its face at the 1000 ft? long [Re: fig426] #1047964
08/07/11 07:15 PM
08/07/11 07:15 PM
Southern by Choice
Shoozy Offline
Shoozy  Offline
Southern by Choice
A realtime test will let you know the entire system. Might be good info to have before you go out again. Plus we're nosy.
Re: My car fall on its face at the 1000 ft? long [Re: Shoozy] #1047965
08/07/11 08:23 PM
08/07/11 08:23 PM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
Hey Fig, did you degree your cam, it seems way retarded, had the same problem with a buddy's car, cam was off 8 degrees.
Re: My car fall on its face at the 1000 ft? long [Re: cgall] #1047966
08/07/11 08:34 PM
08/07/11 08:34 PM
Richmond Va, KeislerTKO 60...
V
VanishPt Offline
VanishPt  Offline
V
years ago , I had a BG diaphragm (sp) bypass on a 528 Hemi with a 950 Holley . I happen to look at the fuel pressure gauge as i was going through the lights--2 lbs. Turned the setting on the bypass to get it up to about 6 lb and picked up 8 MPH on the next run.
Re: My car fall on its face at the 1000 ft? long [Re: cgall] #1047967
08/07/11 09:06 PM
08/07/11 09:06 PM
East Coast, NJ
fig426 Offline OP
fig426  Offline OP
East Coast, NJ
Yes sir it's degreed. Pulls nicely in 1st and 2nd, just falls flat in 3rd at about 4000rpm.
Re: My car fall on its face at the 1000 ft? long [Re: fig426] #1047968
08/08/11 09:11 AM
08/08/11 09:11 AM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
You will need to measure it because your overall system also effects what it will flow. Going by the rating alone, your blue pump would have filled a gallon in 32 seconds.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: My car fall on its face at the 1000 ft? long [Re: Rapid340] #1047969
08/08/11 11:00 AM
08/08/11 11:00 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
The number 8 line you have from cell to pump isn't going to cut it. You need -10. The line after the pump can be -8 but I'd go 10 until the regulator then -8's out to the carbs. Your issue is almost certainly a fuel delivery problem.
Re: My car fall on its face at the 1000 ft? long [Re: BobR] #1047970
08/08/11 01:50 PM
08/08/11 01:50 PM
ill
dennismopar73 Offline
ill
dont forget the vent , might surprise you ??
Re: My car fall on its face at the 1000 ft? long [Re: Rapid340] #1047971
08/08/11 05:33 PM
08/08/11 05:33 PM
East Coast, NJ
fig426 Offline OP
fig426  Offline OP
East Coast, NJ
88gph for the blue. 88gph/60minutes in an hour =1.466 gallons per minute. 60 seconds in a minute/ 1.466 gallons = 40.9 seconds per gallon.
Re: My car fall on its face at the 1000 ft? long [Re: fig426] #1047972
08/08/11 06:51 PM
08/08/11 06:51 PM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
I see, I thought you where comparing a 140 GPH free flow black pump to a 110 GPH blue pump. I would still check it.
Re: My car fall on its face at the 1000 ft? long [Re: Rapid340] #1047973
08/08/11 10:56 PM
08/08/11 10:56 PM
Saskatchewan, Canada
cudabin Offline
cudabin  Offline
Just to be sure, did you check the valve springs? I know you said it pulled strong in 1st and second, but I would check seat pressure and open pressure to be sure...
I used to run 9.55 at 138 with nothing but a single Blue pump...
Good luck,
Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...) 70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
Re: My car fall on its face at the 1000 ft? long [Re: cudabin] #1047974
08/11/11 12:20 AM
08/11/11 12:20 AM
East Coast, NJ
fig426 Offline OP
fig426  Offline OP
East Coast, NJ
Made 2 passes tonight with the new fuel pump. First one redlighted -.437. 12.01 at 118mph. Total mess of a start but it pulled strong throughout. Second run. 60 foot 1.705 . .1 slower than last week. 330' 4.844. 1/8 7.424 at 95.56mph. 1000' 9.647. 1/4 11.531 at 119.41mph. I did a bad burnout and spun 1st and second. Pulled strong through the lights at about 6400rpm. Have some other things to sort out, like me being the driver , but I think it should go into the high 10's. Also it runs like turds after I go through the traps. Seems like now it's loaded up with fuel. I'll play with the fuel pressure, maybe a return line. Thanks again to all of you for the help.
Re: My car fall on its face at the 1000 ft? long [Re: fig426] #1047975
08/11/11 12:28 AM
08/11/11 12:28 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Good to hear it pulls all the way... set the pressure,
set the floats and most likely you will have to do
some jetting
Page 2 of 3 1 2 3
